Question about Dell Dimension 8400 PC Desktop
How to restore windowsxp on dell dimension 2100
  • Dell Master
  • 998 Answers
Why?
Posted on Oct 09, 2014
5 Suggested Answers
kisssmooth
  • 92 Answers
SOURCE: Dell Dimension 5100 computer with error
There are two ways,
1, If you still can access Windows, try to disable any backup programs, virus scanning programs or disk defragment tools. Try also to run a hardware diagnostics tool to detect any errors your hard drive might have. And run chkdsk /r to detect and repair any file system structural damage.
2, If you are unable to load Windows. Then you should try to access your ntfs partitions by making a ntfs boot disk with NTFS4DOS (freeware). You can download it from http://www.geekswhoknow.com/files/ntfsinst.exe You will need a floppy disk.
After you load the bootable floppy disk onto your damaged system, select either option one (1) or option three (3). If you selected option one (1), type chkdsk /r at the command prompt, and your problem should go away after the disk has been repaired.
Note! Unfortunately there is a chance that your partition is corrupt beyond repair and all of your data is lost. In that case, you need to reformat the partition to be able to use it again.
Additional information can be found at http://support.microsoft.com/default.aspx?scid=kb;en-us;Q228888
Posted on Nov 08, 2009
  • 13 Answers
SOURCE: IRQL_ NOT_LESS_OR_EQUAL
A repair install may be the easiest option.
You can follow these steps from Microsoft:
http://www.microsoft.com/windowsxp/using/helpandsupport/learnmore/tips/doug92.mspx
--T
Posted on Dec 09, 2009
lserni
  • 466 Answers
SOURCE: How do I restore my Dell Dimension C521? I am
You need the C521 recovery disk, from Dell. Set the BIOS to boot from CD and start the system.
If it gives you the option of "Complete Reinstall" or "Repair", choose Complete Reinstall.
If it does not, or if it does not work - i.e., it always reads the disk and tries to maintain as much data as it can, you need to first wipe out the hard drive; there are many "Disk Wipe" utilities out there. I'd suggest using a boot disk such as DBAN (www.dban.org).
Posted on May 07, 2010
  • 4044 Answers
SOURCE: how do i restore my dell dimension c521 to the way
This is done 1 of three ways depending on how your restore information is stored. 1. After you push the power button start pushing the F8 key and when you get the option screen select restore to previous or restore to factory settings. This method works if your system has a special restore partition still. If you received System Restore Disk insert the CD in the CD player and reboot the system. It will boot from the CD and present the Restore menu for you to make a selection from. Your third choice is to select System restore from the system tools sub menu under the Accessories menu in your program list and chose to restore to factory settings.
Posted on Jul 23, 2010
How do u reset a dell dimension 4800 computer back to factory setting?
1. Turn on the power
2. Press and hold "Ctrl" then press "F11" when the Dell splash screen appears during booting up
3. Click "Restore"
4. Click "Confirm". A progress window will appear to inform you how long it will take. A message will appear stating "The system recovery process was successful" when the process is completed.
Read more: How to Restore the Factory Settings on a Dell Dimension 4800 http://www.soyouwanna.com/restore-factory-settings-dell-dimension-4800-31875.html#ixzz1u3kXl9Pc
May 06, 2012 | Dell Computers & Internet
I'm trying to reinstall Windowsxp on my Dell dimension 8200. After putting the CD in and it comes up on the screen I click on install Windows XP and then a window pops up that says set up can not continue...
if your using the restore or re-installation CD that came with your DELL computer just boot off the CD.
it will reformat the computer and your data will be lost if you do a fresh install off the CD.
Do not boot into windows and use the CD from there.
make sure you set the bios to boot off the CD follow the instructions on screen to reinstall windows.
Apr 03, 2011 | Dell DIMENSION 3000 CELERON 2.4GHZ...
I need the Ethernet controller drivers for my dell dimension 4600
Click on below link and download drivers for your os.
click here
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 17, 2010 | Dell Dimension 4600 PC Desktop
IRQL_ NOT_LESS_OR_EQUAL DELL DIMENSION, WINDOWSXP HOME EDITION
--T
Dec 09, 2009 | Dell Dimension E520 PC Desktop
Dell Dimension 2100 wont boot from xp disc
you need to go into setup or your BIOS and set the boot sequence as 1- floopy, 2- cd 3- hard drive, exit and restart and your machine should boot up the xp cd.
good luck
May 20, 2009 | Dell Computers & Internet
Need to reboot my dell/windowsXP hard drive to factory settings
You have to put in the cd that came with your dell, then boot your computer. It will boot from the cd and give you an option to restore your factory condition. It will take around 1-2 hours for the process to complete.
Jan 29, 2009 | Dell Dimension 3000 PC Desktop
Install memory
No. Your Dell Dimension uses PC-2100 type memory. Your Dell Dimension can support up to 1GB of memory. For optimal performance install the maximum amount of memory in each socket. Your Dell Dimension 4500 has 2 banks of 1 socket each for a total of 2 memory sockets.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Jan 25, 2009 | Dell Dimension 4500 PC Desktop
Dell Dimension 8400 PC Desktop Logo
32 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
