Question about Samsung SMH1816B Microwave Oven
I turned on microwave. lost all power after a few seconds. outlet has power
    Prodigy:
    An expert who has answered 500 questions.
  • 547 Answers
First, check to make sure you have 120 V at the outlet it's plugged into. If you do, then the most likely cause would be that the main fuse has blown. It is inside the case, usually near where the power cord enters the cabinet. If it is blown, visually inspect it to make sure it hasn't been getting hot - melted solder near the ends is the usual tip-off. If it has been heating up, the fuse holder may have to be replaced as well as the fuse.
Posted on May 10, 2014
No power to microwave
Hello
Check the Power Cord
Verify that the power cord is properly connected the outlet; the plug might have been removed to make way for another appliance. Do not connect the microwave to an outlet via an extension cord or plug adapter; the oven must be directly connected to an outlet.
Switch the Outlet on
Turn the outlet on, if possible, using the switch on the wall behind the counter or on the plug itself. Some microwaves have a separate power switch that must be in the correct position before you can begin cooking.
Reset the Oven
Unplug the oven, wait a few seconds and reconnect the power. A power surge could have temporarily rendered the oven inoperable. The oven should start up as normal when you connect the plug to the outlet.
Check the Fuses and Breakers
See that the fuse or breaker protecting the oven's circuit is still active. Replace the fuse if it has blown, or reset the breaker to restore power to the oven. Stop using the microwave if it repeatedly blows fuses or trips breakers.
Oct 04, 2011 | Microwave Ovens
Microwave does not work nothing on the control pad work the pad just says se
Hello
Check the power supply. Make sure the microwave is firmly plugged into a working electrical outlet and that your wall outlet is active if your home uses outlets controlled by a wall switch. Check your home's fuses or circuit breakers to ensure they have not been tripped. Without power the microwave will not respond to any input.
Make sure the parental lock is inactive. Some ovens, like the one shown in the image above, feature a keypad lock to prevent children playing with the controls. Most keypad locks can be cancelled by holding down a button or combination of buttons for a few seconds.
Make sure the door is firmly closed. Some microwave ovens will not allow any control panel input if the door is open.
Remove the microwave from the power, wait 10 seconds, then plug it back in. This will reset the microwave oven if there is a temporary problem with the software.
Press the "Stop/Cancel" button several times to cancel the current operation and return the microwave to standby mode. Re-enter your cooking instructions using the keypad as usual.
Oct 04, 2011 | Maytag Microwave Ovens
I just turned on the microwave (samsung) and it started for a second then turned itself off and now it is doing nothing.....
HELLO.
This is the step by step solution.
Check if there is live power on the outlet.
Make sure the microwave plug is fixed properly on the outlet.
If the problem is not solved,then change the fuse placed behind the microwave that is used to control power suppl to the microwave.
Thanks.
Sep 19, 2011 | Samsung Microwave Ovens
Model 565.60512000 manufactured 3/2000. there is a L besides the time. I have lost the manual so do not know how to unlock. Instead of seeming locked, I can enter cook time but then the microwave turns...
HELLO.
The problem with your microwave's touch pad needs some simple troubleshooting steps to rectify the problem.
1 Check the power supply. Make sure the microwave is firmly plugged into a working electrical outlet and that your wall outlet is active if your home uses outlets controlled by a wall switch. Check your home's fuses or circuit breakers to ensure they have not been tripped. Without power the microwave will not respond to any input.
2 Make sure the parental lock is inactive. Some ovens, like the one shown in the image above, feature a keypad lock to prevent children playing with the controls. Most keypad locks can be cancelled by holding down a button or combination of buttons for a few seconds.
3 Make sure the door is firmly closed. Some microwave ovens will not allow any control panel input if the door is open.
4 Remove the microwave from the power, wait 10 seconds, then plug it back in. This will reset the microwave oven if there is a temporary problem with the software.
5 Press the "Stop/Cancel" button several times to cancel the current operation and return the microwave to standby mode. Re-enter your cooking instructions using the keypad as usual.
Reach me for further assist.
Thanks.
Sep 06, 2011 | Kenmore 63652 Microwave Oven
We had an power outage and lost power for a few hours everything came back on but the microwave. I checked the outlet and checked the fuse still nothing. Is there anything that can be fixed?
Hello if you have no power at the outlet, you may have saved your microwave. If the outlet is dead go to your house electrical panel and reset the breaker or replace the fuse. if the outlet is live and the microwave still won't power on you will have to choose between repair and replacement. Definitely get an estimate before agreeing to a repair as microwaves are very inexpensive today compared to even a couple of years ago.
Nov 23, 2009 | Emerson MW8108P Microwave Oven
Lost Power in Frigidaire Microwave
without getting inside it , i would tend to believe its the inline fuse just beyond the wire harness.
Oct 03, 2009 | Frigidaire PLMV169DC Microwave Oven
Counter top microwave GE lost all power
As an owner of a GE WES model might want to look at this blog post.
GE Customer Service is here.
Good luck.
Dec 16, 2008 | GE Microwave Ovens
No power to Panasonic NN-S252 microwave oven
follow the incoming mains lead into the microwave their is a small pcb with a fuse their check this first
Nov 14, 2008 | Panasonic NN-S254BF Microwave Oven
Lost power suddenly
Could be; replacement fuses avail @ RadioShack or a similar place for a few bucks, so it's worth trying. Just remove the outer casing, look for the white plastic snap-on container (might say "FUSE" on the side). See this also:
http://www.partselect.com/microwave+replace-fuse+repair.htm
Jan 17, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Sharp microwave
If it died as soon as you hit the Start pad, it probably has a shorted high-voltage capacitor. If it died a few seconds after you hit Start, it may be a shorted high-voltage transformer. Can you describe in more detail what happened? Have you checked the outlet for power? Have you checked the fuse inside? I'm happy to help you.
May 14, 2007 | Sharp R-202EW Microwave Oven
Samsung SMH1816B Microwave Oven Logo
96 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
