Question about Braun Flex XP II 5790 Electric Shaver
Base floods with solution during cleaning cycle
My husband went too long between changes of cleaning solution (he is deployed and couldn't get his hands on any) and now even with fresh solution when he tries to clean the razor, the cleaning solution floods up into the base and won't drain back down.
He's looked for some obvious hole that's blocked with gunk but can't seem to find anything to clean out. We can buy a replacement base but they are $50 - might as well get a new shaver. I'd love to get the one we having working again and send this shaver back to my husband in the desert.
  • vwhite5974 Nov 08, 2007
    btech25, I tried that and it didn't work. It looks like the solution fills a small reservoir and then spills over into the drainage tube so clearing with a q-tip will only work if it's the tube that's clogged. The entire reservoir is gunked up and I think the base is a total loss.
    But thank you for your suggestion. I gave it my best shot and ended up ordering a new base from
    Problem Solver:
  • 10 Answers
OK, Remove shaver from cleaning base. Raise top cover as if you are going to replace the cleaning cartridge. Now, look into the cleaning cup where you put the shaver into.You will notice a small hole on the bottom left side. With a Q-tip ,clean out the beard hair from the hole.If you have a model 5301 which is located on the bottom of the base, you should be able to push the Q-tip all the way through the hole. This will allow the liquid to flow back down into the cartridge.This is whats causing the overflow.
Posted on Nov 04, 2007
Getting a 2003 kia sorento to start after hitting a tree and the airbags deploy
Diagnosing that problem will require
professional help.
There is no way without the vehicle,
we could even list a bunch of guesses
Sep 04, 2012 | 2003 Kia Sorento
My Maytag PAV2300 did not stop filling during the rinse cycle and overflowed flooding the laundry room and the water seaped into the furnace vents. The water found its way into the cealing and damaging the...
I would recommend calling your homeowners insurance and having them take care of the damage. As far as what is wrong with the washer? That needs to be diagnosed. I found this link:
Best of luck
Dec 18, 2011 | Maytag PAV2300 Top Load Washer
Odor coming from disposer
Hello, Tell your husband to wash his feet some place else, OK. it needs to be cleaned. Don't put you hand in it, OK. On the top in sink remove the rubber flapper and clean it with soap water and vingear. Put about four large cups of ice and tuirn on the disposer. The ice clean out any stuff that in the chopping blades. Mix up a sink of water, soda and a little clorex in the disposer sink then let the sink drain and turn on the gargage disposer then let it run while water is running into it. Do a cleaning procedure once or two a month. couple of lemons, Clorex, baking Soad, this stuff will work great. It will make you disposer smell like fresh spring day but tell you husband to keep his feet out of the kitchen sinks. GB...stewbison
Sep 24, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Hi, i've taken the top and sides off my Bosch dish washer sgs45e02gbas it has not been working. the problem is ....when you switch it on is there is a pumping/throbing noise but doesn't continue...
Hello Phillip,
The reason only the pump runs anytime its powered up is because the flood detector has detected water in the base of the dishwasher and until that water is gone only the pump will run.That flood detector is (when looking at it from the front) is in the left front corner,its a styrofoam disc with a rod in the center of it and has floated up activating the flood switch on the letf side wall where the water enters the tub (can be seen on the left side with side panel removed) if thier is no water in the base frame perhaps some foreign object has wedged itself under the sytrofoam disc holding it up. Until the water is out of the base frame only the pump will run as long as the flood switch is tripped.
Possible things that will make water be in the base frame are,
oversuds from too much detergent
a leak of any component or hose
a defective water level switch allowing it to overfill
Sep 06, 2011 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
We bought this mower about a month ago. My husband is getting ready to deploy for a year, so I thought I would mow make sure I don't have any issues before he leaves. Of course, I...
The most simple solution is try using fresh gas (dump the old, put in new), if that doesn't work it is probably a carb issue that needs to fixed.
If for some reason you can't get it to work, one of the awesome non-profits available to military families is Project Evergreen, they'll mow your lawn for free while your husband is deployed.
Aug 29, 2011 | Poulan Pro " Pro" Self Propelled Mower
My ex husband was in a roll over car accident in his 2006 ford fusion going 70 mph and his air bags didnt deploy. is there a recall on those or does he have a possible case for his injuries?
Front air bags are not designed to deploy in side impact, rear impact or rollover crashes.There are several reasons why your air bag may not have deployed during a crash. The first reason is that perhaps your crash is not the type of accident where air bag deployment would be helpful. For frontal air bags, this includes many, but not all, side impacts, rear impacts and rollovers. This category also includes minor accidents in which the driver and front passenger (if there was one) did not suffer any significant injuries requiring medical treatment. Many people do not realize there are a lot of side air bags that do not deploy during a rollover accident, even when the vehicle rolls onto its side. That is because those side air bags do not include an appropriate crash sensor that can detect rollover crashes.
Aug 03, 2011 | 2006 Ford Fusion
I replaced the cleaning liqud cartridge but it shows the red light indicating it is empty.
here is the solution..follow the steps please..
Thanks in advance for rating me..Regards
  • Replace the cartridge in the base station and close it.
  • The indicator light should cycle then change to green. If it doesn't then unplug the base station, wait a few seconds, then plug it back in.
  • Press the lock button to clean the shaver. If everything went well it should start cleaning like normal.
    Aug 27, 2010 | Braun 360° Complete Electric Shaver
    Step by step instuctions on how to do oil change for 2007 lexus 350 rx
    Before attempting this locate the oil filter and be sure YOU can access it comfortably with a filter wrench.
    You will also need to locate the drain plug on the lowest portion of the underside of the engine oil pan. The plug likely has an Allen key insert so be certain you have the correct wrench to match, along with matching filter and oil pan plug seal..
    Rotate the plug counter clockwise to loosen. I change and drain mine with the oil filler cap off so air can help the drainage. Then I unscrew the filter and reinstall a fresh one being certain the gasket are is clean on the engine surface.
    Reinstall fresh filter hand tight, two hands. Install drain plug by hand so as not to cross thread with a fresh seal if required, hand tighten with wrench. Then fill resevoir with at least 4 ltrs recommended oil checking dipstick so as not to overfill.
    After starting check for any drips of clean fresh oil;
    Dec 23, 2009 | 2007 Lexus RX 350 FWD
    Braun Flex XP II 5790 Electric Shaver Logo
    411 people viewed this question
    Top Braun Health & Beauty Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
