Question about AEG Dryers
Aeg electrolux dryer
My AEG Electrolux T55480 dryer has a strange issue: it can turn, it can heat, it can even dry a whole round of clothes well, but sometimes, between a spinning run and the other it makes a noise as if the motor was trying to get through something stuck, and it stops running. One time the light started flashing yellow (it's normally red). I read online there's a way to get a flash coded error message when in that state, but I did not, and it never happened again in the following week. So, as this happened, I believe it's a real problem (the machine itself 'realised') but I don't understand how to fix it. Being an engineer, I tried to open the back and see if I could see anything clearly wrong. Not being an idiot though I stopped unscrewing random things after my gut feelings stopped telling me I knew what was happening.
    Master:
  • AEG Master
  • 489 Answers
Displaying the alarm code
The alarm code is displayed by a repeated sequence of flashing of the ANTI-CREASE/END OF CYCLE LED (0.4 seconds on, 0.4 seconds off, with a pause of 2.5 seconds between sequences). The buzzer emits a series of ,bips" in synchronization with the flashing of the LED.
  • ANTI-CREASE/END OF CYCLE LED: indicates the first number of the a alarm code
  • START/PAUSE LED: indicates the second number of the alarm code
Now you must count how many times the LED lit up and we will know the fault code.
aeg electrolux dryer - 24383347-wycorcio5u0xxoh2plbhrodj-5-0.jpg Dado
Posted on Oct 20, 2015
  • 1073 Answers
SOURCE: My Amana dryer LEA30AW does
the motor is bad replace it
Posted on Apr 19, 2008
  • 4 Answers
SOURCE: Dryer turns off after 30 seconds and beeps six times (over and over.....)
there is a moisture sensor by the lint screen, that could be defective.
Posted on Dec 23, 2008
protek480
  • 1723 Answers
SOURCE: Electrolux dryer error code e61
There is a 'tech sheet' in the back pf the dryer. Unplug machine, Remove the access panel on the back to get to it. Reach in and it should be there. It will tell you how to do a button check. You have to enter a test mode through the buttons.
The E 61 is a stuck button.
Enter function test mode and perform key
stuck closed (active). (button) test to determine which button is at
fault. Carefully free the and perform the test
again. If button is free but the key struck code
still exists, replace electronic control.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Sep 25, 2009
SOURCE: ELECTROLUX DRYER T4190, error code E08
E08 flashing on panel. have tried turning
power on and off, but still flashing. problem?
How to solve this problem
Posted on Sep 07, 2010
ftw1952
  • 10319 Answers
SOURCE: AEG T57800 condensing tumble dryer.
The code E60 means low voltage. Theis means you can have dampness in the circuit which will hinder the voltage output or another problem in the breaker box such as the same. Moister will deduct the current flow in electrical lines as you may know.
Posted on Sep 11, 2010
Have mislaid the manual for AEG Lavatherm protex plus. Where can I find it online? Can't access the model number as machine set in.
User's Manual - AEG Appliances
www.aeg-appliances.ca/wp.../AEG_LAVATHERM-T65179AV-_manual_070913.pdf
LAVATHERM T65179AV Dryer - ... In the AEG webshop, you'll find everything you need to keep all your AEG appliances ... read this user manual carefully, in-.
AEG - Tumble Dryer user manual, operation instructions
www.usersmanualguide.com/aeg/tumble_dryer 4, Lavatherm 310 A; Instruction Manual - Product Number Code:607625125. 5, Lavatherm 310 w; Instruction Manual - Product Number Code:607625014.
[PDF]LAVATHERM 75280AC EN User manual - User Manuals
www.electrolux-ui.com/DocumentDownLoad.aspx?DocURL...pdf LAVATHERM 75280AC. EN User ... Thank you for choosing this AEG product. We have ..... Dry Plus. Extra Quick. Mixed. 3 kg. To dry cotton and synthetic fabrics,.
[PDF]LAVATHERM 76280AC EN User manual - AEG
www.aeg.co.uk/laundry/laundry/dryers/.../downloadpdf/?...User%20Manual... LAVATHERM 76280AC. EN User .... this user manual carefully, including its ..... Dry Plus . The wool drying cycle of this ma- chine has been approved by The.
AEG LAVATHERM 75470AH USER MANUAL Pdf Download.
https://www.manualslib.com > ... > AEG Manuals > Dryer > LAVATHERM 75470AH View and Download AEG LAVATHERM 75470AH user manual online. ... filter, er filters DISPLAY Symbol On/Off Dry Plus Reverse Plus Anticrease Buzzer Time ...
AEG LAVATHERM 65270AC USER MANUAL Pdf Download.
https://www.manualslib.com > ... > AEG Manuals > Dryer > LAVATHERM 65270AC View and Download AEG LAVATHERM 65270AC user manual online. LAVATHERM 65270AC Dryer pdf manual download.
User Manuals ' Service & Support ' AEG
www.aegaustralia.com.au/support/manuals/ Search for user manuals for your AEG products online with our finder tool.
manual for AEG Lavatherm protex plus Google Search
Jun 25, 2017 | AEG Dryers
Remove housing
How to replace a washing machine door seal on an AEG ...
? 5:38
https://www.youtube.com/watch?v=KlAXmnKJQ9k
Aug 17, 2009 - Uploaded by eSpares
This video will show you how to remove and replace the door seal. ... Do you have video repair instructions for AEG washing machine OkO ...
AEG removing drum Washing Machines Questions ... - Fixya
www.fixya.com/tags/removing_drum/washing_machines/aeg
AEG washing machines removing drum related questions and answers. ... into thehousing and get the object out. well as we say in my town you got a "toston" .
Aeg/electrolux lavamat 76810 waschmaschine E20 - YouTube? 0:28https://www.youtube.com/watch?v=1WX5rKxFrXsMay 3, 2015 - Uploaded by jusuf jerkovicAeg/electrolux lavamat 76810 waschmaschine E20 ... front load washer from not draining -- washing machine error code e20 - Duration: 2:52.washing machine error code e20 - YouTube? 2:52https://www.youtube.com/watch?v=2B7FxovrxKoOct 25, 2014 - Uploaded by teppichkopfSave some money and fix it yourself. Totally bizarre how stuff gets stuck in the drain!
Dec 21, 2015 | AEG Washing Machines
Electrolux dryer getting 'stuck' at times
the belt is frayed and catching at times. mine was split in half. right down the middle.gets caught on tention pulley as it goes around,,,sometimes
May 10, 2014 | Dryers
The washing process stops after about 12 minutes at any program and the green door light is on but water in the drum.
it looks like your heating element are dead. But Im not sure.
Does drum is spinning?Does it pumps water then you set in on "drain" program?
Apr 03, 2013 | AEG Washing Machines
Hello, I have a problem with my AEG Electrolux Dryer T59820. I worked perfectly until... It looks that works OK but all what put inside wet, remains still wet after finish of program. I have tried several...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
May 01, 2011 | AEG T57800 Electric Dryer
I NEED A MANAUL FOR MY DRYER
go to AEG website
type : LTH57800 for model number.
The PNC number (which inside the door - bottemleft) might be the same, but otherwise just pick one... teh difference is some internal components revision.. most of the time not relevant for users
Sep 04, 2010 | AEG T57800 Electric Dryer
White westinghouse
I have the same AEG T57800 dryer.  Problem, no heat. Couldn't find a service manual anywhere on the net. Checked for fuses and saw none. Thermostats on heater appeared fine, showing current flow. Replaced heating element 112 54 84 41/8, via local dealer - Respond Services from Electrolux UK in Durham DL5 6ED (£68), still no heat.  Called service tech who replaced the PCB - 973916012018008 (£135 + £85 callout charge). Very, Very annoyed at this as the dryer is only 3.5 yrs old.
Dec 11, 2007 | Dryers
Dryers Logo
129 people viewed this question
Top AEG Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you an AEG Dryer Expert? Answer questions, earn points and help others
