Question about Whirlpool WTW4800BQ White-on-White 3.6 cu. ft. Top Load Washer with Care Control Temperature Management System
How do i release top load cover lock? - Whirlpool WTW4800BQ White-on-White 3.6 cu. ft. Top Load Washer with Care Control Temperature Management System
  • 89 Answers
One way is
Posted on May 11, 2014
Removing lid lock switch on cabrio washer
Hi
To get to the lid lock you must raise the cover To raise the top you unscrew the top screws in the back, ( the ones that hold the smaller galvanized piece of sheet metal behind the control panel). There is also two clips on the sides of the back with 2 screws in each, remove the top ones. You should be able to slide the cover forward while lifting. It will hinge on the 2 clips. Then prop the cover to keep it open. Under the cover are 2 screws that hold on the latch. Under the cover towards the back there are 2 spring clips that hold down the top user control panel. Squeeze them to release the panel. Follow the wire from the latch to the motor control module and unplug the plug. Remove the latch. Reverse to reinstall a new one.
Robert
Oct 26, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a Maytag Neptune TL, it won't unlock and still shows 22 minutes left to wash...I just would like to get in unlocked for now, and take my clothes out...Thanks you!
If the Lid Locks won't release you can release the Washer top from the base. You need a putty knife and press in to release the.
Un plug the washer from the 120VAC outlet.
Insert a plastic putty knife in line with the lid seam and
push in to release catches on the left and right side.
Yhe top cover is hinged at the rear.
See Pic fpr putty knife insertion point;
Ypu can get the Service Manual for here Neptune TL Washer FAV6800AWW
5 post doen in the sticky.
Apr 03, 2011 | Maytag Neptune FAV6800AW Top Load Washer
HOW DO YOU REPLACE THE DOOR LOCK I NEED TO KNOW HOW TO GET AT THE LOCK THE WASHER ONLY LOCKS IF YOU HOLD IN ON THE TOP OF THE DOOR
Disconnect power then open the dispenser cover and remove the four screws securing the dispenser bezel to the top cover then lift the bezel off. The top cover with the dispenser bezel off can be lifted to the rear of the machine to access the door locking mechanism, but you have to remove the front panel first.
Open the machine door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel then move it away and set it aside.
The top cover is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket.
Swing the bracket to the outside and unhook it from the slot in the top cover lip.
Open the door then lift the front of the top cover and tilt it toward the rear of the machine. The door locking mechanism can now be removed and replaced.. Reinstall the top cover and the front panel by following the removal steps in reverse order.
Jan 19, 2011 | Maytag Neptune MAH5500B Front Load Washer
How do i unlock a maytag neptune tl?
Disconnect the machine from power source then insert a plastic putty knife or similar tool in line with the lid seam and push in to release catches on the left and right side. The top cover can then be hinged up.
Once the top cover is raised, remove each of the 1/4" hex-head screw attaching each lid lock to the top cover.
Release the lid locks from the lid then reinstall them back into the top cover. Take the opportunity to visually check the lid locks and the harnesses for any obvious sign of degradation such corrosion and broken wires.
Sep 26, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My machine has the door lock light on and wont start, the door is locked as i have to press the release to open it!
Remove the top cover, and release the door catch from inside the washer, you will probably need a screwdriver or similar to do do this.
You will need to replace the door catch and spring, and possibly the door lock, as it may break when you force the door open.
Thank you !!
Jun 26, 2010 | Hotpoint Aquarius WD63 Front Load...
Maytag front load washer Neptune MAH5500B codes FL and DO
There is an emergency access cord provided for the manual unlocking of the washer door and can be accessed by removing the dispenser bezel. Open the dispenser cover and remove the four screws securing the dispenser bezel to the top cover then lift the bezel off. Once the bezel is removed, look for the nylon cord near the door lock assembly through the opening left by the dispenser bezel. Pull the cord away from the door lock assembly to pivot the mechanical opener and push the locking lever into the open position. Open and close the door several times then start a new cycle.
Check the door lock assembly if the problem persists and replace it when necessary. Disconnect power to the washer prior to servicing to avoid the risk of electric shock.
Access to the door lock assembly requires the removal of the front panel, dispenser bezel, and lifting of the top cover.
Open the washer door and remove the two screws securing the door hinge and the front panel to the front shroud assembly. Do the same to the two screws on the opposite side of the door opening.
Disengage the front panel posts from the clips located on the face of the cabinet by grasping the upper part of the front panel posts and pressing in on the outer edges then twisting it inward. Once the front panel posts are released from the cabinet, tilt the front panel away from the cabinet and remove it.
Remove the two 5/16" hex-head screws securing the two top cover hold down brackets; one on each side. Swing the brackets to the outside to unhook it from the lip of the top cover then lift the top cover to expose the door lock assembly. Prop up the top cover to prevent it from falling back into position while accessing the door lock assembly.
Disconnect the wiring harnesses from the door lock assembly and the two mounting screws then rock the top of the assembly forward and lift it off the front shroud assembly.
Clean the wiring terminals and the connectors then reseat the connectors several times. Replace the door lock assembly when the problem is not resolved.
Install the new door lock assembly in reverse of the steps given above. Review the steps thoroughly for easy reassembly of the washer. Make sure the wiring harnesses are properly and firmly seated to the door lock assembly terminals. The door lock assembly is part number 22004435.
Mar 22, 2010 | Maytag Neptune MAH5500B Front Load Washer
I can't get the washer to unlock. The cycle is stuck and I think the load is unbalanced but I can't get the washer door electronic lock to open even after I turn the washer off and unplug it
Manual Door Unlocking Procedure for Maytag Neptune Top Load Washers
  1. Safety first. Unplug the machine.
  2. Insert a plastic putty knife blade in the front edge of the machine between the top cover and the cabinet and in line with the lid seam on the left and on the right.
  3. Push in to release the latches holding the top cover to the cabinet.
  4. Lift the front of the top cover and release the lid from the lid locks.
  5. Disconnect the wiring harness from the lid locks. Clean the terminals to ensure good connection.
  6. Reconnect the lid locks wiring harness and push the top cover back into the cabinet until the latches lock up.
Please let me know if the problem comes back for further troubleshooting and repair guide.
Jan 24, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune stacked front load MLE2000AYW
I'm trying to remove the top cover in order to relace one of the fins inside the drum. The screws came loose and let go. I'm struggling to get the top off. Which screws in the from need removed to release the front? Thanks.
Jul 13, 2008 | Maytag LSE7806A Top Load Stacked...
Neptune front load washer
Look for screws on the top cover, normally behind the machine. Take off the wall plug before handling the thing........
Nov 03, 2007 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool WTW4800BQ White-on-White 3.6 cu. ft. Top Load Washer with Care Control Temperature Management System Logo
94 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
