Question about Sewing Machines
How do I oil singer 5932?
My manual says nothing about oiling my Singer 5932. Should this be part of regular maintenance and if so, how and where do I oil the machine?
Mimito7
  • 128 Answers
SOURCE: Need to clean and oil my Singer 14u34B serger
There should be little holes on the top of the machine, an opening near the bobbin winder and one on the base of the machine about 3 inches from the face place. Also, you can open the bobbin area to put a couple of drops down inside there. The best utensil to clean the machine (especially near bobbin) is a bird feather. The bend easily around corners with out breaking.
Posted on Apr 22, 2009
  • 43 Answers
SOURCE: NEED MANUAL FOR SINGER IZEK SEWING MACHINE
You can get a free downloadbale / printable copy by goig to http://www.singerco.com/accessories/manuals.html and cliking on the "Free Download!" button to the right of the English version description.
Posted on May 06, 2009
  • 1116 Answers
SOURCE: I need the oiling instructions for a Singer 9410 sewing machine
You can get a free download from Singer. The maintenance section should have the information you are looking for.
Posted on Apr 20, 2010
  • 1116 Answers
SOURCE: 8280 Mechanical Sewing Machine: i need free manual for singer sewing machine model...
Free download here - http://www.singerco.com/accessories/manuals.html
Posted on May 07, 2010
  • 29 Answers
SOURCE: Singer Samba 6 sewing machine
It would be wise to have the machine cleaned & serviced. Do you have a manual for it? Did it come with oil at one time? I found a free manual at
http://homeappliance.manualsonline.com/manuals/mfg/singer/7442.html
You have to register (free)...choose to skip the popups (2)...and you can save the manual to your hard drive.
I checked the manual...you don't need to oil the machine...but page 61-63 shows cleaning...and it's basic. You take the two screws from the throat plate, remove the bobbin case & brush the inside of the machine bed out...I use a small artists plastic bristle brush, or a small childs tooth brush.
Hope this helps.
Posted on May 14, 2010
Testimonial: "Hi, thanks a lot. I don't know if it came with the oil, we assumed that it maybe needs oil (my father knew this from the old machines ;-) ) Again thank you very much for your quick answer!"
Do I need to oil my singer merritt sewing machine. I have a manual but it says nothing about oiling it.
If it is a computerized sewing machine, they are usually self-contained and do not require oiling except as directed or by a technician.
If it an older mechanical machine, generally they do need regular oiling to keep them running in fine shape.
Wheel on right side that controls the needle up and down is very tight...
Mar 30, 2017 | Singer Sewing Machines
Singer T&S 638, the whole bobbin assembly popped out. My mom-in-law said the needle caught and it just popped out. So it must be pssible to "pop" it back in, right? :)
Manual may be helpful:
Singer Touch Sew 638 Instructions Manual
Just an FYI, be sure to apply a couple drops of fresh good quality sewing machine oil as directed in the instruction manual. Do NOT use 3-in-1, WD-40, cooking oil, or old stinky brown sewing machine oil. Keeping it regularly maintained will keep your sewing machine running smoothly for many years.
Oct 20, 2016 | Singer Sewing Machines
Will not zigzag or decorative stitches. New to these newer plastic style machines Always used older steel machines. This was given to me my by my sister who used it very little. Could cam be broken?
Hmm, I'm wondering if it has been cleaned and oiled recently. Older mechanicals require frequent TLC. Consult your owner's manual for cleaning and maintenance instructions:
Is your sewing machine mechanical (ie, not computerized)??? CAUTION--if your machine is computerized, do NOT proceed with the following suggestions.
If it is mechanical, have you cleaned and oiled your machine recently? Most mechanical sewing machine failures are because they have not been adequately and routinely oiled, the old oil has solidified and frozen the mechanics. I recommend Bernina oil or liquid Tri-Flow Synthetic Lube (or similar good quality sewing machine oil) for mechanical machines--do NOT use 3-in-1, cooking oil, WD-40, or the sewing machine oil from your grandmother's sewing basket. (I am not associated with any Bernina dealer.)
If it is in fact frozen, pick up a bottle of liquid Tri-Flow Synthetic Oil at the hardware store. Oil one or two drops in every oil hole (see your manual) and also every place where metal rubs on metal. But DO NOT oil any plastic gears, rubber, or belts. If it is still stiff or frozen, direct a hot handheld hair dryer into the top and bottom mechanism of your machine. See if that loosens it up. You may have to repeat.
Once your machine is working again, place a drop or two of good sewing machine oil as directed above. Be sure to use a small brush to clean the lint and dirt out of your machine, especially around the feed dogs and bobbin area. (Caution: Compressed air will sometimes force the dirt and lint into areas that cannot be cleaned.) And continue to use good quality sewing machine oil to keep it running. Recommendation: every time you change a bobbin, after 8 hours of sewing, or every six months if it is not in regular use.
Dec 30, 2015 | Singer 6038 Mechanical Sewing Machine
How do you raise the feed dogs on the Singer Stylist 776?
Here's a manual to download for your machine:
http://www.singerco.com/uploads/download/abbd2bd7616f2b26729a1f5800a872ec0dc41c5e.pdf
It appears that your machine does not have a drop feed-dog function. Instead, you would need to buy a special plate that covers the feed dogs. (See page 6)
If the feed dogs are not functioning properly, then consult the maintenance section of the manual for cleaning and oiling. Most likely, the feed dogs need oiling. Be sure to perform regular maintenance on your machine to keep it operating.
Aug 29, 2015 | Singer Sewing Machines
How do you oil the singer xl.1000
please read the instruction menu for oiling area. a small plastic bottle singer oil can be purchased at joanne fabric shop or any department store carries fabric. if you can't find the menu booklet, a drop of oil should be enough on all moving mechanism. don't over do it. best way is move the pulley where the belt is attached. see the movement for all moving mechanism. then one drop oil should be enough. be sure clean out the dust in general are by using vaccum cleaner before lubricating the macjine. do not oil the belt, otherwise will lose friction and slip when sewning. hope this will help. bob
Mar 02, 2015 | Singer Quantum XL-1000 Computerized Sewing...
How to use the stich pattern on singer model 5932?
Download the instruction manual free from the Singer Sewing Machine site; it's on page 17.
Jun 20, 2014 | Singer Sewing Machines
How to oil a singer fashion mate 258
Try searspartsdirect.com
They have all brands.
Sep 02, 2012 | Singer Sewing Machines
Do I need to oil my singer pioneer II machine
All sewing machines need regular maintenance and this includes using sewing machine oil (supplied with all Singer machines when new) where indicated by the user manual.
I can't supply you with a link though as it's not clear which model you have. Simplicity and Singer are different brands and you seem to have mistakenly mixed them up.
Oct 07, 2010 | Simplicity Pioneer II SA200 Mechanical...
Sewing Machines Logo
73 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
