Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
My Husqvarna riding lawn tractor starts but when I engage the mower, the mower wont work
It starts up okay, but when I engage the mower, it will not engage the mower, the tractor still runs, but not the mower.
  • 31 Answers
Sounds like a broken belt.or it has come off the pulley
Posted on May 10, 2014
  • 1 more comment
  • Al
    Al May 19, 2014
    That's a common issue with the seat switch broken or a wire unplugged. When you are sitting down it allows the engine to keep running but if you get off of the seat (only when the blades are engaged) the engine will stop. But when the blades aren't engaged the engine will run no matter if you're on the seat or not. Check the switch under the seat.
  • Al
    Al May 19, 2014
    Sorry I didn't see that the mower is still running. The suggestion on the belt sounds logical or check that the electric clutch is engaging, that's a common issue as well.
  • Lynn Cutler Jun 05, 2014
    check and make sure belt is still on the deck and in the correct alignment is this is the case the safety switch for the mower deck may be faulty
dgjtex
  • 405 Answers
SOURCE: I NEED BELT DIAGRAM FOR MY HUSQVARNA RIDING MOWER
http://www.usa.husqvarna.com/home.aspx try this out for your answers, I hope this helps you. MERRY CHRISTMAS!
Posted on Dec 23, 2008
lester482529
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
Posted on Jun 01, 2009
  • 95 Answers
SOURCE: Husqvarna Mdl YTH2448 Riding Mower - Electric PTO Not Working
It sounds like your charge system is not working. If you jump the battery the engine will run with a weak battery but the pto clutch needs a strong battery to stay engaged.Try this to test it,after you jump it leav the jumper cables hooked up and try to engage the blade clutch,if it runs it is either a battery that wont take a charge or a charge system not working. If you put a volt meter on the battery while the engine is running and the voltage is 13 volts the charge system is working and the battery is bad.
Posted on Jul 31, 2009
  • 9 Answers
SOURCE: 2007 Husqvarna Riding mower blade will not engage
Sounds like you electric blade clutch is bad. I just had the same thing happen to my exmark mower. I was cutting grass and the engine just shut down. It would not crank over. Checked the fuses and replaced one blown fuse. The engine wanted to crank over but it was locked up. I looked the engine over and seen that the bearing in the electric clutch seized up causing the clutch to melt.
Posted on Apr 25, 2010
Testimonial: "Thank you! That doesn't sound like an inexpensive solution. We appreciate your help, though."
SOURCE: Blades will not engage on Husqvarna riding mower.
I have a Husqvarna GTH2548 and the blades will not engage. It is free from all debrie
Posted on Sep 04, 2010
How do you lock differential?
The locking is automatic:
Husqvarna riding lawn mowers, lawn tractors, garden tractors
www.husqvarna.com/us/products/riding-lawn-mowers/
Husqvarna GroupThe available, electronic or automatic locking rear differential increases ... forHusqvarna lawn and garden tractors, you are ready for every season. ... Why use your ride-on mower only for lawn mowing, when it has the capability to do so much more. ...Kawasaki V-Twin engine; Fast hydrostatic transmission; Cruise control ...
Husqvarna Riding Lawn Mowers YT48XLS CARB
www.husqvarna.com/us/products/.../960430205/
Husqvarna GroupBy using this site, you agree to our use of cookies. Learn more. Got it. Close .... Wedeveloped our LS series yard tractors with the discriminating landowner in mind. Engineered for added ... Automatic locking rear differential increases traction while cutting wet grass or on slopes. ..... WORKING FAST WHILE STAYING SAFE.
Husqvarna Riding Lawn Mowers GT54LS
Dec 06, 2015 | Husqvarna Fast Tractor YTH24V48 48" 24HP...
My Husqvarna riding mower won't start. I was
Check to see if you left the blades engaged. There is a safety switch that prevents starting with blades engaged. Easy to miss, happened to a friend of mine last month.
If this really helpful, please rate.
Jul 11, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
The mower starts but the blade switch won't conect yth1542xp
Husqvarna uses an electronic clutch to engage the mower deck. When the clutch works itself out of adjustment it will quit working. Sometimes it will blow the 20 fuse and the tractor will continue to run, but the blade won't engage. When you then shut off the tractor it won't crank again until you replace the fuse. When you attempt to engage the blades again, the fuse will blow again.
Follow this link for a detailed description of the adjustment process:
http://www.lawnsite.com/showthread.php?t=164509&highlight=clutch+adjustment
Nick
Apr 22, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
I reversed polarity when installing new battery now mower wont start. Did I fry the mower or can I do something to get it to work?
Would like clarification. Is the engine turning over at all? Is the starter pinion engaging? The electric start circuit is totally separate from the ignition circuit and will not affect the running of the engine at all.
Feb 20, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Could be a broken belt, loose belt (stretched) or something is under the mower deck jamming the blades. (stick for an example)
Apr 14, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Blowing fuses
try unplugging the pto, starting the mower and then engaging the blades. If it still blows a fuse the problem lies in the mowers wiring. If not the problem is the pto. Hope this helps
Jul 13, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
371 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
