Codigo for pvr activat the tv2 - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 74,383 Answers
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier.
http://electrohelponline.blogspot.com/ Check this link too. http://remotesearch.blogspot.com/
Posted on May 11, 2014
Samsung retune
Hi, Try this go to menue on tv run the channel scan function.
If you are using a PVR or Tivo do the same with that, But you will have to set your TV to channel 3 to get your PVR/Tivo going. or in some TVs TV1 or TV2...depending how you hooked it up.or if you have HDMI cable... Good luck
Feb 11, 2014 | Televison & Video
Dstv remote not working on any blue dials? Two tv's in separate rooms, one pvr decoder. Only the red dial works on both tv's & both remotes are working & both tvs responding properly.
Is this a newly installed system? If both tv's are responding to the same remote setting (red in case), it means both tv's are set to the same channel. The tv that is connected to the decoder directly (via AV cables, I presume) is supposed to respond to if the remote is set to red. In order for the second tv to respond when the remote is set to blue, you need to tune the second tv until you find the picture of tv2 (the decoder transmits both tv1 and tv2 on the RF/coaxial output and it seems that your remote tv is tuned to tv1 instead of tv2).
Apr 02, 2013 | Televison & Video
Como puedo programar una tv samsung con el control de dish
Hola! Mi nombre es Kimberly Escobar con DISH Network, sera un placer proveerle la informacion que necesita. Para programar el control remoto a su televisor Samsung hay ciertos codigos que puede integrar al control para que funcionen con la t.v. Los codigos para un televisor Samsung son los siguientes: 738, 516, y el 680. El procedimiento a programarlo el el siguiente: Oprima el boton de t.v localizado en la parte de arriba del control por 5 segundos hasta que todos los demas botones se iluminen rojos, una vez esten iluminados ingrese uno de los codigos seguidos por el signo de numero (#) por ejemplo 738# el boton de t.v deberia iluminarce 3 veces, despues de esto puede tratar las funciones. Si tiene preguntas adicionales puede contactarme directamente a kimberly.escobar@dishnetwork.com
Kimberly Escobar
DISH Network
Aug 07, 2011 | DISH Network IR Remote Control
Compre una tarjeta y cuando entre el codigo en mi computadora para comprar games el sistema me dice que el codigo esta mal o que la tarjeta no tiene fondo que puedo hacer
Primero identifica que estas entrando el codigo correcto. Tratalo por lo menos dos veces. No trates esto mas de 10 veces porque subes el riesgo donde PSN puede cerrar tu codigo.
Si eso no funciona, asegurate que el codigo que te dieron esta activado. Para asegurarte de esto, verifica en tu recibo de la tienda que te activaron tu codigo al momento de comprarlo. Normalmente en el recibo de la tiendo debe de decir ACTIVAT FEE.
Otra opcion podria ser de simplemente esperar. Puede ser que tu codigo se cerro si lo intentaste muchas veces. Solo espera unas horas para entrarlo otra ves.
Tu ultima opcion podria ser de solamente regresar la tarjeta a la tienda a cambio de una nueva.
Gracias.
Feb 27, 2011 | Video Game Consoles & Games
I have a Dish receiver 322. TV1 is set on channel 3 and TV2 is set on channel 116. Everything worked. We moved the receiver and TV1 into another room (right next door to where it was). We triple checked...
Hi hartbettinaI see where your TV2 has a blue screen, there are a couple of things you can doyou can do. The first things you want to do is press the buttons of MENU-6-1-5and see if TV2 is set to channel 60 or 73 and make sure TV2 is on that channel.Once TV2 is on the channel on the Modular Setup page you will want to unplugthe receiver for 10 seconds and plug it back in and it will reset itself. Iwill send a link that will help with these steps. http://www.dishnetwork.com/SupportSection/black-blue-tv2
Feb 27, 2011 | DISH Network 322 DTV Receiver
How do I add another TV to Dish network. I simply want to view the SAME channel as on one of the other receivers? I now one PVR and one box on Dish.
What you are looking for is called a mirrored location. Its a location that mirrors either tv1 or tv2. It can be installed using simply a few splitters depending on how you want it ran. If you do it your self it will save you alot of money. If not Dish Network will charge up to $99 for a reinstall
Nov 20, 2009 | DISH Network DVR-625 DTV Receiver /...
My dvr remote 2 has been taken over by my other tv2 remote is there a way activate the former remote? I just had a hdtv dual dvr installed and a new dual reciever. I already had a dual dvr. When I had the...
Unplug one of the receivers. Now go to the second and with the TV1 remote press MENU-MENU and you will see the two remote addresses displayed. On the TV 2 remote that is associated to turn off the TV2 with this receiver press and hold the SAT button on the top left of the remote until all the buttons across the top illuminate. Now key in a two digit number that differs from the one for TV2 displayed on the screen. Now press the pound sign and the SAT button will flash three times. Next press the small record button until the TV2 address changes to the correct two digit number. Now you should be able to turn the other receiver back on and be able to control each TV2 independent of each other. Thanks for using Fix Ya. If you need further assistance let me know.
Sep 17, 2009 | DISH Network IR Remote Control
Dish Network not working all... lights up but nothing else!
call dish network. they have all the information you could possably need.
their phone number is inside your recivers manual
Aug 19, 2009 | Universal Remote Control Dish Network...
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Electro Med Services...
