Question about Canon PowerShot SX 200 IS Digital Camera
Memory card locked
Bought a used Canon Powershot S2 IS put new batteries and a 4 gb sdhc Sandisk card and it reads memory card error Card locked....Any suggestions? Thanks
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Posted on May 11, 2014
  • 3 Answers
SOURCE: memory card error after inserting SDHC card on powershot A620
the a 620 only goes up to 2 gb no higher
Posted on Jan 28, 2009
t00nz
  • 4738 Answers
SOURCE: I put a brand new SanDisk SDHC 4 GB memory card in
I also own an A620, but unfortunately I also learned the hard way that SDHC cards are not compatible with this camera. The A620 was designed before the newer SDHC format came out, thus although they look exactly the same, your camera will never work with these cards. Your camera uses standard SD cards (2GB or less). There are some standard 4GB SD cards, but they are very rare these days, and costly.
Posted on Aug 06, 2009
videotransmi
  • 105 Answers
SOURCE: Cannon Powershot A540
A 4 gb memory card is beyond the capacity of your Cannon A540. It is too large. I would stick with a 1 gb card in that camera.
Posted on May 28, 2010
Obertelli
  • 3006 Answers
SOURCE: I am trying a new
Your fix is a very simple one. Your camera is only compatible with SD cards, and you're trying to use it with an SDHC card.
SDHC is a later technical development of the SD to allow larger capacity. Your camera was designed and made when SDHC development was still just a vague idea for the future. 512MB was all that your camera was guaranteed to work with as they were the largest capacity cards then available. You may wish to look at the user manual for yourself, page 170.
SD cards are available up to 4GB in theory, but in practice almost no SD device can go above 2GB, According to the MyMemory website your camera will accept 2GB SD cards (see details), but from experience even if it works you may find that the camera operation becomes very sluggish when the card gets more than half full. You are also likely to find that at the maximum capacity your camera is very choosy about which brands it will work with reliably. Staying at or below 1GB should ensure the maximum usability.
There is no way to update your camera to the newer standard as the SDHC card requires different internal hardware and firmware.
I hope that you've found my solution to have comprehensively answered your question, please take a moment to rate my answer.
Posted on Mar 08, 2011
t00nz
  • 4738 Answers
SOURCE: I have a Canon PowerShot A540 Digital Camera I got
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Please note that your particular model camera can only use up to 2GB standard SD cards. These are relatively inexpensive these days, and may be purchased on Amazon if your local store no longer carries them. There are also other common causes if the above didn't help, with troubleshooting steps for this problemlisted here.
Posted on Oct 01, 2011
New camera, Canon PowerShot A2300, I have not used it, yet. Just placed the new battery in after I charged it, and I put in the San Disk 8GB SDHC Card, and the camera says "memory card error". I ca
Normally, you can only insert an SD card one way. Try a different SD card or check to see if the SD card you're using has the "write protect" switch on. If that's not the issue try formatting the card in your PC and then format it in the camera.
Mar 05, 2013 | Canon PowerShot A2300 16 Megapixel Digital...
I have a Canon PowerShot A540 Digital Camera I got a new memory card it is a sandisk SDHC 8 GB but I am getting a memory card error message.... What can I do?
Oct 01, 2011 | Canon PowerShot A540 Digital Camera
I bought a brand new Sandisk 4GB memory card for my Canon PowerShot A520. The camera registers my other memory card just fine, but this card says Memory Card Error. I checked for locked position, and it is...
The 4 GB memory card is not compatible with the camera. It's a SDHC card (high capacity) and the A520 only supports SD cards. (The difference between the SD and the SDHC is similar to that of single layer and dual layer optical discs. Not all drives can handle both formats.)
Documentation for the camera is here: http://usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a520#BrochuresAndManuals .
I wish that I had better news for you.
Jul 30, 2011 | Cameras
I have a SanDisk SDHC Card class 4 4 gb and it won't work in my Canon Power shot SD630, I get a memory error that says card is locked, however card is not locked, what camera canI use this card in?
The SD630 works with MMC and SD cards, 2GB or smaller. It does not work with higher-capacity SDHC cards.
Your SDHC card can be used in any camera that accepts SDHC cards.
Feb 03, 2011 | SanDisk 4GB Secure Digital High Capacity...
I have a 4GB SD HC card that works well in my Powerhot SD750 but gives an error code "Memory Card Error" and "Card Locked!" on my PowerShot S2 IS. Is there a fix for this? Peter
The S2 IS uses SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. While you can use SDHC cards with the SD750, you will have to use SD cards, 2GB and smaller, with the S2 IS.
Oct 21, 2010 | Canon PowerShot S2 IS Digital Camera
Cannon Powershot A540 SanDisk SDHC 4 gb I insert the card and receive a memory card error. Can't format
May 28, 2010 | Canon PowerShot A540 Digital Camera
I put a brand new SanDisk SDHC 4 GB memory card in and it says "memory card error; card is locked".
Aug 06, 2009 | Canon PowerShot A620 Digital Camera
Menory card error
The problem is that you've probably got a SDHC (High Capacity) card which is not supported with the S2; it only supports SD cards (up tp 2G)
Dec 24, 2008 | Canon PowerShot S2 IS Digital Camera
Canon PowerShot SX 200 IS Digital Camera Logo
93 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
