Question about Car Audio & Video
[Clarion 46804666] screen flashing nothing more
Hello, I have bought a Clarion 46804666 and I don't have its wiring manual but after googling I found that I need only to connect both the yellow and Red to the positive and black to the ground. http://img.cogsci.nl/uploads/536ea2573481d.jpg after I did so, the screen and the button light are keeping flashing. Nothing more happens. Is there any solution?
  • 1 more comment
  • Xtreme
    Xtreme May 10, 2014
    img:http://img.cogsci.nl/uploads/536ea257348...
  • Xtreme
    Xtreme May 14, 2014
    Thanks guys for your support.
  • Xtreme
    Xtreme May 14, 2014
    @ Paul, I did the same as you told me and the only thing I got was the screen light was blinking. Nothing is shown on the screen and no buttons are working...
  • 637 Answers
Red goes to ignition switched wire and yellow is for memory so it needs constant supply voltage.
Posted on Jun 19, 2014
DrElectrics
  • 199 Answers
SOURCE: car radio /clarion db315 pro audio
try this
http://www.ehow.com/how_5829_wire-car-stereo.html
Posted on Feb 18, 2008
  • 4102 Answers
SOURCE: re sent wire diagram gat all messed up
Hi
have we spoke before in previous post?
the red can go to any 12v live peramanent such as wire to clock or other item that has power with ignition off and the same with the yellow if your putting these to the same permanent live say from clock you can join these to together red/yellow to red on clock
the black can go to any metal or neg wire.
This should then have your device working the only problem im looking at for you now is the pink wire as this stops you using the device whilst driving as it goes to handbrake but i need to find out if its live or negative.
You could just wire the red/yellow to live and black to earth then see if it switches on and works if not then let me know and ill see about the pink wire ok
Makes sure you use inline fuses on the live wires so as not to short the device out.
Make sure you know what is permanent live to put the yellow/red wire to.
It doesnt need to be ignition it only says this so you cant use it with ignition off but you can wire it into any live feed from clock or switches so its up to you what to wire it to its just the pink wire im concerned about.
PINK: does it tell you to put it to live or earth on handbrake switch?
let me know ok
Posted on Apr 21, 2008
  • 14 Answers
SOURCE: need wiring diagram
This is a general wiring diagram for most head units.
Should be what you're looking for.
Posted on Dec 17, 2008
  • 14 Answers
SOURCE: DEH-P80MP need wiring/color description
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/103539332INSTALLATION%20MANUAL%20DEH-P80MP.pdf
Installation guide for your model with wiring diagram.
Hope this helps.
Posted on Dec 25, 2008
Installer1
  • 97 Answers
SOURCE: jvc kd-sx750 head unit has power but puts out no sound
bro to me it sounds like your radioi is bad you got everything hooked up right to get sound from it maybe the ant. hooked up but you should still get sound thats why I say the amp in the unit is bad!
here a little help: red: ignition when the key is turned on
yellow or orange: all time 12v
black: ground
blue: amp turn on, or auto ant.
Posted on Aug 20, 2009
Testimonial: "thx alot i was think that the radio was bad i got it off creiglist for 25 bucks i guess the deal was to good to be true "
Clarion NZ500 nothing on screen
Clarion ebrake safety bypass without using toggle switch
Clarion has a brake safety wire that has to switch from open to a ground every time you turn on the unit so therefore you cannot just ground the brake wire it has to switch to ground every time you turn on the radio
Aug 22, 2017 | Clarion NZ500 Car Video Player
Installation Guides
Click on Clarion (below FIXYA)on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, voila! u hv your manual on line.
Nov 26, 2007 | Clarion ARX7470
I have a Clarion M 475 radio that came in a used boat I just bought and it is not hooked up. I need to know what the different color wires go to. Do you have a wiring diagram I can down load? Don
yellow 12v battery
red 12v accessory
black earth
blue/white amp rem
blue power antenna
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
green rear left +
green/black rear left -
purple rear right +
purple/black rear right -
this is the standard wiring for clarion cd players
May 17, 2010 | Clarion M475 CD Player
Clarion xa311 wiring diagram. not hing about were
You can download it from Clarion website. Look for installation manual.
Apr 11, 2010 | Car Audio & Video
I installed clarion in dash dvd and i cant get
Hi
Have you checked the RED wire for a 12 volt feed when ignition is switched on and also the YELLOW wire for a permenant feed?
Jul 08, 2009 | Clarion Car Audio & Video
Clarion DRB3675 cd and radio with clock
to set the clock just press and hold the DISP for 5 to 10 seconds, button while the clock is is displayed. When the the time starts flashing, use the DISP button to adjust the time. When you have the correct time, just hold the button until the clock stops flashing and you're done.
Aug 05, 2008 | Clarion DXZ665MP CD Player
Clarion vrx755vd no wire
Hi
its dificult to wiring your unit for a novice man! that What is call Convertion! If you have experience in electronics maybe i can tell to you how to wiring that in properly!
thanks!
Jun 18, 2008 | Clarion VRX935VD Car DVD Player
Robert
The best solution is to google Clarion and serial # to deck, also include manual. EXAMPLE: Clarion VRX935VD Manual....And in that manual there will be a wire connection page. It will show you the best possible way to install the deck into your car.
Jun 12, 2008 | Clarion VRX935VD Car DVD Player
Clarion radio wiring diagram
please help what wire goes where?? need a wiring diagram or manuel to install. clarion xmd1 marine am fm cd player
Mar 18, 2008 | Clarion DB245 CD Player
WIRING COLOR CODE
Yellow - +12V Constant Power Red - +12V Switched (accessory) Power Blue - Power Antenna Blue/White - Amp Turn-on White - Left Front Positive Speaker Wire (LF+) White/Black - (LF-) Gray - Right Front Positive Speaker Wire (RF+) Gray/Black - (RF-) Green - Right Rear Positive Speaker Wire (RR+) Green/Black - (RR-) Purple - Left Rear Positive Speaker Wire (LR+) Purple/Black - (LR-)
Apr 07, 2007 | Clarion DRX5575
Car Audio & Video Logo
172 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
