Question about Garden
My Bolen15.5 garden tractor won't move when I put it in gear. How Do I fix it?
    Problem Solver:
  • 16 Answers
1. Confirm the transmission is being powered by the engine.
2. Is it powered by a belt? Is the belt on? Is it slipping?
3. With engine OFF, jack the rear of the tractor and turn the rear wheel. Does it turn freely? Does if turn the transmission?
Work backward up the drive train to confirm each component is in good working order. You will then gain an understanding of how it works. If you do not find the problem, respond to this post with more specific information as to where the problem is in the drive train.
Posted on May 11, 2014
SOURCE: my garden tractor makes a funny noise when i put it in drive
Wrong belt size? Did you put everything back the way you took it off to put the belt on? Usually, it's the belt, if it doesnt fit tight it will vibrate, have a burning smell and wont let you shift smoothly.
Posted on Dec 29, 2008
  • 17 Answers
SOURCE: I have a craftsman model # 917.274031 garden tractor.
check the rear wheels,has you fixed a flat and not put a key back in or not fitted the wheel correctly.
Some hydro ?? cut out levers only have a spring to pull it back and get stuck.
Posted on Jan 12, 2009
  • 79 Answers
SOURCE: Craftsman DGS 6500 garden tractor won't engage
Hi
There is a pin in the back by the hitch - make sure it is pushed in. If it is pushed in then check to see if there are any oil leaks under it.
Posted on Apr 10, 2009
  • 1114 Answers
SOURCE: lawn tractor won't move when put into gear
First, check the tension of the drive belt. There should be an idler pulley which is spring loaded that creates the tension. When you push the clutch in, it will release the tension. Also, check to see if the rear wheel hubs have set screws which lock them onto the axle Make sure they are tight.
Posted on Aug 02, 2009
  • 420 Answers
SOURCE: john deere 300 garden tractor hydrostatic drive will not work
check two things, make sure the by-pass rod is pushed all the way in and the drive belt from the engine to the rear end (tranaxle). If both check out ok do not attempt to service the tranaxle at home. have thet serviced by a dealer.
Posted on Jun 02, 2010
Mower will not shift into gear
Please review my answer to:
Craftsman tractor won go into gear had flat tire got it fixed and...
Oct 08, 2016 | Craftsman Garden
Weedeater lawn mower won't go forward or reverse
Try the friction wheel, you guys over think things. Use a snapper wheel, then use your original friction band, you'll have to modify the snapper wheel a bit but it will fix your problem
May 26, 2013 | Garden
Won't move in any gear
did the belt let go?is it a auto trans and the lever on the rear is pulled out that allows you to push it?
May 18, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My john deer won't go in to gear. It starts and
the drive and the mower deck use different belts
Apr 12, 2012 | John Deere Garden
I put the rear end of my craftsman lawn tractor on a cinderblock to take the rear wheel off and fix it. It was on the block for a couple of day. Now my tractor won't go forward or backward. the belt...
Did you forget to reinsert the key or did it slide out while putting the wheel on. A quick way to check is if you remove the center cap and have someone put it in gear and try to go while you are watching the axle. If the axle is turning and the wheel is not then the key is missing.
Sep 12, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a craftsman riding mower that's 2 years old and it won't go into gear it's a 6 speed won't go in reverse either
Hi, did this happen when you went to use it or while mowing? Also will the lever go in but the mower won't move or won't the lever go in either gear at all? Regards Phil.
Aug 17, 2011 | Craftsman 42" Briggs Stratton 20 hp Gas...
When backing up the mower blades shut down and won't come back on when I try to go forward again.
on most riding lawn tractors you most first disengage the blades before going into reverse moving the tractor stop, put the tractor in a forward gear then re-engage the blades. if this dose not help please contact me. Thank you
Jul 06, 2011 | Garden
When i dich in gage the cluch the motor will shatoff or in gage the mower it will shut off .and put it in gear it will shut off.
Check your seat switch. If the switch thinks no one is in the seat, it won't allow the mower to move or blades to turn.
Let me know,
Gary
May 29, 2011 | Garden
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
