Question about Maytag M6P09S2B Portable Air Conditioner
I have to drain the water more i think there is a problem
E5 error on Onida washing machine Need solution
5E. This means the washing machine has a "water drain error". It's basically timed out on empty, it's tried draining out the water for 10 minutes and the water level still hasn't fallen below a specified level (or at least it thinks it hasn't). This error should be reset by pressing the Start/Pause button though if there is a fault it will need fixing or the error will just return.
A washing machine not emptying the water can have various causes as can a washing machine thinking it hasn't drained the water because it's possible that the signal telling the machine that the water has gone can sometimes not be triggered if a fault in the pressure system prevents it.
To troubleshoot this problem the first thing to check is the pump filter, which could be blocked. I have extensive advice on diagnosing pump faults here Washing machine won't drain water (stuck full of water) ' Faults on pressure system
May 17, 2015 | Washing Machines
Need to empty reliance 501 hot water heater how?
1) Shut the breaker off to it at the panel. 2) Hook a hose up to it (the bottom has a drain). 3) Close the valve to the water heater (on the cold water supply). 4) Open drain on the bottom of water heater. 5) Open the relief valve to allow air into the tank (it won't drain otherwise - think if you put your finger on one end of a straw - the liquid stays in until you let go). Why are you draining it by the way?
Jan 26, 2010 | RELIANCE ELECTRIC WATER HEATER
Water keeps rising inside the dishwasher while its off not in use
Try filling your sink up with water and draining it while watching the dishwasher bottom if it starts fill it is back flowing from the sink drain
Mar 29, 2009 | Jenn-Air Dishwashers
No Drain Knob on my Singer CSP 1
I would think that your water tank in missing a grey rubber bung, which pushes in to a small hole under the water tank.
Mar 05, 2009 | Singer CSP1 Iron
Frigidaire D/W. Model fd8750rcc0
hi Dishwashers usually run on 115-volt or 120-volt power. The water they use comes directly from the water heater, and wastewater is drained into the sink's drainpipe. The dishwasher is not connected to the cold-water supply. For best dishwashing results, set the temperature control of the water heater to no less than 140 degrees Farenheit. Water cooler than this usually doesn't get the dishes clean, unless your dishwasher is a newer model that preheats incoming water. The water shutoff for the dishwasher is typically located below the adjoining sink.
Nov 06, 2008 | Zanussi 24 in. DA6153 Free-standing...
We bought a washer yesterday. When I went to fill it up this morning the water would not fill but just drains, while the water is running, please help, I think it is something simple/
The drain hose is too far down the drain. Pull out excess hose from drain and leave only 8 to to 12 inches. Using zip tie or other method, secure drain hose to water hoses to prevent drain hose from jumping out.
Jun 08, 2008 | GE Washing Machines
LG WT-R801 keeps draining
If the cycle does not stop draining that is usually because of a faulty membrane switch that controls the water level in your appliance.
The faulty sensor cause the machine to think that there is still water inside, even when water has drained completely.
May 16, 2008 | LG WM0642H Front Load
WATER IS NOT DRAINING IN THE BOTTOM OF DISHWASHER
I am thinking these expensive dishwashers have reached end of life. I cannot get it to drain, clean the dishes or shut off when the door is opened. I bought this product thinking due to its cost, it would last longer. So sick of being ripped off. Let me know if you find a solution RMCDaniel at kervin@avaya.com
May 01, 2008 | Dishwashers
Bosch Dishwasher Not Draining
Im really not all that familiar with the bosch unit, but a few things i would ck. when you cancel a cycle (it should drain the water) is it humming??? does it sound as if it even trickling into the sink discharge?? do you have a disposer under your sink that this unit drains into, if so remove the clamp and look for possible obstructions right there.Honestly passed this ill have to defer to someone else sorry and good luck
Mar 10, 2008 | Bosch SHU9915UC Dishwasher
Water leaking frigidaire frs23h5as
yes remove the rear panel in the freezer where you see the drain hole. Clear the ice from the drain hole. It will take a while for the water to start to drain because the ice is deep in the insulation. A small tube is helpful to draw some hot water in and stick in in the drain hole and squirt the hot water down in the hole.
Nov 25, 2007 | Frigidaire FRS23H5AS Side by Side...
Maytag M6P09S2B Portable Air Conditioner Logo
Top Maytag Heating & Cooling Experts
Bill Long
Donni Steen
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
