Epson 8100 blurry in spots
Projected image is blurry in only selected spots, The center could be focused but the sides will be blurry or vice versa. Could a new bulb be the reason?
  • 146 Answers
SOURCE: HP vp6162 projector spots on projected image
you may have touched the bulb while changing it and minute traces of skin oil are on the actual bulb, with the machine cold, try and very carefully clean the bulb
Posted on Jan 05, 2008
bestdarngood
  • 3037 Answers
SOURCE: Toshiba 3LCD Projector - No image from the computer
You will need to go into your control panel and get the display settings set up.
To do this follow the detailed directions at the following link and you should have no problems what-so-ever
http://qbx6.ltu.edu/s_schneider/howto/displays.shtml
If you have any further questions please let me know, I am very familiar with setting up multiple screens and such if for some reason you have questions with the directions on the link above.
Thank you for using Fixya and Good Luck to you
Posted on Apr 19, 2008
projdoc
  • 2237 Answers
SOURCE: There are blueish-purple crystal-like distortions
either there is something on the inside of the lens, or there is something on the lcd prism face. if it was the lcd panel, it would be in focus with the picture. take it in for a good cleaning.
Posted on Aug 15, 2009
heathgr
  • 442 Answers
SOURCE: Cannot focus uniformly across the
try bringing the screen up as close as possible to the projector and still get a focused picture. check keystone here and also for image clarity. if you still have problems, check for dust or moisture etc in the optics. check the lamp for a clean front surface. clean the air filter also. Try a different image source for differences
Posted on May 22, 2011
jerry_kramer
  • 3904 Answers
SOURCE: epson projector center blurry
Sounds dumb on this one but make sure the lens is cleaned. Other then that check the manual for operating range of lens to screen. Typically somewhere in the area of 8 to 12 feet.
Posted on Oct 10, 2012
My epson projector center is blurry
Hello, if it's mounted you may have never adjusted the "focus" on it before. Just slowly turn the end grey colored lens one way or the other with a stationary picture such as the menu on the screen, adjust it to where the lettering is the sharpest.....tks
Nov 09, 2013 | Epson Powerlite Home Cinema 8100 Home...
Epson projector center blurry
Oct 09, 2012 | Epson PowerLite 83 Plus Projector
White spots on screen i have changed the lamp
It's probably you have a busted DMD chip, have your technician replace that, better yet buy a new projector because replacing that chip costs almost a brand new unit.
Nov 19, 2011 | BenQ Office Equipment & Supplies
Cannot focus uniformly across the projected screen. This seems to be more than a focus problem in that some areas of the image seem blurry as opposed to out-of-focus. Also, in what may be a related...
May 20, 2011 | Eiki LC-XB25 Projector Multimedia...
I bought the 10x25 camera binoculars and only one lens will focus using the center dial. Its almost like the other one needs to be focused at the eye piece itself. The pictures are not clear and are...
It is common for binoculars to have one independently focusable eyepiece.  If one eyepiece can be rotated, then that is the case.
If that is the case, focus through the one that DOES NOT rotate using the center control until you get a sharp image on that side.  Then rotate the eyepiece on the blurry side until the blurry side is sharp.  If you succeed at this, from henceforth the center control will focus both eyes adequately
Aug 11, 2010 | Sharper Image Optics
Projected image is blurry, mostly at the top of half. Weird. Tried another laptop. Although that one was slightly clearer, the top of the image was still blury.
Clean the lens on the front, turn on the projector and wait for it to heat up, then turn the plastic ring on the front to change your focus. computer image can't be made blurry because of software. Blurriness is always something to do with the lens.
Jun 10, 2010 | Sanyo PLC XU35 Multimedia Projector
Yellow spots on the projected image
Hello there. First, some info you need...Green LCD=purple onscreen, Red LCD=cyan(baby blue) onscreen, and Blue LCD=yellow onscreen.
These spots (specks?) are probably dust particles that get past the filter. Annoying but harmless. To check if they are indeed dust bits, if you can focus sharply on them, then yes, its dust. To remove the particles completely will require a service. They will only return eventually. You can try to blow out the biggest offenders with some canned air. And, to help slow down dust entry, keep the dust filter cleaned so that the unit always has plenty of air movement--you'll have a cleaner image with the added benefit of LONGER life of the lamp and projector components (dust is the number 1 killer of projectors)
Aug 30, 2009 | Epson PowerLite® S4 LCD Projector
There are blueish-purple crystal-like distortions in the projected image. They actually can be brought into focus to look at, and at that point the projected image is extremely out of focus. So, obviously,...
Aug 14, 2009 | NEC MultiSync MT840 Multimedia Projector
Jan 05, 2008 | HP VP6121 Multimedia Projector
Picture focus
Low light = long exposure times
There for hand shake - use a tripod or subject movement.
Dec 08, 2007 | Epson PhotoPC 850Z Digital Camera
jasbo
jasbo
