Question about Miller 907068 MILLER TRAILBLAZER PRO 350D KUBOTA DH905
D1105 kubota engine on generator overheating
After running for 35 min the engine overheat and shuts down
    President:
  • 1,723 Answers
Can you tell if it's really hot (water temp) ? Could be a bad sensor.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jun 26, 2009
How do I adjust the valves?
Most valve adjustments are usually pretty easy. What I would say to you is go to you tube and you will find how easy this really is they have a bunch of great vids on this subject. You also have look up your engine and get the valve clearance numbers for your particular model intake and exhaust and then get er done pal.... Good luck.
Oct 21, 2014 | Kubota Garden
Onan generator
Hello, I would check the valve clearance. If the valve clearance is too small, the valves can expand in length as the engine comes up to running temperature and lose compression in the cylinder until the engine cools back down and the process starts all over again
Aug 15, 2014 | Electrical Supplies
Why does my Kohler 7.3 generator start and runs great for about 5 min. then shuts downRestarts fine but shuts down seconds later. Upon removing rad cap, fluid is seen moving upon warm up. How do I...
change the oil to the correct specification first. As the engine runs the heat changes the viscosity and overheats or trips the oil alert switch. If its over 10 years old change the oil alet magnetic switch
Jun 12, 2014 | Kohler Electrical Supplies
Kohler 5E, initially water pump impeller no good causing overheat and shut down of motor (overheat switch killed ignition), replaced raw water pump impeller, heat exchanger stays cool, exhaust manifold...
You did not say what fuel you running the motor on??? It sounds like it may be LPG or Propane.... is so then it seems as though you do not have enough surface for evaporation...
heatman101
Jun 13, 2011 | Kohler Electrical Supplies
Hello... I got problem with my honda odyssey. For the past 3 days, if i start the engine, after 5 min the temperature will goes up to HOT and engine indicator light-up. I turn-off the engine and then start...
Your English is very good.
From what you have described, which is a rapid over heating of the radiator coolant fluid and therefore a hot engine condition, it would appear that the thermostat in the engine's cooling system is faulty.
If the thermostat is sticking in the closed or nearly closed position temporarily, there will be no flow or very little coolant flow between the engine and the radiator and the engine will overheat.
You have advised that after the engine is shut off , and radiator coolant fluid has cooled, you re-start the engine and drive the car without the overheating condition occurring again and the radiator coolant temperature is normal. This time there is no overheating because the thermostat is working normally.
You should have the thermostat replaced as soon as possible because allowing the engine to overheat can cause very expensive engine damage.
If you had a continuing overheating condition then I would suspect both the thermostat and the water pump. However as the overheating seems to be only temporary, and clears itself after you have shut down the engine and re-started it 10 minutes later (without further overheating arising) then I think you only have a faulty thermostat.
Please also check that the electric fans which draw air through the radiator are operating. These run on a temperature sensor and will switch on automatically once the radiator coolant fluid reaches a certain temperature and then switch off again when the fluid temperature reduces. You will hear them running once they start up. If these fans are not working the radiator coolant can quickly overheat in various driving and temperature conditions because there will be insufficient air flow through the radiator to cool the fluid. If the temperature sensor is faulty or has died, or if the electric motors running the fans are faulty, the fans will not operate.
I hope this helps.
Dec 18, 2010 | Honda Odyssey Cars & Trucks
Is it hard on diesel garden tractors run for short time? 45 mins-1hr? kubota gr2110 or 2100
Short runs are not hard on the unit. As long as there is oil pressure and the battery stays charged your not going to hurt it at all. Kubota diesels are very reliable.
Kelly
Feb 28, 2010 | Miller 907068 MILLER TRAILBLAZER PRO 350D...
Black and decker 18
i can only send the wiring by fax.
Jul 08, 2008 | Electrical Supplies
Miller 907068 MILLER TRAILBLAZER PRO 350D KUBOTA DH905 Logo
1,116 people viewed this question
Top Miller Electrical Supplies Experts
Craig Butler
Craig Butler
Robert Wooley
Robert Wooley
Lawrence Oravetz
Are you a Miller Electrical Supply Expert? Answer questions, earn points and help others
