Question about Frigidaire Affinity ATF7000E Front Load Washer
Ltf6700fs frigidaire affinity washer restarts itself
My 4 year old washer has started coming on by itself. We leave the door open when not in use. I have unplugged over night and when I plug in it happens again. I can do a load of laundry and when it finishes instead of going off it resets to 31 minutes and the lights start blinking and a faint beep sounds. The only thing I can do is unplug it again. Appreciate any ideas you may have. Thank you.
  • Janice Tarter
    Janice Tarter May 10, 2014
    I have been messing around with this for two days. And after posting the question it now shuts off! I guess good vibes from the site did it! Hopefully it lasts. If not, I will be back!
  • 30 Answers
I had similar problem two times and both times where the control module if you are handy it is easy to replace it is located right in front. There is a new replacement part # I hope it is and improve part, first time my washer was about three years old and I complain to the company and they paid for every thing(parts & labor) Two years after I had similar problem again I call again and this time they gave me the part "at cost" about $70.00 and send it to me in about 2 days. The part at Sears parts dept. cost about $160.00 Good luck RUDY
Posted on May 11, 2014
  • 26 Answers
Seems like the electronic timer and or board has a short or lets say malfunctioning. If it does it again, find out which board controls the timer. Most likely has two boards minimum or three.
  • 147 Answers
You knob programmer is short circuited , try to clean it first , but you may not be the case to do so, is need it a technician, second replace the programmer unit at all no other way
Posted on May 10, 2014
5 Suggested Answers
  • 7 Answers
SOURCE: Frigidaire Front Load Washer
It looks like the door switch was not making because the door is defective. Also the switch may just be bad.
Posted on Mar 08, 2008
SOURCE: Frigidaire Affinity Washer beeps & won't spin
The drain filter is clogged. I had the same problem. There is a filter inside the "drain boot" (black) that comes from the drum to the drain pump. Mine was completely clogged with money, lint, etc..
Posted on Oct 19, 2008
localwonder
  • 6784 Answers
SOURCE: my frigidaire affinity wont start
Yes, the original issue was the control from the beginning. the control is damaged and it cannot register the latch at this point. this is necessary and , it will fix the issue.
Posted on May 29, 2009
  • 5161 Answers
SOURCE: when i turn on my frigidaire affinity front load
The control lock feature has been activated. To toggle this off, press and hold Options and Select for 10+ seconds. There is a small padlock indicated in the middle of a line between the buttons that toggle the lock on and off. This feature prevents anyone from changing a wash program when in use or a child starting a cycle with the cat or another child in the washer.
The manual for most Frigidaire appliances are available here: http://www.frigidaire.com/manuals . Enter the model number and click Search. Frigidaire lists several models of the Affinity ATF7000E. The direct link to the operating instructions manual for the ATF7000ES0 is here: http://manuals.frigidaire.com/prodinfo_pdf/Webster/134602700ef.pdf . In this manual, the control lock is described on page 2.
I hope this helps.
Posted on Oct 30, 2011
Has a e62 error
Frigidaire Washer Error Code E62 - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Apr 4, 2012 - 10 posts - ‎4 authors Hello, We have a 6 year old Frigidaire front load washer model GLTF2940ES3. Up until now it's worked fine. The machine now constantly ... Frigidaire Washer error code 31
May 1, 2015
Frigidaire Affinity Front Load Washer Won't Start ...
1 post
Dec 4, 2013
Frigidaire washer E6E error
Jul 31, 2012
frigidaire affinity E62 error code
Oct 30, 2010
More results from forum.appliancepartspros.com
Oct 19, 2015 | Washing Machines
My Frigidaire Affinity washer stopped working in middle of cycle and shows E41 code.
Hello Shawn Smith - Typically error code E41 indicates that washer has detected that the main control board thinks the door switch is open. Try reprogramming the washer by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If it proves to be ineffective, contact a professional to move forward accurately and properly assist with the repairs.
Mar 03, 2013 | Frigidaire Affinity ATF7000E Front Load...
LTF6700FS - (affinity) front loader - door lock will not engage - latch looks fine and child safety feature is not on
Sheck the hinche if is twist or pull that the most comon problem. If is that, disconect the door ahd replace the hinche. If the hintch is OK sheck the lock set up if is of place. Some time is being forced to open or to close it and bend the lock clip.
Aug 11, 2009 | Frigidaire Affinity ATF6000F Front Load...
My frigidaire affinity wont start
May 29, 2009 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire affinity front load washer doesn't start
mabye there is something keepin the door open, thats usually why most washers dont start
May 11, 2009 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Door open error on frigidaire affinity atf6700 washer
hello, it sounds like you have a bad door latch that needs to be replaced if you need a web sight on were to order one let me know and i'll find the part for you.
Mar 29, 2009 | Washing Machines
I just bought a Frigidaire Affinity washer model #LTF6700fs about a week ago. Starting yesterday the washer stopped draining. We can hear the motor working to pump it but no water is draining. My...
perhaps not in that hose but in the pump housing just below it, quite possible that someting is jamming the imopellar preventing proper draining of water
Mar 18, 2009 | Frigidaire Washing Machines
Frigidaire affinity washer doesn't start
Try holding the 'options' & 'select' buttons together till the door lock button comes on. This is the child lock function. You can do it again for the lock to come off. Hold down for over 3 seconds
Please reply or rate.
Dec 01, 2008 | Frigidaire Affinity ATF7000ES Front Load...
My Frigidaire affinity washer doesn't start: the "door locked" button doesn't come on though the door is closed properly
If the washer fills with water, but will not start the wash cycle or spin, it is 1 of to things. the most common for frigidaire front load affinitys is the door lock assembly. I have had to replace numerous of these. if the door lock indicator is not on when it tries to wash, you need to replace the door lock assembly. if the door lock indicator is on, but wont wash, it is likly that you have a bad motor control board.
Frigidaire Affinity/dr error
dr code means door not closed
get some crc spray and spray into lock on machine
that will lube the workings and should fix problem
Mar 13, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
149 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
