Question about Sewing Machines
Problem with spinning bobbin case base of my Pfaff 360 sewing mac
I was sewing on an upholstery project when I suddenly felt metal dragging on metal, when apparently the needle shaft began rubbing on some portion of the hook/bobbin housing. I checked below and found that the bobbin case base was not in the usual position, so I reached over and slowly turned the balance wheel. I was horrified to find that not only was the rotary hook assembly spinning like it is supposed to, but the bobbin case base was spinning along with it.
    Problem Solver:
  • 7 Answers
On lockstitch machines with rotary hooks the base[the bit the spoolcase fits in]is held in place by a retaining finger,tip machine back and you will see a long finger with a right angle lug sticking out approx 4/5mm .loosen the screw holding the finger only slightly and spin the base till the top of the base is at the 12.00clock pos.[it will help if you take needle plate off]the lug fits into the cut out of the base.then tighten finger screw and try. if base is jammed you will need a mechanic to dismantle hook and repair and retime the machine.
Posted on Jun 24, 2009
The top thread will not pickup bobbin therad it is a pfaff 5.0 machine
The bobin may not be in correctly. When looking at the bobin, with the thread threaded through the bobbin case, make sure that it spins counter clockwise. Also the problem could be caused by the machine not threaded correctly. But it is more likely the bobbin case and bobbin
May 04, 2017 | PfaFF Sewing Machines
5.0 pfaff will not pickup bobbin thread when getting ready to sew
Make sure your bobbin is spinning in the correct direction when installed, and that it is the correct bobbin case as well.
Cheers,
Chance
Embroidery Services
San Diego, CA
What size bobbin for a pfaff creative sensation
Bobbins (10pk), Pfaff #820921096: Sewing Parts Online
www.sewingpartsonline.com > Pfaff Parts > Creative 2.0
  1. Cached
  2. Similar
Product Details. Guaranteed to fit Pfaff Sewing Machine Models: Group J: creative sensation, creative sensation pro, creative performance, creative vision, ...
Pfaff - creative sensation™ pro
www.pfaff.com/en-US/Machines/creative-sensation-pro
  1. Cached
Now your PFAFF® creative sensation™ pro can embroider faster than ever ... needed to achieve perfect balance between the needle and bobbin threads.
Pfaff - Accessories
www.pfaff.com/en-US/Accessories?page=5
  1. Cached
Results 161 - 200 - Revel in a wide range of PFAFF® accessories .... blue bobbins for sewing, embroidering or experimenting with the creativeBobbin Case. bobbin for pfaff creative sensation Google Search
Dec 31, 2016 | PfaFF Sewing Machines
Needle Jams In Bobbin Case Area pfaff 1540
First, make sure there is no debris and scraps of thread in the bobbin area. I'm sure you did that already. I assume you also tried it with another thread just to be sure. I would suspect that the timing went out of whack. The machines depend on a synchronization between the needle motion and the bobbin action underneath. I once had a Singer that slipped and I had to reset the timing. If it is the timing synch problem then it would happen consistently and not work sometimes and then not work other times. G
Jan 27, 2014 | PfaFF Sewing Machines
Bobbin case inserting wrong
hi, Can i ask what model Pfaff it is ?
Regards
Rob
www.electronicrepairs.co
Dec 29, 2013 | PfaFF Sewing Machines
Pfaff tiptronic 2020 locking up/cutting bobbin thread
try changing the needle
when sewing a project-- the needle & fabric & thread must be compatable
check to see if there is any burrs on the needle plate or on the bobbin case
always make sure every thread guide is used
make sure the bobbin is inserted correctly in the bobbin case
Mar 31, 2012 | Sewing Machines
How do you insert a bobin?
Drop the filled bobbin into the bobbin case with the bobbin spinning counter clockwise, slide the thread into the **** in the metal part of bobbin case at the 6:30 position, drag the tail of the thread to the right and rear of the machine.
Apr 07, 2010 | Elna 2007 Mechanical Sewing Machine
Needle stuck in the material while sewing a straight stitch.
See if you can release the bobbin from the case.
Dec 30, 2009 | PfaFF Sewing Machines
Frozen Sewing Machine Arm/Pfaff Tiptronic 6270
Good morning,
A question to help determine what's happening with your machine(s).
Open the bobbin case so you can see the bobbin area. Begin by trying to turn the handwheel towards you and watch as the needle attempts to go up/down. If you cannot turn the handwheel towards you, turn it slightly backwards then forwards. Does the needle hit the bobbin case as it comes down?
If yes, your machine is out of time and will require a professional technician to repair.
If the above is not the case, there may be thread jammed behind the bobbin case or wrapped around the inner parts of the take-up lever.
Either case - a Pfaff authorized technician would be your best bet for a proper repair.
Best of luck with your machines - it's just awful to not have the at the ready for all our projects!
Happy sewing,
Kim & Linnette
Jul 30, 2008 | PfaFF Tiptronic 2040
Sewing Machines Logo
426 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
