Question about Troy Garden
Why does my 50"mustang xpshuts off when i engage the pto
Mustang 50"mower why is itcutting off when i engage the pto?
  • 4 Answers
Have you checked the safety switch under the seat? A lot of the riding mowers I've seen have a number of "safety" locks to keep a person from doing bodily harm by NOT being in the driver's seat.
Posted on May 12, 2014
panilling9
  • 284 Answers
SOURCE: cub cadet mower pto will not stay engaged while
be sure your battery is good and your system is chargingning the battery while run
Posted on May 26, 2009
panilling9
  • 284 Answers
SOURCE: engine stalls when electric PTO clutch is engaged
check your spacers to be sure you havent locked the clutch assembly directly to the motor shaft
you should be able to turn it fairly free less some clutch drag
MIlfordPrint
  • 90 Answers
SOURCE: Mower runs but blades aren't turning
You can get help at both of these places:
http://troybilt.custhelp.com/cgi-bin/troybilt.cfg/php/enduser/std_alp.php
http://www.mowersdirect.com/technical-support.php
Posted on Aug 03, 2009
SOURCE: pto blows the fuse everytime i engage it on my rzt
Wire harness for the PTO on the RZT's is designed dangerously near the drive pulley. After time, the harness drops and comes in contact with the pulley which grinds through the coating and shorts out the circuit. Repair (tape up) the wiring, relocate the the wire to the opposite side of the crank pulley (may have to zip-tie in place) - shouldn't be a problem anymore.
Posted on Sep 09, 2011
  • 6468 Answers
SOURCE: Cub cadet zrt50 mower deck will not engage
check the fuse then see if there's power to the clutch then check the safety switches
Posted on Apr 19, 2012
I replaced drive belt on troybilt mustang rzt shortly after electric pto clutch stopped engaging
Moist likely you failed to reinstall PTO clutch correctly as it sound the anti-rotation device wasn't installed. When you started the engine it would spun pulling the wiring apart. Hopefully just connector came part; otherwise, you might need to purchase a new PTO clutch assembly.
May 12, 2015 | Mustang Garden
What is the Function of the pto control
It is to supply power the electric clutch that drives the mower deck.
If not functioning then the switch, PTO clutch, or wiring is not working properly. Note on some ZTRs when both handles are in reverse then electric clutch is disengage for safety.
Oct 06, 2014 | Troy Bilt 25HP VTwin Hydrostatic 50" Zero...
Pto won't engage blades
ether switch bad fuse blown behind dash or pto bad if pto 300.00
Sep 12, 2014 | Troy Bilt 25HP VTwin Hydrostatic 50" Cut...
Troybuilt Mustang RZT mower pto blades not engaging
Unplug the wire at the pto and turn the ignition key in the on position, us a tester to see if you have 12 volts to this plug, if you do then the pto itself is bad, if not then the pto switch is most likely the culprit.
Jul 29, 2014 | Garden
New pto switch stoped working after 4 mowings
Maybe the problem wasn't the PTO switch. My Cub Cadet RZT PTO would disengage when I backed up and then failed to re-engage. I was able to isolate my problem to the safety switches at the base of the steering levers. I sprayed them with WD40 and they've been fine. Just a thought and worth checking. I hope this helps.
Jun 15, 2014 | Mustang Rzt 50" Zero Turn Riding Lawn...
Mower: Troy Bilt 42 Mustang Zero-turn mower: The
Hello Donna,
I would remove the battery and have it tested at a local parts store. It sounds like the battery to me.
Sep 08, 2013 | Mustang Rzt 50" Zero Turn Riding Lawn...
When I pull the PTO lever up, it does not engage the blades.
you will need to check and see if the voltage is getting to the pto itself if it is then the pto needs replaced if not then the switch is bad
Apr 17, 2011 | Mustang Rzt 50" Zero Turn Riding Lawn...
Put mower in reverse, turned it off and mower
There are safety interlocks on zero turn mowers. These prevent starting unless you have: 1. the handles in 'neutral' position 2. the brake on 3. the mower engagement (PTO) switch off 4. yourself in the seat.
Chances are one of these conditions hasn't been met. Since you were reversing when it happened, perhaps you haven't got the handles back to neutral position?
Jul 06, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
Garden Logo
32 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
