Question about LG LRBP1031T 10 cu. ft. Compact Bottom Freezer - Titanium
How do you vacuum coils ? - LG LRBP1031T 10 cu. ft. Compact Bottom Freezer - Titanium
Still having problems will not run good. 1997 ford 2.0 escort;new plugs&wires coil;fuel pump still codes 0351;
From a reputable repair website:
P0351 - OBD-II Trouble Code
Auto Systems and Repair
Ignition Coil "A" Circuit Primary/Secondary Malfunction Our emissions expert has put together the following information about the P0351 fault code. We have also included diagnostic procedures you can take to your repair shop if the mechanic is having difficulty analyzing the code.
OBD II Fault Code
  • OBD II P0351 Ignition Coil "A" Circuit Primary/Secondary Malfunction
What does this mean? The ignition coil or coils are responsible for igniting the air/fuel mixture inside the combustion chambers. Without reliable performance from the ignition coil(s) the vehicle will stumble and misfire.
Code P0351 indicates there's an electrical problem in either the primary ( the computer side ) or the secondary ( the spark plug side ) of the Ignition Coil "A" Circuit.
Symptoms
  • Check Engine Light will illuminate
  • Engine idles rough
  • Engine misfires on acceleration
  • In rare cases, the engine may not exhibit noticeable symptoms
Common Problems That Trigger the P0351 Code
  • Defective Ignition Coil(s)
  • Defective Spark Plug(s)
  • Intake Manifold Vacuum leaks
  • Carbon buildup in the Throttle Body air passages
  • Defective Idle Air Control Valve or Electronic Body
Common Misdiagnosis
  • Ignition coil(s) replaced when cause of the malfunction was a vacuum leak
  • Spark Plugs replaced when cause of the malfunction was a vacuum leak
Dec 21, 2014 | Ford Cars & Trucks
Refrigerator is not cooling
Have you cleaned the coils lately? If not, unplug the appliance after you've located the coils. They may be on the bottom or in back. Dust on the coils can hinder the cooling process. I purchased a good quality long handled brush from the Fuller company. Extend the brush carefully into the coil area, twirl and pull out. Do this for the entire coil area. You'll be amazed at the "fun stuff" you'll remove. You may also use the crevice tool of your vacuum cleaner. If your vacuum has a dusting brush that is small enough, that may be used as well. Also, pull the refrigerator out and vacuum the floor under it well . If the cooling doesn't improve, you will probably need to get a professional to check the refrigerant level.
Nov 01, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
How to clean condenser coils on lfx25960tt
Condenser coils- The condenser coils dissipate heat. If dust and debris accumulate around the coils, your refrigerator may not be able to cool properly, it may run continuously or it may stop completely as a result of an overheated compressor. You should clean rear-mounted coils once a year. Unplug the refrigerator before cleaning. Refrigerators are heavy, never tip one forward or backward. Never attempt to move a refrigerator without an assistant. Vacuum or brush the coils. If coils have a filmy build-up, use warm soapy water to clean them. Take care not to spill or drip water onto the components of the refrigerator.You should clean floor level coils at least twice a year. Unplug the refrigerator before cleaning. Vacuum or brush the coils. Remove the grill from the front of the refrigerator and use a vacuum with a wand attachment to remove any dust and debris. The grill should snap off and on. Pull firmly toward you and possibly upward to remove the grill. If it does not come off with a modest effort, check for screws or retaining clips that may hold it in place.
Sep 04, 2010 | LG LBC22520S (224 cu ft) Bottom Freezer...
Nedd to test coil on an 89 chevy 2500, dont know parameters
PICK-UP COIL (HEI)
1. Isolate 2 pick-up coil lead wires. Remove pick-up coil connector from module. Connect ohmmeter to either terminal and ground. See Fig. 4 . Connect pump and apply vacuum to test vacuum advance unit. Replace vacuum advance unit if inoperative. Connect ohmmeter to pickup coil terminals. Operate vacuum pump and observe ohmmeter throughout the vacuum range.
2. Attach ohmmeter to one pick-up coil terminal and distributor housing. Set ohmmeter to middle scale. Operate vacuum advance throughout vacuum range. Reading should be infinite at all times. If not, replace pick-up coil. See Meter "A" in Fig. 4 .
3. Connect ohmmeter leads to pick-up coil connector terminals. Operate vacuum pump to ensure proper operation throughout vacuum range. Flex terminal wires by hand to check for possible intermittent defects in wiring or connectors. Pick-up resistance should be 500-1500 ohms. If resistance is incorrect, replace pick-up coil. See Meter "B" in Fig. 4 .
NOTE: Activation of the vacuum advance may align trigger wheel tooth and pick-up coil pole piece causing ohmmeter pointer to deflect. This
deflection should not be diagnosed as a faulty pick-up coil.
Jan 20, 2010 | 1990 Chevrolet K2500
The freezer is staying @ 10deg, set at -2deg. I had a message "vacuum condenser" I did turned of & then on message has not appeared for more than a day. no new message, seems to be constantly...
I\'ve been struggling trying to keep our 2 goldens dog hair from the coils of our 8 year old Kenmore side by side with "W" compressor coils, but like everyone else was unable to clean past the first set of coils.
I came up with this solution that worked to get much of the big stuff, hair and bunnies, off of the further back coils. Not perfect but much better than nothing.
Removing the back lower panel I was able to snake a crevice attachment from our vacuum down the right side of the coils (left side looking from back)
I made a compressed air contraption to blow the dust/hair across the coils using a compressed air nozzle that I added a 10" long tube and a 90 degree deflector
From the front of the fridge, on the left side of the coils, I snaked the compressed air nozzle towards the back and started directing the air stream blowing towards the vacuum crevice tool at the opposite side of the coils.
The compressed air dislodged the hair/dust enough that the vacuum was able to suck it away. Again, not perfectly but certainly much better than I was able to clean the coils in the past.
I suppose you could use a can of compressed air and add some sort of deflector if you don\'t have a compressor.
I then got to thinking how to prevent the dust from accumulating on the coils, I\'m going to try an air conditioner filter. I cut it slightly oversized to fit the front opening then split it in half to make it thinner for more air flow.
7a2fbc41-ef6b-4a4c-8961-a892df9da8ab.jpg 938facae-8d39-4f2b-b07c-82f5e4219751.jpg
Picture taken before making the filter thinner. For years I had my calendar remind me monthly to vacuum the coils but now hopefully I\'ll be able to simply change the air filter.
Jan 07, 2010 | Sub-Zero 642
Can't clean coils under fridge
Dec 18, 2009 | Whirlpool GS6NBEXR Side by Side...
The refrigerator/freezer is not cooling it has power just will not cool
Try cleaning the dirt off the coils. First vacuum off all you can. If there are a lot of places the vacuum cannot reach, get a refrigerator coil brush at the hardware store and losen the dirt, then vacuum again.
Dec 01, 2009 | Sub-Zero Refrigerators
How do you get in to clean dust off the condenser coils? On this model, the narrow grates across the front and back of the coils make it impossible to vacuum off the coils. It's not like most refrigerators...
Looking from front"
Sep 08, 2009 | Estate TT18TKXKQ Top Freezer Refrigerator
I need to vacuum the condenser in a sub zero,
The condenser coil is located behind the cover on top of the two doors and when you take it off you see the coils that look like a radiator (fins and copper pipes) ,turn of the refrigerator and with a brush and a vacuum clean the coil very carefully and don't push to hard against the fins.
Aug 24, 2009 | Refrigerators
LG LRBP1031T 10 cu. ft. Compact Bottom Freezer - Titanium Logo
12 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
