Question about Electrolux Kitchen Ranges
Can I install CPVC pipes, instead of steal pipes, for the range hood?
I'm installing a hood range for my kitchen's electric stove thought of installing CPVC pipes, instead of steal pipes, to draw the cooking fumes outside. Is this possible?
catriver
  • 878 Answers
SOURCE: kitchen aid cook top gas. iginator consstantly firing with knoob off
strutz, you probabley got one of the valve switches wet when cleaning. It could of shorted out or it might be just wet. Pull the control knobs off the burners and take a hair dryer and go over the valves slowly. See if it stops the clicking. If not you will probabley have to change out one of the switches. Im not coming up with anything with the RGA365 model number. Try the above posted first...Catriver..post back.
Posted on Mar 12, 2007
  • 1462 Answers
SOURCE: Electric Oven doesn't cook evenly
back plate inside oven may be distorted or some of the vents blocked with crud
Posted on Apr 03, 2007
SOURCE: Stove elements won't turn off
replace switch for that burner
Posted on Jan 17, 2008
SOURCE: need color code/wiring diagram info for Enterprise electric range installation of thermostat
I need the Oven knob for the front panel. The numbers have rubbed off on mine. Thanks, in advance, for your help!
Posted on Jul 28, 2008
SOURCE: Electrolux Slide In Electric Range doesn't fit to the wall?
We have the same Electolux range.....it is supposed to fit about 2 inched from back wall......your granite installer will have to fit a piece of granite behind the range. Yes, it is proper to have the plug installed. The plug is not part of the range package and will have to be purchased seperately if your installer does not use the plug from your old unit.
We are on our second slide in with wave touch controls.......we hope you have better luck that we've had. Ceramic cooktops do not seem to be level on all units. The bottom oven has locked up on both ovens and cause burned foods.....Electrolux has problems that aren't acknowledging as yet..........good luck
Posted on Nov 30, 2008
How do I install a whirlpool top gas stove?
You need a gas connection .then flex tube channel locks or a pipe wrench and some Teflon tape. Connection should have shut off valve.should be shut off. Put Teflon tape on threads then connect the connectors. Open valve.check your work twice listen and use your nose for a foul smell.
Jul 15, 2014 | Stoves 600SiDOm Gas Kitchen Range
Problem with Kitchenaid Electric Range Stove Top Burner
there may be a loose connection in either the pipe or on the burner rings on the surface. Some stoves have a safety cutoff if gas supply is interrupted to avoid prolonged gas supply.
May 12, 2012 | KitchenAid KERA807P Electric Kitchen Range
Can we take the power cord from frigidaire electric stove and attach to magic chef
Yes .. the power cords for electric ranges are interchangable .. just remove and re-install on your new range.
Dec 13, 2009 | Magic Chef CER1115AA Electric Kitchen...
What space is required behind range to allow for gas hook up
If you follow the installation directions for this range, you should be able to have zero clearance from the wall IF the electric outlet and gas shut off valves are located in the proper places. The gas valve should not protrude more than 2" from the back wall in order to have the stove sit flush against the back wall, when pushed all the way in.
Here's a copy of the installation instructions from Jenn-Air for your stove. Please see page 10 for their recommended location of the electric outlet and gas supply line and shut off valve
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Installation%20Instructions%20-%208101P629-60.pdf
Hope you find this Very Helpful and best regards!
Aug 28, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Hello-I am being given a Jenn-Air electric range soon. My current electric stove just has the vent pipe coming up under a back element. Will I need to vent the Jenn-air to the outside? I have an...
Yes the ductless fan will work for you. I have that setup here at my house. Just make sure that you have a charcoal filter installed in the microwave where the air comes out on top. If it is already vent less the filter is probably already there.
Good Luck and Please Rate FixYa!
Mar 03, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Gas stove with electric starter
regardless of electrical supply to home you can always match light you stovetop incases of power failure, your bake and broil would be compromised by lack of electricity.
Oct 23, 2008 | Ovens
PRG3610NP
when you buy a new stove the manufacture installs a small cap on the stove side i know its silly you probably removed that part before you installed the flex line just check that if you did already well then i,m stump-ted thanks the appliance doc
Sep 22, 2008 | Jenn-Air PRG3010 (NP) Gas Kitchen Range
How to Install as Ductless
it should mount sqaurely to the bottom of the cabinets over the stove/oven
you will need a 120v power supply
but it is pretty straight forward other wise
Apr 02, 2008 | Maytag UXT5230AD Kitchen Hood
Stoves newhome
the residue is the grease being exhuasted from the oven.i wouldnt think you could vent it out unless you have an overhead hood.if its really bothersome look at a home depot/lowes for a heat/fire resistant filter and install it on the oven somehow.
Jan 05, 2008 | Stoves 800DFDOm Dual Fuel (Electric and...
Kitchen Ranges Logo
60 people viewed this question
Top Electrolux Kitchen Ranges Experts
Craig Butler
Craig Butler
Robert Plante
Andrew Taylor
Andrew Taylor
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
