Question about Craftsman Garden
Why will MY MOWER WILL NOT KEEP A CHARGE.
I have a riding mower that the battery will not keep a charge. I have to stop mowing every 45 minutes to recharge the battery. What could my problem be??
  • 2 more comments
  • David Ogawa May 10, 2014
    Hi Paula Keating, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? What is the model number and brand?
  • Paula Keating
    Paula Keating May 10, 2014
    briggs and stratton model number is 4457770231. It is a new battery. i am also looking for a repair diagram for this model
  • steyr1 May 10, 2014
    http://www.youtube.com/watch?v=xzBKch7qH...
    Add a Commentsee this link and all other videos in page maybe you find a response
  • 147 Answers
Dead battery, if you have a nicd or metal hydride you must recondition them , if you have a acid battery you must change them , the samme for litium
Posted on May 10, 2014
Testimonial: "it is not the battery. have replaced them several times"
    ok can you put more information please?
  • 138 Answers
SOURCE: The charging system on the mower will not charge the battery up
The first thing to check on this machine is your voltage regulator try bypassing the voltage regulator to see if the alternator starts charging, it would be better to check your charging system with a voltmeter so that you know what the exact input and output in the electrical system.
Posted on Sep 23, 2009
  • 53 Answers
SOURCE: I have a 2003/4 craftsman riding mower, 23 hp
sounds like the stator under the flywheel is bad that is what charges the battery
Posted on Jun 11, 2009
  • 246 Answers
SOURCE: riding moweer wont charge the battery when mower
Hello davidturner:
>>From your Description it Sounds like the Stator/Charging Coils are Not Charging Correctly.
For Testing the Electrical (Charging) System on Mowers you can Use this Site Addy; http://faqs.custhelp.com/cgi-bin/faqs.cfg/php/enduser/std_adp.php?p_faqid=3438&p_created=1101706364&p_sid=4fQ1f8Xi&p_accessibility=0&p_redirect=&p_lva=3443&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NTEmcF9wcm9kcz0mcF9jYXRzPTAmcF9wdj0mcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1Wb2x0YWdlIGFuZCBTdGF0b3IgQ2hlY2s*&p_li=&p_topview=1 and Use the Link for AC Volts/DC Amps Meter Setting Chart. This is for Briggs Engines and Works Well for Kohler and Other Engine OEMs.
>>If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance. Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Happy.
>>Thanks.
Respectfully
John
Posted on Apr 21, 2009
SOURCE: battery not charging
you probably have a bad cell in the battery,replace it.
Posted on Oct 22, 2008
  • 61 Answers
SOURCE: The new battery on my Craftsman LT1000 18hp riding mower will not charge. Anyone have any ideas?
ck for blown fuse, ck for broken wire.
Posted on Sep 06, 2009
I am having to charge battery even though I have a new one on mower and When mowing the pto shuts off after 15 minutes
Charging circuit is bad. Probably the voltage regulator however there are other components that can fail. Thus may also be causing the pto to go out
Aug 01, 2016 | Cub Cadet RZT L50 50" 23HP Zero Turn Mower...
Battery drains and won't charge
I would start by having battery tested. If u remove it and take it to auto parts store they will test it for free. It could be that the battery will not hold a charge or your tractors alt. is not putting out a charge
Apr 04, 2014 | Garden
I have a craftman riding mower model 917-273381, It will run & cutt grass good for about 4 to 5 min & then stop. I`ve replaced carb kit & check the kill switch. It still doing the same thing.
How long does it have to sit before it starts again? Does it need to be jumped? If battery is old or not recharging you can loose power. I had a regulator go bad and mine would keep dying. I would charge the battery and mow for awhile then would die again. Have you checked battery and regulator?
Sep 07, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a series model 1018 cub cadet with electric mower deck. After mowing for about 45 minutes, I turned off the tractor for a few minutes. When I tried to restart, the battery was dead. I jumped started...
If you have access to an electric voltmeter, with it running check voltage at the battery. The engine should charge the battery and maintain system voltage so that the electic PTO will function. The electic PTO will not pull in if system voltage is too low.
Jul 08, 2011 | Cub Cadet Garden
My mower will not keep a charge very long. It use to keep a charge long enough to mow my front yard and back yard. Now I can hardly keep a charge long enough to mow half the front yard. It is 3 years...
Is this a battery powered mower?
If so, it sounds like the battery is dying. Batteries do have to be replaced, but 3 years seems like a short life. Ask your dealer before buying another.
Gary
Jul 05, 2011 | Ultra Garden
I don't kown anything about charging batteries! How do I carge a battery in a 2008 Husqvarna riding lawn more?
mille get yourself a cooler and put 8 cold beers in it. Put that cooler into the gap between the seat and the "dash" of the mower. Make sure your gas and oil are good. Have someone jump start your mower from a car and then you mow and drink and mow and drink until the beer is all gone. If the mower does not start from the battery the next day go out and buy yourself a new battery. If the battery and charging system are good then you do not have to charge it if it is being used regularly.
Apr 20, 2011 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
Mountfield 1228h ride on mower battery does not keep charge when mowing
had same problem,when u r setting in the sit open the hood of the tractor on the left side of the eng. u will see a square part bolted into the side of the up by the top it should have three wires coming out of it this is the rectifier which runs off the magneto on the eng. this keeps the battery charge but very expensive $57 had to order mine from craftsmans took 1wk
Mar 31, 2011 | Tecumseh Ov691ea 22 Hp 22hp Lawn Rider...
I have a troy bilt riding mower, 6 years old, 26
many of these units use the starter motor as the generator to re-charge battery. check voltage regulator & wiring.
Sep 28, 2009 | Garden
Pto stops working while mowing
is this by any chance a husqvarna or cub cadet/yardman? ran across this problem in all three. they use a cheaply made clutch that's prone to bearing failures. the clutch [not cheap, just cheaply made] needs to be replaced, the pto switch needs replaced AND the little relay under the dash - if you replace the clutch and switch and not the relay, it'll keep taking out the switch and that can get expensive in a hurry
Aug 24, 2009 | Garden
Mower will not start will make clicking noise. did start at for one minute
Your battery is dead. Replace it.
In the winter keep a smart trickle charger on the battery to prevent it from discharging. Lead/acid batteries lose 1% of their charge per day and are basically junk in 3 months. They have to be kept charged.
May 04, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
