Question about Gucci Watches
Clean white rubber watch band - Gucci Watches
    Habit-Forming:
  • 34 Answers
I found this answer: http://www.howtocleanstuff.net/how-to-remove-dye-transfer-from-a-rubber-watchband/
and according to several of the comments, this technique also works with Gucci products. Other than that, I would suggest taking it to a verified retailer.
Posted on Mar 28, 2015
escapement
  • 2334 Answers
SOURCE: discolored white nautica watch band
If your watch band have UV sensitive pigmentation in it, there is nothing you can do, but buy the new band.
Find your nearest jeweller and ask to clean watch band in ultrasonic cleaner for 1 hour. If this kind of cleaning doesn't help, that means your watch band is UV sensitive and is and will be discolouring more and more by the time.
Alternatively you can try to clean it with the lighter fluid (ZIPPO). Soak a soft cloth in to lighter fluid and clean the band. Start with a small area inside band to make sure the fluid is not reacting as dissolver, as some resins react quite vigorously and tend to transform into chewing gum sort of state.
And again- if this cleaning doesn't help, the band is UV sensitive and discolouring is taking place.
That discolouring is happening becouse some of the colour pigments used in resin manufacture are sensitive to ultraviolet light and when exposed to sunlight or daylight, they react in a chemical
way, changing molecular structure, wich we see as the colour change.This process can not be reversed and this is why the band can not be cleaned.
Do not forget to rate please.
Posted on Jan 25, 2009
  • 55 Answers
SOURCE: Missing piece to Luminox 3000 black rubber watch band`
Try parsecent.com they can get the part or a substitute part, the keeper is not sold separately tho, you would have to buy a complete band...good luck :)
Posted on Nov 18, 2009
  • 2501 Answers
SOURCE: Where can I buy a new White Resin Nautica watch band.
If you go to the web site www.nauticawatches.com and select "service center" you will be able to see all the service centers. Choose your nearest and ask them.
Posted on Jan 26, 2010
Testimonial: "THANK YOU"
escapement
  • 2334 Answers
SOURCE: Replacement watch band
You can buy any rubber watch strap and take the loop off for replacement. Just make sure - the strap you buy is exactly the same width as the original ******** your watch. Needless to say: colour should match as well. Rate me, plz.
Posted on Mar 30, 2010
Testimonial: "Quick and informative response!"
  • 101 Answers
SOURCE: My Casio watch band has split apart where the
are you referring to casio mtg900 if so do you mean the rubber part below the G button . If so I do believe casio sells that first link . You can call them if you would like to order it if they still have in stock or for a whole new band
you can see the parts store here
http://www.pacparts.com/model.cfm?CFID=3663724&CFTOKEN=19469938&mfg=CASIO&model_id=MTG900DA-9V&row_start=1&src_model_id=mtg-900&action=list_part
I believe the 12 h and 6 h are the parts you are looking for I am not sure what side you need 12 oclock or 6 oclock , but give them a call they should be able to help you out
the other company that handles watch parts is here
http://www.americanperfit.com/parts/parts.htm
Posted on Oct 26, 2010
Bwhat do i clean white resin watch band
Hello, here is an article with tips to clean watch bands, and according to several of the comments, the process was successful on several Gucci and Michael Kors watches as well.
May 10, 2014 | Gucci Watches
How do i know its a genuine watch has on the rear
where can i find a watch band for the bvlgari model al 38a l 3276?
Jul 29, 2011 | Bvlgari Aluminium White Dial Solid Black...
I have a Michael Kors watch with a white rubber wristband that has turned dirty and dark in less than a year. I am quite unhappy with how it looks, but very happy with the watch. What to do???
Thanks for contacting FixYa.
  1. The easiest thing to try is a regular pencil eraser. It's perfect for removing marks and smudges from rubber and works like a charm! Use white erasers as the pink ones may leave pink smudges.
  2. If a regular pencil eraser doesn't work, try a Mr. Clean Magic Eraser or similar product. Simply moisten the sponge and rub it over the stained area.
  3. If that doesn't do it, grab your safety goggles and move on to the next step.
  4. Mix four parts water with one part bleach in a cup or small bowl. You will need less than ¼ cup of the finished solution, so only mix a small amount.
  5. Wearing eye protection, moisten a white cloth with the mixture. Do not use a colored cloth. You will likely transfer color from the cloth to the watch band and make your problem worse.
  6. Carefully dab the bleach against the stain on the watch band. Don't over apply the bleach or leave it for more than a few seconds or you may damage the rubber.
  7. If needed, increase the strength of the solution by adding a bit more bleach. Do this in small increments to expose the rubber watchband to as little bleach as necessary.
  8. Blot and repeat as necessary if you see improvement.
  9. Once the stain is removed, rinse the band well with water to remove all the bleach residue.
  10. If the stain remains, mix the Rit Dye Remover with a small amount of water to make a paste.
  11. Spread the paste onto the stained area and allow it to set for a minute.
  12. Rinse with water and dry with a soft cloth.
  13. Repeat if necessary.
Additional Tips and Advice
  • Once you have the band clean, treat it with Armor-All wipes made for vinyl car interiors. This easy tactic will help protect the band from stains and smudging. Repeat every few weeks for maximum effect.
  • Be careful with acetone on rubber watch bands. It can start to break down the rubber and make the band feel "sticky." Once done, this can be difficult to reverse.
Best regards.
Jan 31, 2011 | Fossil CH2331 Wrist Watch
Hi, I have a swiss legend Commander watch with a rubber band. It is white and really needs cleaning. Also, it is coated with a rose-gold plated material on the bezel. Any ideas on how I can clean...
mcdevito75 here, For the Bezel (top part of the watch) the best bet is to use a jewelers polishing cloth available at any jewelery shop. For the white rubber strap, a few drops of water with a light hand, or dish washing soap on a wet paper towel or cloth should do very well.
Sep 20, 2010 | Watches
Need a new watch band
mcdevito75 here, Ebay is a great place for your watch band, but you should know the watch band size in MM, or you can look for a small watch repair shop in your area.
Jun 17, 2010 | Locman Titanio Tonneau LOC/484/CRBRD/BK...
Finding replacement watch band
Hmmmm to get an orange rubber band you will more than likely have to go thru Bvlgari. I have access to a lot of watch band but I have not seen an orange rubber band in any of the catalogs I get. You can contact them at 1-800- BVLGARI
Jul 27, 2009 | Watches
Discolored white nautica watch band
Jan 25, 2009 | Nautica N07574 Wrist Watch
Watch band repair
Cleaning yellow Nautica plastic or rubber wach bands
Oct 31, 2006 | Nautica N07518L Wrist Watch
Watches Logo
Top Gucci Watches Experts
Lawrence Oravetz
John mullen
Are you a Gucci Watch Expert? Answer questions, earn points and help others
