Question about Krell Audio Players & Recorders
Krewll showcase processor right channel noise is coming after one hour
  • 42 Answers
Chances are that you have a "Leaking" capacitor in the final stage.
Time for the repair shop :(
Posted on Jun 14, 2014
Crackling noise all channel when i change 110v to 220v
Sound as if you have a low voltage, check for 220 v if its ok, then you have a current problem, the higher the voltage, it will be less current flow. Hope its not a flaw on the 220 v side
Dec 20, 2013 | Krell Showcase 5 5-Channel Amplifier
Getting a lot of noise from new Aphex Channel Master Preamp how do I fix this? I was using a Neuman TLM 103 mic and just recently switched to a Rode Procaster mic but still plenty of noise. I'm sure...
My thought is that this is a gain issue. Too much somewhere, and not enough somewhere else. Try experimenting with the input gain on the unit, and your mixer until you can reach a better noise floor. Otherwise, some units are noisier than other brands inherently. But experiment and see what you come up with. Also check for the +4 or -10dB switch. If there is one, it may be set incorrectly.
Apr 25, 2013 | Aphex Channel-Master Preamp and Input...
I have a Static noise coming from the right channel of my mixer. I hear it coming out the right speaker as well as the right ear of my headphones (jack). How can I fix this?
That sounds like a bad connection but it can also indicate your mixer has a problem. If it occurs on all channels it is the mixer, if only one then the problem is in the input. Check your cables, they are a big culprut in problems like this.
Jan 08, 2013 | Stanton SA-5 DJ Mixer
Main menu screen won't stay up on my krell showcase
If the main menu comes and goes off then it is possible that there is a fault in the processor memory. Try and reset with the given code- refer to manual, if not switch off set for about 6-12 hours and press down the panel buttons to drain off all residual voltage . this might help to reset.
Jun 06, 2012 | Audio Players & Recorders
I have answered this fault earlier , please check this out
Jun 06, 2012 | Krell Showcase Surround 8-Channel...
How to connect effects processor to mackie 1602 mixer
Should be an Aux 1 or 2 output jack on the right side of the mixer. You can come out of the 1 or 2 OUTPUT jack to the input on your processor, and then from the output of the processor to Effects return or to a channel input. By going to a channel input you can then blend the processor's signal with a slider into the sound system with the other channels, while adding tone if needed. By going back into the Effects return, you just blend it overall by adjusting the Effects return knob.
To feed the channels through the processor, turn the AUX 1 or 2 knob up on each individual channel you want to go through the processor. Make sure the AUX 1 (or 2 if you are using that) MASTER knob is turned up on the right side of the console, otherwise nothing will go to the processor. You should see the processors' input light showing signal, if not check your connections. Good luck
Feb 19, 2011 | Mackie 1402-vlz3 Compact Mixer - 120v
Left from speaker not working- Yamaha HTR-5940-6.1 channel
Redbird,
What do you have in the "multi channel input" jacks on the rear of the receiver? Those inputs Right, Left, Center, Surround R+L, and Sub are used when selecting 6 channel mode. They bypass the receivers surround processor board.
John W
Jan 10, 2009 | Yamaha HTR-5940 Receiver
Multi Effects?
Here's a run down of the 2488 effects. It should explain how to use them.......
Effects processors can be inserted into the appropriate channels simply by holding the required effect mode button and pressing the required channel selection button. When the effects are configured as eight channel insert effects, the processor can provide compression, de-essing or exciter functions (selectable independently in each of the eight installations).
If you only need four such insert effects, then you can substitute a single multi-effect processor for the other four. This multi-effect is most likely going to find its way into the guitar DI input, and offers a chain of effects starting with a noise-gate followed by either distortion or compression.
If you are happy to abandon channel insert effects entirely, then you can set up the effects block as a single send/return processor which provides somewhat higher-quality effects. Algorithms include reverb, pitch-shifting, delays, and so on, and are accessed by dialling in an amount of Loop Send from any appropriate mixer channels. There is no dedicated effects return channel as such, but the level of the chosen effect can be adjusted in the relevant control screen.
Full article at: http://www.soundonsound.com/sos/may04/articles/tascam2488.htm
Sep 03, 2008 | Tascam 2488 Portastudio Multitrack...
Drop out of left channel, Adcom GFA5802
It sounds as if there is a broken solder joint somewhere that slowly opens up with heat. The other possibility is that an input or driver transistor is dying. Since the whole channel is dying, I would guess the broken joint and/or dying transistor are near the very input of the channel.
A tech can very easily find the spot by playing the amp until it starts to die, then spraying small bursts of freeze spray, one component or area at a time, until the amp suddenly comes back to life.
Aug 13, 2008 | Adcom GFA-5802 2-Channel Amplifier
96 people viewed this question
Top Krell Audio Players & Recorders Experts
80stech
Josh Whitehead
Josh Whitehead
 Grubhead
Grubhead
Are you a Krell Audio Player and Recorder Expert? Answer questions, earn points and help others
