Question about Dryers
How do you replace the timing belt on a 1992 volvo 940 turbo?
  • 89 Answers
I need diagram of timing marks and belt allignment for 1992 volvo 940
best thing you can do is buy a repair manual at any autoparts store .
Feb 15, 2012 | 1992 Volvo 940
Belt Routing Diagrams
For belt routing diagrams of 1992 volvo 940. Click the link below:--- http://technoanswers.blogspot.com/2011/10/timing-belt-diagram-for-1992-volvo-940.html ----------- Its with proper detail and procedure. ----- This will help.Thanks.Helpmech.
Oct 24, 2011 | 1992 Volvo 940
I have 1992 Volvo 940 turbo 4cyl . I need advice on how to change my alternator belt
Underneath the alternator facing forward is a 13 mm nut which locks the alternator in place, slacken this off and the two nuts/bolts where the alternator pivots.From the left side of the car there is a 10 mm bolt which is the tensioner, slacken this untill the alternator can be moved towards the engine sufficiently to remove the belt .Reverse this procedure to replace the belt. (depending on drives to other items you may have to remove their belts as well)
Dec 20, 2010 | 1993 Volvo 940
I have a volvo 940 1992 non turbo and sometimes it won't start
you have to check you engine starter (dispositive that is made to turn on your car)
Jul 30, 2010 | 1992 Volvo 940
What is the engine size for a 1992 940 volvo
Turbo or non turbo engines are 2.3 liter.
May 20, 2010 | 1992 Volvo 940
Volvo 940 turbo oil control valve location
take off pipe going to the intercooler from the turbo see if oil is found and clean then other pipe from incooler check it .if oil is found .drain oil in intercooler .you have an oil leak from the turbo this is why you will have light on far left of dash
Mar 01, 2009 | 1992 Volvo 940
Code 1-1-3 volvo 940 turbo
The code seems to point to the camshft actuator circuit. Namely the Oil Control Valve. Probably needs replacement. I do not know the location on your vehicle. I suggest you ask a mechanic or try to find it online.
Feb 28, 2009 | 1992 Volvo 940
1992 volvo 940 turbo died while driving and will not start
two things to check,,, there is a crank sensor at the back of the engineby the bulkhead,,at the top of the engine where the gearbox joins ,,,the sensors are known to be faulty if sometimes ,,, check the cable to the sensor,,if it is damaged replace the sensor,,,the other common problem is the fuel pump relay,,, behind the fusebox in the dash
Nov 16, 2008 | 1992 Volvo 940
Suspension
I know the 93 940 turbo has pos track rear end, going to about 15mph.
Sep 07, 2008 | 1992 Volvo 940
940 GL Stall problem
crank sensor problem
Jun 16, 2008 | 1992 Volvo 940
Dryers Logo
37 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
