Question about Ohmeda Ohio Care Plus Incubator
Anyone know what the E05 error on the Ohio IC incubator unit indicates?
Upon heating up the unit will send the alarm between 3-4 minutes from start and error code E05 will present in the display. The unit was supposedly working prior to transit/shipping.
What does area Error code E-05 mean on a Frigidaire front load dryer model # AEQ6000ES2
model aeq6000es2: the "e05" error code normally indicates that control board may need to be replaced or a stuck relay on the control panel. you can reset the unit by unplugging the dryer power cord for 5 minutes and then reapplying the power. if the problem persists then the control board or the control panel may need to be at fault.
Good Luck & All The Best, Justin McCartney
Dec 26, 2015 | Frigidaire Dryers
Maytag Maxima E05 & F06 error codes on washer
My F06 E05 error returns within a moment of clearing all errors. My Maxima has no tach line from the M to the MCU. MCU commo fault is a different error. So does anyone except Maytag really know what this error is? And Maytag only wants to send a service guy to bleed some money from you.
Oct 21, 2013 | Maytag Washing Machines
I have a Aqua Pro heat pump P130 with error code F5 does anyone know what that means
Error FS?
Unit has started defrost cycle and will reverse operation in 5 minutes.
If coolant has nor res=ached desired temp, unit will shut down and display FS
Other models:
FS can mean not enough water flow in cooling mode.
Mar 25, 2013 | Aqua Pro Swimming Pool Heat Pump 125000...
Error code e61
Identification
  • GE dryers use three-character codes that display on LCD screens. Every code starts with "E" and is followed by a two-digit number.
Power Failure
  • When your home loses power, the "E01" error flashes on the screen. Reset the dryer memory by unplugging the device, waiting 30 seconds and plugging it back in. The error code will disappear.
Thermistor Errors
  • Errors "E02," "E03," "E04" and "E05" are thermistor errors. The thermistor, when operating properly, reads the temperature of the dryer. Errors E02 through E05 indicate the thermistor must be replaced.
Effects
  • When there is an error with the door switch and sensor, the "E60" error code will appear. An unbalanced door will produce the E60 code. Try to close the door gently and listen for the click. If the error remains, the door switch may need to be replaced.
Control Board Errors The control board sends signals from the controls to the dryer. When this fails, errors "E61," "E80" and "E81" appear. Contact GE service or install a new control board for the dryer
Jan 15, 2013 | Electrolux Dryers
What does F61 mean
Hi Georgina,
F61 is an error code(protect error code in other brand) for panasonic home theater system. This will trigger if the unit gone to overload to avoid further damaged to other parts. This code is quite technical if your not handy with electronics. However I will say to you the common caused of this error code.
1. Output IC - this is the most common caused of the error code. Once shorts happened to this IC, it will trigger the error code. Exposure to high volume and/or running in the long time will caused this IC to shorts and produce an overload.
2. Shorted Speaker - if one of your speakers shorts, error code will appear also. This may isolate by disconnecting the speaker to the set and play the unit *****. If the symptom still there the fault came from the unit itself.
3. Shorted Inputs - inputs connector is also prone to shorts due to frequent bending and pulling. To isolate this from fault, disconnect all the inputs connected to the unit like the aux input, antenna, mic, etc.
4. Faulty power supply - once gone to out-of-regulation condition, the error code will appear to protect the most expensive parts from further damaged. Bad solder joints in this section is also to consider.
5. Faulty Fan and its circuitry - F61 will appear only after a minute of operation not upon powering on the unit. Check the fan if working or not...
I would advice you to send the unit to your local Panasonic service center and leave the expert isolate the symptoms.
Also, check if your unit is under warranty period, avail it because the manufacturer will fix it forfree.
Hope I helped you.
Good luck and have a great day!
Jdvillanueva
Jan 10, 2012 | Technics Audio Players & Recorders
My amplifier is geetting very hot and shutting off
Hi gordog239,
This symptoms indicated that your sound output IC was already shorted. It heats up while on operation but the heat depends upon the volume and the load speakers(normal operation). If the unit gone to excessive heat even the volume is set to min, this was a clear indication that the fault came from the output IC (mounted in the heat sink. You may confirm it by opening the cover of the unit and touch the heat sink.
Once confirmed that the heat sink gone to excessive heat, replace the output IC and all electrolytic capacitor around this section, this will solve the issue.
Let me know if you need further assistance.
Hope I helped you.
Have a nice day!
Thanks for using Fixya
May 23, 2011 | Car Audio & Video
Hi my panasonic sa vk90d is giving me an f61 problem when i turn it on
2. Shorted Speaker - if one of your speakers shorts, error code will appear also. This may isolate by disconnecting the speaker to the set and play the unit naked. If the symptom still there the fault came from the unit itself.
Also, check if your unit is under warranty period, avail it because the manufacturer will fix it for free.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
May 12, 2011 | Audio Players & Recorders
How hot does this heat tape get up too?
Sounds like you are trying to hatch chickens. The heat tape is designed to keep pipes from freezing, and will not be warm enough for an incubator. Try a heating pad or electric blanket, or if you are really serious, you could just BUY an incubator
Oct 02, 2009 | Easy Heat Water Pipe Heating Cable
I have a 1982 Evinrude 35 hp motor. After running it at tops for about 5 minutes, I go to trolling mode and in about 5-10 minutes in overheats. Steam coming from the water outlet holes. This happened 3...
My smaller johnson had a pickup tube in the housing. With your alarm you only know when it is too hot. You do not know how close you are to setting the alarm at full throttle; it can be running hotter than it should then too. I would drop the lower unit, pull the sending unit and try to force water through the sending unit hole. This should backflush the head. Backflush the impeller housing too.
Jun 06, 2009 | Boating
HOW DO I SET THE TIME?
Wildbill,
My wife has the AudioPhase SPR1 AM/FM 2 AAA portable sports type music player. There is no pdf manual available on internet yet - I will scan and post when I get time. The paper manual says:
To set the Clock:
1. Turn unit off.
2. Press MEMORY once: the clock will start flashing.
3. Press DOWN/MIN to set the minutes, press UP/HOUR to set hour.
4. Press MEMORY again to complete time set.
5. There is always an AM/PM indicator on the LCD display to indicate DAY or NIGHTTIME or night.
To Set Alarm:
1. Turn unit off
2. Press ALARM once: the alarm will start flashing.
4. When alarm time setting is complete press MEMORY 3 times.
5. The alarm setting is completed.
6. Now alarm standby is ON. ALARM indicator will now show on the display.
--> Alarm will only make a noise throught the headphones. When it goes off cancel it by pressing ALARM.
Canceling ALARM standy by.
1. Turn unit off.
2. Press ALARM twice.
3. Now ALARM standby is off.
Radio:
To Seek press UP/HOUR or DOWN/MIN to click throught the frequency or press and hold to seek.
Oct 27, 2007 | Griffin Technology SPR1 AM/FM Radio
Ohmeda Ohio Care Plus Incubator Logo
52 people viewed this question
Top Ohmeda Science & Laboratory Experts
Gareth Cockram
Gareth Cockram
William McMath
ray gallant
Are you an Ohmeda Science and Laboratory Expert? Answer questions, earn points and help others
