Question about Utilitech 1/2 HP Convertible Jet Pump 1/2C-JET
How do I tell the pump to shut off when up to pressure?
Pump doesn't shut off.
  • 32 Answers
The black cover on the side is the pressure switch. Open it you will see two screws with springs on them. Don't touch the short one. The tall one will adjust the pressure. Clockwise for more, counterclockwise for less. Cover should have diagram.
Posted on May 11, 2014
What causes my booster pump to increase pressure even after I shut power and or water supply off?
something wrong here. your incoming pressure is 4 psi ( tank pressure to the pump and you use a pump to boost pressure to a maximum of 65 psi at which point the pump is shut off ( all taps close off)
yet with no pumps running the pressure goes up to 100 psi
Find where you are getting pressure in that is making the pump leak
if you have 100 psi to the pump when it is turned off, then it would not be turning on ( power on) as the shut off pressure is set at 65 psi and the line pressure is 100 psi
Sep 27, 2016 | Grundfos MQ3-45 1 HP Pressure Booster...
Fuel pressure sensor located buick
the fuel pressure sensor tell the pcm if pressure inside tank can be achieve.if your problems is when you fill up the tank then could be a separator inside the tank or fill tube restriction
hope it helps
Mar 21, 2014 | 2001 Buick Century
Pump shuts of when meeting slight pressure or load conditions.
This could be caused my several issues. A Amp meter used on the cord to see if the FLA ( Full load Amperes) are being draw and causing the Thermal overload to shut off the pump.
The other issue could be that the windings are bad, you could have bad brushes, or possibly the run capacitor has failed.
And the last thing is that the pressure sensor switch might also be faulty. it may have some debris in it and when you get pressure it\'s enough to tell the pump it has pressure and shifts off the switch.
Oct 19, 2013 | AO Smith SQ1152 Pool Pump Motor
I have a franklin electric 4
I have plenty of children and grandchildren, none with my name..... Cash is better but that is not what I'm doing this for.
Sounds like your system is "water-logged", shut off the pump, drain the bladder tank and check air pressure in the bladder. Set it to about two psi below the normal cut on point of the pressure switch. If that doesn't solve it, post again.
Sep 10, 2012 | Franklin Electric 1/2Hp 2-Wire 110 Vlt Sub...
My bostich 6 gallon pancake compressor won't shut off. It get so hot it stinks and I turn it off. The pressure gauges show that it should.
You didn't state your model number so I won't be able to tell you what specific parts you may need. If your guages are correct and the tank is coming up to pressure as it should but the motor doesn't shut off when the peak pressure is reached, you have a bad pressure regulator. They're easy to replace. If it's possible your guages are off and the shut-off pressure isn't being reached, the motor will continue to run as long as it has power. Reasons for not reaching peak pressure in the tank could be a leak somewhere like the pump to tank line or drain valve, a bad valve plate that isn't sealing properly or damaged piston or cylinder assembly.
Aug 16, 2012 | Air Tools & Compressors
My reverse osmosis system causes my Grunfos pump to cycle on and off for two hours aftr drawing a gallon of water from the reverse osmosis. Is there way to fix this so that the pump doesn-t cyle on an
HI THIER MR.STEELE. MY NAME CANDY A..I COULD TOTALY UNDERSTAND WHEN SAY THAT THE CYCLING OF YOUR PUMP TURNING ON &N OFF CAN GET VERY ANNOYING.LET ME ASK U A QUESTION.? HAS THIS CONSTENT CYCLING CAUSE YOUR POWER BILL TO INCREASE? OK NOW ,LETS SEE WHAT WE CAN DO TO FIX THIS PROBLEM OF YOURS..THE ITEM THAT TELLS YOUR PUMP WHEN TO COME ON. HAS TO HAVE SOME KIND OF SETTINGS ADJUSTMENT.ON IT WHAT U HAVE TO DO IS.SPREAD 4 IT TOO COME ON WHEN U WANT IT TOO.
Dec 23, 2011 | Grundfos MQ3-35 3/4 HP Pressure Booster...
Hyundai 2003 Santa Fe 2.7V6 - engine turns over fine, doesn't seem to be getting fuel immediately. Eventually it starts after 5 or 6 seconds of turning over. Suspect fuel filter or fuel pump?
Initially I would agree fuel pressure had dropped off after shut down. This fuel filter is a sock screen attached to the fuel inlet tube of the fuel pump and is located inside the fuel tank with the fuel pump. This screen is rarely the cause. You'll need a fuel pump pressure gauge to verify the low fuel pressure at start up. Caution, sometimes this low pressure isn't a faulty pump, sometimes it's a poor wiring connection to the pump motor. An analog amp meter can verify if there is fluctuation/ing current flow to the fuel pump. A fluctuating current flow could mean poor connections, or could mean the pump has/is gone/going bad.
Aug 31, 2011 | 2003 Hyundai Santa Fe
Where is the fuel pump shut off switch located in a 2000 pontiac sunfire
GM doesn't use a fuel pump shut off switch, the safety system works like this, fuel pump is turned off if the engine oil pressure goes to zero with the key in the run position. Ford uses a shut off switch that is activated by an impact exceeding 3 G's (3X the force of gravity), it is called the fuel pump shut off inertia switch.
Aug 24, 2011 | 2000 Pontiac Sunfire
Car runs great for 10 minutes then shuts off and has to set about an hour before restarting and will only spin over yet has spark and fuel pressure
This sounds like a bad control module, run the car until it dies then remove a sparkplug wire from a sparkplug and stick a screwdriver into it and place it near a ground then have someone spin the key as you watch for spark, if theres no spark then i would say its a bad ignition control module. this is common, when it gets hot is dies out, you can even remove it and have it tested at an auto parts store just make sure they test it a few times to get it hot. good day.
Jun 27, 2011 | 1989 Chevrolet Celebrity
Utilitech 1/2 HP Convertible Jet Pump 1/2C-JET Logo
205 people viewed this question
Top Utilitech Plumbing Experts
Paul Carew
jhnolson
Are you an Utilitech Plumbing Expert? Answer questions, earn points and help others
