Question about Streamlight Survivor LED Flashlight, by 90503
Find replacment switch
Find replacement switch
  • Aaron Totton May 10, 2014
    The switch in this light is very simple. It is a button that snaps a small metal disk that momentaily completes the circuit. I can't find anyone to supply the part though. Does anyone know where I can get a switch for the Streamlight survivor LED?
    Top Expert:
  • Streamlight Master
  • 41,875 Answers
Streamlight might be able to supply the part or information.
Posted on May 10, 2014
Replace broken power switch
didnt specify make and model --generic answer --unless it is a mother board [newer design ] unplug unit remove knob and where switch is housed unscrew the housing than unscrew switch retaining screws unplug connector remove switch and replace the following link shows how to replace different switchs
Replace Washing Machine Switch Yahoo Video Search Results
Jul 09, 2016 | Dryers
I have a gfci/switch and need a 4 wire instructions. As none of the diagrams match what i have.
What device are you replacing... a switch or a outlet?
1) If you are replacing a switch with 3 or 4 wires?
That is either a 3-way switch, 4-way switch, or a DPDT switch and cannot be replaced with GFCI
2) If you are replacing outlet with 4 wires, then it can be replaced with GFCI combo.
http://waterheatertimer.org/How-to-wire-GFCI.html#8
3) If you are replacing ordinary single-pole switch, then you can replace with GFCI combo IF the box has a neutral wire
http://waterheatertimer.org/How-to-wire-GFCI.html#6
4) You can install GFCI protection on any circuit by installing GFCI earlier in the circuit.
http://waterheatertimer.org/Basic-house-wiring.html
Gene
Oct 21, 2014 | Pass & Seymour 1595SWTTRWCC4 COMBINATION...
How do i remove and replace combination switch?
torx bits to remove column surround and same for switch
Jun 17, 2014 | 2003 Pontiac Grand Am Turn Signal Switch...
Stove element always on high
If the switch is bad the contacts in the switch are not breaking allowing the switch to regulate the power to the element. The switch will need replacing. unless you are replacing the switch with an exact replacement the wiring can be tricky. many times the company will replace the switch with a different manufacture and the terminals are not in the same location. This can make replacing the switch a bit of a challenge unless you are familiar with how the switch is wired. I would have a service person do this you could short out the new switch if wired incorrectly.
Mar 10, 2014 | Ovens
Cooling fan switch
It is not necessary to replace the thermo-switch when replacing the radiator. The switch can be replaced separately.
The fan switch is located under the sound box of the air cleaner. It is 2 pin connector. Pull the connector out by pressing the lock which attached to it and short the two pins with a thin auto wire temporarily. Switch on the ignition. The fan will become on. Drive it and see if runs hot.
If the temp reads OK, replace the fan switch. If the problem persists, diagnose the other issues which are concerned with the overheating problems.
May 07, 2013 | 2003 Honda Civic
Kexus ignition switch replace
To troubleshoot these issue, for ignition switch replacing procedure:---
Click the link below:---
IGNITION SWITCH REPLACING
It depends on vehicle to vehicle. But it's not very difficult on mot of cars to replace ignition switch. Basic theory of replacing ignition switch is same for all car models. -----
To replace ignition switch on your vehicle, I suggest you few helplinks with proper ignition switch replacing procedure. View its details and you can replace ignition switch on your vehicle.
Click the link below: ------
How to remove ignition switch on VW Car models?
http://schematicsdiagram.blogspot.com/2011/12/how-to-remove-ignition-switch-on-vw-car.html
How to replace Ignition Lock Cylinder on Acura Car Models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-ignition-lock-cylinder.html
Ford Taurus: Ignition Switch & Steering Column Replacing?
http://repairhelpcenter.blogspot.in/2012/06/ford-taurus-ignition-switch-steering.html
How to replace Ignition Switch on Acura Car Models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-ignition-switch-on-acura.html
How to Replace Ignition Switch on Chevrolet Caprice Classic?
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-ignition-switch-on.html
1995 Ford Taurus: Ignition switch not turning OFF?
http://repairhelpcenter.blogspot.in/2012/06/1995-ford-taurus-ignition-switch-not.html
Ignition Switch Will Not Turn Off?
http://schematicsdiagram.blogspot.in/2012/04/ignition-switch-will-not-turn-off.html
These will help.
Thanks.
Dec 06, 2012 | 1993 Lexus Es 300
How to replace ignition switch
It depends on vehicle to vehicle.But its not very diffult on mot of cars to replace ignition switch.Basic theory of replacing ignition switch is same for all car models.:-----
To replace ignition switch on your vehicle,i suggest you few helplinks with proper ignition switch replacing procedure. View its details and you can replace ignition switch on your vehicle.-------------Click the link below :----------------
1995 Ford Taurus: Ignition switch not turning OFF? http://repairhelpcenter.blogspot.in/2012/06/1995-ford-taurus-ignition-switch-not.html
Ignition Switch Will Not Turn Off? http://schematicsdiagram.blogspot.in/2012/04/ignition-switch-will-not-turn-off.html
These will help.
Thanks.
Nov 25, 2012 | Cars & Trucks
Remove/replace starter sloenoid
your Ignition Switch is bad here is how to replace it
The ignition switch is usually mounted to the steering column and is operated by a linkage rod.
NOTE On column-mounted ignition switches, don't confuse the switch with the lock cylinder and keys. The ignition switch is not normally visible. On some vehicles, the steering column support has to be removed and the column lowered to find the ignition switch. On others, the switch is accessible under the dash.
f32-17gif.gif The ignition switch is operated by the key switch. Courtesy of Ford Motor Company. To replace the switch:
  • Remove the ignition switch wiring harness.
  • Unbolt it from its position.
  • Bolt the new switch into position.
  • Attach the witing harness.
May 22, 2010 | Jaguar Vanden Plas Cars & Trucks
Replace ignition 87 4runner
It is probably better to replace the switch.
If it is anything like my 87 4Runner, the switch is pretty worn out anyway. I just replaced the switch wiring harness in mine.
Get a new switch and a Haynes manual at an auto parts store.
The manual describes how to replace the switch.
WAY too much to list here, but pretty simple really.
Good luck :)
Nov 06, 2009 | 1987 Toyota 4Runner
Streamlight Survivor LED Flashlight,  by  90503 Logo
125 people viewed this question
Top Streamlight Camping, Backpacking & Hiking Experts
Stan Ford
Tom Chichester
Are you a Streamlight Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
