Question about Garden
Which manufacturers make a lawn tractor that uses a drive shaft?
I need to find a riding mower/lawn tractor that uses a drive shaft instead of one that is belt-driven, since we have some hills that we would have to mow, and belt drives can't handle hills for too long. Do you know of any manufacturers/models there are that use a drive shaft? Thanks in advance!
  • 513 Answers
Kubota does & i also think john deere does try them
Posted on Jun 28, 2009
Mower wont cut going up hill
there should be two drive belts. they should be replaced both at the same time. if one is wore so is the other one. use the correct belt, from a lawn mower parts store.
Aug 26, 2016 | John Deere D140 22HP V-Twin Foot Pedal...
Model 944.601380 Wouldn't pull up even a small hill. How thick should the rubber on the friction disc be? It doesn't seem worn but that is all that I can see drives the wheels. Can't find any belts to...
If it is a Craftsman riding mower, it has to have a drive belt unless it is shaft-driven. Its behaving precisely like a mower which has a drive belt that is so worn its "hanging by a thread - literally". That's why it won't pull a hill but is OK on level ground. You need to replace the drive belt, but you need to find it first. Consult your manual about what belt to use (you can get it at Sears) and the routing pattern.
May 24, 2016 | Craftsman Garden
Deck will not engage
if belt driven, check belt,could be loose belt drive hub spinning on shaft
Sep 08, 2012 | Cub Cadet Riding Lawn Garden Zero Turn...
My craftsman tractor wont pull itself up a hill. Runs fine but just comes to a stop when trying to go up a hill. Maby the ground drive belt is slipping????
Sounds like your drive belt is slipping alright. Need to tighten your clutch rod. One end of rod adjust. Have someone help you, move the clutch petal and your helper watch and see rod moves.
Nov 14, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
The mower can not go up a hill. It does not quit running just doesn't move.
The drive belt is too loose...you need to replace or tighten the belt...replacement is probably the best option...
heatman101
Aug 25, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman lawn tractor mower, automatic,917.273621, transmission will not pull mower up a slight hill. richard swint drive/motion belt seems normal,
The belt is probably slipping because it is not tight enough. look by the belt, inside there is a little spring, you may half to tighten it.
Jun 13, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Murray Lawn Tractor won't go up hill
Your drive belt is worn/slipping
May 31, 2009 | Garden
Riding lawn mow
give as the model so we can help.
Apr 15, 2008 | Black & Decker 19" Electric Lawnhog...
Garden Logo
157 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
