Question about Optics
Marlin 22 57m has ejection problems
My marlin 57m lever does not eject well
  • 243 Answers
Check the ejector on the inside right of the receiver. If it does not stick out slightly the flat spring underneath it may be broken. Also be aware that you should open the action briskly. Speed of opening has a major impact on ejection.
Posted on Jun 23, 2014
  • Leonard Zook Jun 23, 2014
    Sorry, should be the inside LEFT of the receiver.
2 Suggested Answers
strech3030us
  • 1554 Answers
SOURCE: I'm trying to see what year my marlin lever action rifle is.
1883
Found here:
http://oldguns.net/sn_php/marlinlookup.php
Posted on Mar 28, 2014
Year for Marlin 1894: 94010182
Here you go. It is a question often asked.
  • Model 1894 - Marlin Firearms www.marlinfirearms.com/Firearms/1894Centerfire/1894.asp Model 1894. Built in the tradition of one of Marlin´s oldest lever-action designs, the Model 1894 is an elegant carbine chambered for handgun calibers.
  • Marlin Serial numbers - OldGuns.net oldguns.net/sn_php/marlinlookup.php Marlin Lever Action Rifle Serial Numbers 1883 to 1906 (Including Models 1881, 1888, 1889, 1891, 1892, 1893, 1894, 1895 and 1897.)
  • Marlin 1894 serial number question - Marlin Firearms ... www.marlin-collectors.com > ... > Cowboy Guns Savvy Jack; When Marlin developed this serial number system, they used the current year, subtracted from 100 to determine year of manufacture.
  • Marlin Serial Numbers = Dates of Manufacture ' Gun Values ... www.gunvaluesboard.com/marlin-serial-numbers-dates-of-manufacture... Marlin Serial Numbers = Dates Of Manufacture ... Marlin rifle with serial number on bottom stock tang, ... I have a model 1894 Marlin 32-20 sn 149833.
  • Marlin Model 1894 38-40 Serial Number Question - M14 Forum m14forum.com > M14 Forum > Gun Forum > Lever Action
    • 16 POSTS
    • FIRST POST: 2013-09-12
    2013-12-09 · Marlin Model 1894 38-40 Serial Number Question. This is a discussion on Marlin Model 1894 38-40 Serial Number Question within the Lever Action ...
  • IMPORTANT Model 1894 - Marlin Firearms www.marlinfirearms.com/pdfs/manuals/MFC_Centerfire_1894.pdf · PDF file CENTERFIRE Lever Action Rifles Model 1894 IMPORTANT This manual contains operating, care and maintenance instructions. To assure safe operation, any user of ...
  • Marlin Model 1894 Lever Action Chambered In .32-20 https://www.bigironfirearms.com/marlin-model-1894-lever-action-in... Marlin Model 1894 chambered in 32-20, serial number 162 manufactured 1898, 24" Octagon Barrel with full length tube magazine & Lyman Tang Sight.
  • Jul 05, 2016 | Optics
    Wont eject round after firing
    Probably the ejector itself, or the extractor.
    You weren't too specific.
    Is the round staying in the chamber?
    Coming part way out?
    Coming all the way out, just not ejecting out the action?
    Coming out, and staying in full contact with bolt face?
    Coming out, dropping away from bolt face?
    Etc..........
    Jul 19, 2014 | Marlin 70510 336 Model 336 Lever 30-30 Win...
    Disk will not eject
    Unplug the drive. insert a paperclip in the hole in the back of the drive. This will manually eject the disk. You can also open the cover but that's a lot more work than you need to go through when a simple paperclip will move the manual eject lever.
    Jan 19, 2014 | Iomega Z100P2 External ZIP Drive
    Marlin rifle model 795 jams intermittently
    It takes about 250 rounds to break in a gun. Try some hotter ammo and see if the problem disappears, if so, call Marlin and ask them for their solution if you want to keep using Federal, you might want to try some Remington standard velocity target, it is very accurate in most guns.
    I would shoot it for at least 500 rounds and clean it from powder debris in chamber and receiver bolt and trigger group and try it again, however don't hesitate to get a hold of Marlin, they are nice folks.
    Feb 12, 2013 | Marlin 795 Semi-Automatic -22LR Rimfire...
    Hi, the flash card card-eject lever spring is broken and wont eject the card. u have to manually push the card in place and pull the card out. the lever stays up until u shut the card slot door.once the...
    I have the same problemI think that the reason that the not record the image is that the card slot door is pushing down on the card eject lever and ejecting the card when the door is closedThe only answer I can think of is to shorten the leverdavidh
    Feb 18, 2011 | Konica Minolta Dynax 5D / Maxxum 5D Body...
    I have a ithaca model 49 lever action single shot and it wont eject shells after firing it but it will eject it if i dont fire it,in other words it will eject a live round but not a spent one
    there is a lever under the barrel and it is probably worn beyond function or broken off all you need to do is disassemble the gun and replace it. ( get yourself some good brass punches)
    Feb 08, 2010 | Guillemot Hercules Dualpix HD 4780428...
    Cannot find way to eject tapecassette
    Check eject lever near battery, press it downward to open tape compartment, take out old tape and put new tape, close tape door and let it go inside by itself. Close tape compartment.
    Below image will help you to locate eject button/ lever in DCR-HC18E camcorder.
    Thanks.
    Sep 20, 2009 | Sony Handycam DCR-HC40 Mini DV Digital...
    The "arm" that ejects the slides has jamed on my Kodak projector.
    the grease on the moving parts of the mechanism gets sticky with age. when the motor and cam stick, the select and index levers (which the cam moves) will stick. you'll need to remove the top and the whole mechanism and clean it out with wd40, dry it and regrease it. just remember what you removed so as to reinstall it properly.
    Aug 09, 2009 | Kodak Office Equipment & Supplies
    Optics Logo
    209 people viewed this question
    Top Optics Experts
    Joe Lalumia aka...
    Joe Lalumia aka...
    james laughton
    james laughton
    Are you an Optic Expert? Answer questions, earn points and help others
