I have a B60 Keurig, I had it for about 5 months now, lately when I put the Kcup in the Kcup holder then push the handle, I select the small cup for stronger coffee. It will drip for about a second then stop, I would open the handle reposition the kcup and close the handle again, then it start dripping again, but the small cup is no longer lit, instead the big cup is lit, it makes it a weaker coffee. Help has anyone have it happened to them. Thank in advance for your help.
I descaled the brewer and am still having problems- when the brewer says ready to brew and I hit...
(More)
I descaled the brewer and am still having problems- when the brewer says ready to brew and I hit brew the amount of water that comes through is not the same amount as should come through. THere is also water that drips through the line in the reservoir at the same time. What should I do?
the water doesn't come out through the needle- it seems clogged or disconnected and the water comes...
(More)
the water doesn't come out through the needle- it seems clogged or disconnected and the water comes out over the edges of the needle & coffee grounds housing
