Question about Panasonic Kx-tg2740 2.4 Ghz 2 Lines Cordless Phone With Two Wireless Handsets
How can a pair a wireless extensiin to my base phone?
My wireless extensions, kx-tga270s, do not link to base.
  • 147 Answers
See manual you must put it in the samme frecuency
Posted on May 10, 2014
Ringer
There is a section on setting the number of rings in the manual for the base unit on page 28. You can download it from here: http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Telephones/Expandable-Systems/model.KX-TG2740S
c:\documents and settings\bruce\application data\pixelmetrics\capturewiz\lastcaptures\2010-04-21_15-45-33-014.pngc:\documents and settings\bruce\application data\pixelmetrics\capturewiz\lastcaptures\2010-04-21_15-45-33-014.png
Apr 21, 2010 | Panasonic KX TGA270S Cordless Expansion...
I have a Pansonic kx-tga270s that is registered to a base I do not have. Is there a way to deregister it.
you dont need to deregister it if you have not registered all 8 hand sets with your base unit. Just register the new one and the base will assign a new # for this new. I you had registered 8 hand sets with your base already, you need to remove(deregister0 one handset from your base(it can take only upt 8).
If it still not registering please deregister as follows:
on the base unit, press program, them mute, then enter 335#, then enter the handset number you wish to deregister.
after deregistering try to register your new hand set.
Nov 19, 2009 | Panasonic KX TGA270S Cordless Expansion...
Need to clear out a used kx-tga270s handset
press function, initial setting, registration, deregistration, enter 335(deL) and then press Ok (right button on screen).
Once that is done press mute on the base unit and Ok on the hanset (right button on sreen)
Mar 28, 2009 | Panasonic KX TGA270S Cordless Expansion...
TOO FAR FROM BASE
Hi! This may cure your problem!
Re-registering the handset
If “No link to base. Move closer
to base, try again.
” is displayed
even when the handset is near the base
unit, you may need to re-register the
handset to the base unit.
Important:
LMake sure the base unit is not being
used.
LHave the handset and base unit near
each other when re-registering the
handset.
LKX-TG5422 and KX-TG5423 only:
Confirm the extension number of the
handset which has lost its link to the
base by placing the handset on the base
unit or charger.
If you accidentally assign another
handset’s extension number to it, the
other extension will stop functioning.
1 Handset:
Press {MENU}.
2 Scroll to “Initial setting” by
pressing {V} or {^}, then press {>}.
3 Scroll to “Registration” by pressing
4 KX-TG5421 base unit:
Press and hold {HANDSET
LOCATOR
} until the CHARGE
indicator flashes.
KX-TG5422 base unit:
Press and hold the handset locator
button that corresponds to the handset
you want to re-register ({HANDSET
LOCATOR
1} or {HANDSET
LOCATOR
2}) until the CHARGE
indicator flashes.
Below is a link that will take you to the instruction manual for your phone.
http://www.phone-manuals.com/panasonic/KX-TG5422M.shtml
Hope this helps! Hal
Feb 27, 2009 | Panasonic KX-TG5422M Cordless Phone
Hanset ringer off line
Hi - You can download the manual from the link below:
kx-tga270s
Please update the question & let us know if the information given was useful to you - Good Luck!
Jul 05, 2008 | Panasonic KX TGA270S Cordless Expansion...
How do I add an extension handset to my current config?
IF it was a used handset it was likely registered to another base. I just switched bases (1line to a 2 line base). I had to "deregister" the handsets from the old base. I am not sure if you can deregister if the old base is not present? With the old base plugged into power I hit the "function key" at the bottom left of the handset and scrolled down to initial settings. Under registration is "deregistration". I selected that and it put the handset back to its default out of the box. Then simply hit the mute button on the New base and OK on the handset. Worked for all 5 of my old handsets.
Hope this helps
Jan 27, 2008 | Panasonic KX TGA270S Cordless Expansion...
How do you get the KX-TGA270S apart to replace the Antenna
Real easy... remove the battery and you'll see 2 screws. then start peeling the phone in half from where the screws were.. the phone may seem like its breaking but it does snap apart... then you will needs a soldering iron to replace the antenna..
Nov 13, 2007 | Panasonic KX TGA270S Cordless Expansion...
The phone ( sub-unit) links to the base on and off from time to time. How can I do ?
Sounds like the RF (radio frequency) module may be bad. If your battery is really old it could also be the problem, especially if the problem is more likely to happen after the phone has been off the charger stand for some time.
May 02, 2007 | Panasonic KX TGA270S Cordless Expansion...
Panasonic Kx-tg2740 2.4 Ghz 2 Lines Cordless Phone With Two Wireless Handsets Logo
80 people viewed this question
Top Panasonic Cell Phones Experts
ray gallant
Are you a Panasonic Cell Phone Expert? Answer questions, earn points and help others
