Question about DCS RGS-305 Professional Gas Kitchen Range
Dcs oven door unhinged
One hinge came unclipped on a dcs oven door. how do I reinstall the door?
  • 6 more comments
  • joecas564 Jun 23, 2009
    there is an upper hinge and a lower arm on each side. the lower arm is disconnected and I cant get it to click back in. I can move the arm but i cannot get it to lock into the slot. make sense?
    I'm not sure what you mean. I am still able to open and close the door via the hinge however the lower arm is not connected. the door drops lower on one one side when closed.
    Gas. I dont have the model # b/c it is located at a customer's house.
    thanks for the effort woodsman
  • Jim Thurston May 11, 2010
    sorry - stumped - will research tomorrow
    do you have the model number? gas or electricplease??
    did the hinge fold to the closed position?
  • dcshelper Nov 07, 2013
    there are 2 style hinges on the doors. one has an arm thats about 4" long, the other has a short plate. they both use a small clip on the bottom of the arm that flips up to keep the arm and plate loaded (as if the door were open). you need to load the hinge by rotating the arms down, then flip the clip to keep the arms in the "loaded" positing. then install the door being sure the hinge is engaged in the proper orientation. push the door open and flip the clip so the door will close fully
    Novelist:
  • 222 Answers
Easy to install the door,before to remove check it how exactly the position of the door its a clip typr,or get the manual to see the procedure,open the door,pull open then if u see the hinge we have small lock in the hinge u psh it up the lock then slowly close the door,be care bcoz the hinge is powerfull,if u close the door see the hinge how to remove the door.
tnx gerbee
Posted on Jun 23, 2009
How do I put in my oven door?
The door on k.a. / whirlpool - hinge has a tab that locks rhe hinge and prevents the hinge spring from pulling door closed all the wayslightly lifting and continuing to close thw door lifts it off the hinge rest. Some models have set screws that need to be removed some require door disasembly some ge maytag frigidaire dcs wolf viking etc the door simply lifts off. The hinges stay attached to the app.and some have holes at the pivot of the hinge wherea 1/8 inch metal tabs or nails are inserted and door is ifted up and out....
(That is 1/3 of the job 2/3 is puting it back) lol
Mar 09, 2015 | Kenmore 75012 / 75014 Gas Kitchen Range
TRYING TO REMOVE FAN OVEN DOOR
The link below has a video that explains how to remove the door from most modern oven and ranges.
http://www.appliancerepairlesson.com/2011/01/22/oven-door_diy-oven-repair-help-101/
Feb 27, 2011 | Ovens
Apparently a spring on my oven door is broken (DCS-RG-4844GG). On the large oven door, the left hinge has no tension in it. I can latch the hinge to remove the oven door for cleaning. However, when I...
spring is broken on the side that is 'slacked' without return tension. may be necessary to get underneath the stove chassis. move away from wall, carefully disconnect the gas fitting after turning off the gas spigot. Pull away far enough from wall to 'tilt' the whole chassis rearward to access the underside. Technicians use a 'jack' to raise stove....
Dec 02, 2017 | DCS RGS-484GG Gas Kitchen Range
Decor double oven - Door adjustment
Unfortunately yhe door hinges are non adjustable.
The only solution is to replace the hinges as a pair.
Hope this helps.
Dec 15, 2009 | DCS WOS-230 Oven
The oven door won't close JGS968
The hinges are sping loaded Take the door off to see how much he bent it maybe you can bend it back or the screws can adjust it.
If you need further help, reach me via phone at https://www.6ya.com/expert/scott_541ceb86d69e7743
Dec 04, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
DCS 30 inch oven door fell off
First thing is be careful them sprins are strong and will hurt your fingers bad if not careful. That said place both hinges in 1/3 open position they should stop there. if not put both all the way open then slide door back on and close. supposed to only lift off in 1/3 open position but whatever works.
Jul 25, 2009 | DCS RGS-305 Professional Gas Kitchen Range
Oven door hinges
It is tricky, it takes two people to hold door in place, put hindges into slots then fold downward towards the floor, the hinges will open all the way and it will snap back in.
Jan 11, 2009 | DCS RGS-305 Professional Gas Kitchen Range
Very Old Whirlpool "Wall of Fire" Gas OVen
what you have to do is get a couple of nails pull the hinge on the door down far enough to insert the nails in the holes and let it rest against the door this will hold the door at the proper angle to engage the hooks inside the hinge slots on the body of the range grasp the door on each side and insert the hinges in each side to engage the hooks then open the door all the way and remove the nails
Aug 22, 2008 | Whirlpool RBS275PD Electric Single Oven
Oven door
tough but you need to open the door all the way stick a small screw in the hole on the side of the hinge that is still on then partially close the door this will alow for you to remove the door and then you can push open with your hand the other hinge and stick a screw in the hole on the side this will keep the hinge from closing on you then reinstall the door
May 31, 2008 | Refrigerators
DCS RGS-305 Professional Gas Kitchen Range Logo
3,422 people viewed this question
Top DCS Kitchen Ranges Experts
Carmen Mikulic
Sal De
Ismael Rodriguez...
Are you a DCS Kitchen Range Expert? Answer questions, earn points and help others
