Question about Cuisinart CSB-77 SmartStick Blender
Attachment stuck mixing attachment (the top part that attaches to the hand wand) will not release. worked fine; then after using the mini processor attachment, it will not release. Tried putting it in the sun as one "expert" recommended. That did NOT work.
  • Jeanne Rothenbuecher
    Jeanne Rothenbuecher May 10, 2014
    I had a very difficult time understanding what was written due to misspellings and poor english.
  • 147 Answers
Try to rotate top part while you pushed it down with two hands, somme one must help you to handle basement with forces in oposite direction, work smoth dont give too much force in the samme time or you are going to broken top part, put force in ascending
Posted on May 10, 2014
Any ideas how I remove both the mixing bowl & blade that won't release from my hardly used (maybe 10x's) Kitchen Aid Food Processor?
It sounds like the blade has become jammed on the motor shaft sleeve. You will be up for a new blade and motor shaft sleeve to sort that out. They are not expensive and it is the only proper fix for them. If you replace nothing it will happen again pretty much straight away and if you only do one the other damaged part will wreck the new part. To solve the not turning on problem which is a separate issue it will very likely involve replacement of either the bowl or the lid. One is as likely as the other, I have both parts in stock so I try one or the other to decide which one is the problem. Getting the blade off is a real chore, I have a small chain (with welded links so very strong) I put a couple of turns around the big blade shaft and fix it there with a shackle. It's about 2.5 meters long so I attach the other end to the leg of my bench and accelerate the motor unit away from the bench. The chain comes tight and shocks the blade off. I then drill a hole through the motor shaft about 8 mm from the top, attach the chain to that with a shackle and shock it off just like the blade. New parts now and job done.
Nov 20, 2015 | KitchenAid Kitchen Aid KFPW760WH - 12 Cup...
Two buttons are stuck in on my kitchen aid blender.
I have been searching for an answer to this same problem. My chop and mix buttons were stuck and I was getting no power or blinking lights. After finding no help on-line, I decided to take it apart and fix myself. It was easy and it worked!
1. Take the bottom of the mixer off by removing the rubber foot pads and remove the exposed 4 screws.
2. Remove the 3 sets of wires that are attached to the inside panel with clips. Very easy to remove, just squeeze at the base of the clips and pull up.
3. Remove the 2 screws holding that panel in place and gently lift off.
4. Remove the panel found under the top panel by also removing 2 screws. When you flip this panel over you will see what operates the switches.
In my blender the black plastic nubs that push against the buttons that were stuck and got twisted off kilter so they were not resetting properly. I just put a small screwdriver in there to try and straighten them as much as possible. All of these steps will be obvious as you disassemble the blender.
5. Push on the back of the buttons that were stuck to get them unstuck before reassembling everything back together.
I was surprised how easy a fix this was and how obvious what the problem was when I opened the blender up. No soldering or fancy tools needed, just 5-10 minutes and a phillips head screwdriver!
May 21, 2013 | KitchenAid KSB560 5 Speed Blender
My Braun MR5500BC Multiquick professional handblender is now not working but I still do have all the accessories still intact. Is it possible to buy the motor part of the blender only?
I have a Braun Vario Model 418 hand processor - motor works fine but when attached to the blender, the blender shaft vibrates - if you look into the inside of the blender, the shaft is shaking - may be some support is missing. Can any one advise what can be done.
Jaya
rkayrjay@yahoo.com
Sep 15, 2010 | Braun MR 5550 M HC + BC MultiQuick...
The chopping disc won't attach to the wand.
There are two grooves in the C blade which may be clogged up with food residue. What you need to do is get a sharp knife and score the two grooves to remove the residue, then the blade should have a better chance of staying on the stick.
The C blade is the one you use most, so that's why it would be having the problem. You probably don't have as much residue built up on the grooves of the Aerating or Blending blades.
Apr 06, 2009 | Bamix Deluxe Handheld Blender
Need to order parts for food processor for stainless steel blende
I neede a new blade unit for my phillips smoothie maker, I just googeld the model number + spare part and was redirected to the websites! Eventually you fine it!!
Feb 20, 2009 | Ultrex 834-334 Die Cast Work Top Blender
Cuisinart DFP-14 Series does not start
First, do a motor test by removing the work bowl completely and using a pen to press in the grey button on top of the base (with the food processor plugged in and turned on of course), toward the back. If the processor spins, the motor is still good. At that point, I would inspect the work bowl pieces, lid, pusher assembly, etc for cracks/damage. If all appears well, insert ALL the pieces back into place and try again. For the DFP-14, remember: handle faces front, feed tube faces back, and metal element on back of pusher faces back of processor. Connect the pieces separately - if you try to put the work bowl on with the lid and pusher already attached, it will not always lock properly. If even one piece is out of place, the processor will not spin.
If it no longer spins, the motor has a problem.
-Tha Mp3 Doctor
Nov 17, 2008 | Blenders
Attaching top container to bottom tub.
Place food processor attachment on base
Put work bowl on gear collar with left slot just to the left of the tab on left side, slide until tabs click
Place work bowl lid on top of workbowl with tabs slightly to left of work bowl handle - slide into place until it clicks
Nov 13, 2008 | Cuisinart BFP-703 Blender
Need new product
I have a brand new, never used (parts still in plastic, but no box) ULTREX Kitchen Preparation Center model 14008- Blender-Food Processor-Fruit Juicer that you could buy.
Nov 06, 2007 | Blenders
Blenders Logo
430 people viewed this question
Top Cuisinart Blenders Experts
eyecam
ray gallant
richie46
Are you a Cuisinart Blender Expert? Answer questions, earn points and help others
