Question about Traeger Industries Grilling
I recently replaced my 3 position switch with the digital upgrade on my lil Texas grill. It worked great the first several times but the last two times it wouild not keep the temperature at all constant . It varies 100 degrees or more. Pretty useless unit at that juncture.
  • 36 Answers
SOURCE: Low and Slow heating to temperature on grill
Here are some tips:
Check: The excess flow safety device, which is part of the barbeque to cylinder connection, may have activated.
Fix: To reset the excess flow safety device turn all burners control knobs and the cylinder valve OFF. Disconnect the regulator from the cylinder. Turn burner control knobs to HIGH. Wait at least 1 minute. Turn burner control knobs OFF. Reconnect the regulator to the cylinder. Turn cylinder valve on slowly. Then use your like you normally do.
Now the line is purged.
Fireplace-Girl
Posted on Apr 30, 2008
  • 744 Answers
SOURCE: Inconsistent heat problems Weber Grill
If your propane gas delivery system is equipped with a pressure regulator, check it or replace it. If no regulator, check the following:
* The gas jets for any obstructions, including carbon build up (they can be cleaned with an automotive fuel injector or carburetor cleaner with a lttle help from a brush bristle - do not try and use a drill or other mechanical means)
* The gas connections, and make sure they are all tight
* The gas manifold(s) to be sure they aren't partially obstructed with insect nests, especially cocoons
* The burner(s) to be sure they are clean and that the flame is even
Posted on Apr 27, 2009
SOURCE: Grill heats up at first than will not get hotter that 350 degrees
how make need icecam2 open video ask
Posted on May 20, 2009
SOURCE: the grill only reaches 200 degrees
PROBLEM
Barbecue temperature only
reaches 250° to 300° in the HIGH
position.
CHECK
which is part of the barbecue to
activated.
CURE
device turn all burner control knobs
cylinder valve on slowly. Refer to
“Lighting Instructions”.
http://www.weber.com/manuals
Posted on Oct 17, 2009
  • 332 Answers
SOURCE: I have a Traeger Executive 100 with a digital
Call Traeger direct.
You have a bad control unit
Mike Treager is really good about replacing anything that goes wrong
Posted on Mar 07, 2010
How to remove the hot box
I don't believe the firepot is removable but you can access it for cleaning by removing the heavy metal pan under the grill and the cover over the firepot. It may be attached to the grill bottom with screws or rivets but the best way to clean it is with a shop vac. For specific information you might want to contact Traeger support at
Jun 24, 2014 | Traeger Industries Lil Texas Elite Grill,...
I bought this watch in May of last year. For the last 3 months, every 2 to 3 weeks I have to reset the hand home position. Once that is done, I have to then reset the home city and time manually. What...
Hand home positioning normally has nothing to do with time setting.
Just set your local time and date and then you can do the hand home positioning procedure.This will not affect the time setting.If hands,after a while,do not show correctly,this means that the watch is under severe magnetic field, after severe shock or finally watch malfunction.
You must know that on this type of watches analog time follows digital time.
Feb 05, 2014 | Casio G-Shock World Time Analog Digital...
My playback button ON Samsung camera doesn't work! :(
How wet is "a lil" wet? If the device was submerged in water it likely has severe water damage, you can try putting it in a bag of rice for 24 hours but if that doesn't fix anything there is nothing you can do other than buy a new one, or replace the parts that were damaged, and I do not recommend trying that if you have never done so before. Good Luck!
Jun 07, 2012 | Samsung St65 14.2mp Digital Still Camera...
Model ST01 to be used on a 3 way switch arrangement. Unit works in one switch position but fails to allow light to turn on in other switch position. Several other switches are adjacent in same box and...
You have ST01C timer.
If I understand correctly, timer is wired for 3-way and was working fine before.
Now, the timer is no longer letting the 2nd 3-way switch operate.
I tested this timer.
When the red and blue wires on timer are connected, the timer reverses.
When the red and blue wires are disconnected, the timer reverses back.
So the 2nd 3-way switch merely connects and disconnects the red and blue wire on timer.
This is why wiring is different on 2nd 3-way switch, and not like ordinary 3-way wiring.
http://waterheatertimer.org/images/ST01C-EJ500-w-3-way-450.jpg
This means that a) Timer has gone bad or b) 2nd 3-way switch has gone bad.
1) Replace 2nd 3-way switch
2) ST01C instructions say as last resort, reset timer.
However all timer programs will be lost.
Open following link to read steps for resetting and reprogramming timer, plus wiring diagrams.
http://waterheatertimer.org/ST01C-program.html
3) Replace timer
Amazon:
http://www.amazon.com/Intermatic-ST01C-Digital-wall-Timer/dp/B0045D3D16
Aplussupply
http://www.aplussupply.com/intermatic/timer.htm
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 30, 2011 | Intermatic Inc. ST01C Digital In-Wall...
I don't know how to use the calculator enough to figure scientific notations
Scientific notation is a number format that has the following structure (d stands for digit)
one digit decimal mark several other digits [times] 10 raised to power of exponent
d [decimal mark] dddddd...[x] 10^ (-) dd
Here are two examples the last two results. The number of digits after the decimal mark is select by the user depending on the number of significant digits in the data. The exponent can be positive or negative.
In you case, to enter x10^ you press the [EE] key (no 10 is entered) the sign of the exponent and the value of exponent.
Aug 22, 2010 | Texas Instruments TI-89 Calculator
BBQ was working great last time I used. Next time
yes turn off bbq at inlet valve , open control knobs let out gas pressure or undo line after control tap reconnnect then turn on slow should work
May 30, 2010 | Napoleon Gas Grill
I cant see my external lacie hard drive on my mac. Was part of an ethernet network and able to use ok by 2 imacs and p. All of a sudden not visible anymore.
Just contact www.lacie.com great support. their answer for my drive was to upgrade the drive version and to reboot the drive. Maybe the last thing is enough. For me it worked.
If necessary update driver http://www.lacie.com/nl/support/drivers/driver.htm?id=10156
Follow the procedure below to reset the Network Space to factory defaults:
  1. Move the power switch to the OFF position. Wait for the drive to shut down.
  2. Turn ON the drive.
  3. Within about 3 seconds, flip the switch OFF and On several times.
  4. Immediately turn it ON
If the light flashes quickly, the unit is resetting itself. Attempt to connect to the drive again after about 1 minute using the default username and password (by default, they are both admin.)
Feb 04, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
I have external hard lacie it work normal before two day but now it cannot detect
Dec 08, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Sony RM-ASP001 for 400 disk changer stopped working
Try the command code switch. I recently had a similar problem when my remote suddenly stopped working. It worked fine one time but nothing the next time I tried it.
I checked the emitter with a digital camera and found it was not working. I did the remote reset (remove batteries and push all the buttons twice, reinsert batteries) and the emitter was now working. However, the remote would still not control the base unit. I did the remote base code reset (push power, volume and TV/DVD buttons together) but this did not help. I then checked the command code switch. This is a small three position slide switch located in the battery compartment on the remote. I slid the switch back and forth several times returning to the default number one setting where it was before. I did not change anything on the base unit but the remote now worked.
Hope this helps.
Dec 23, 2008 | Sony RM-ASP001 Remote Control
Panasonic screen problems
Then recently, these additional problems: 1. The picture cannot be restored by turning off then on. 2. Sometimes, several channels will have the same picture. 3. Sometimes several channels will have the same ghost-like picture. the above all problems are due to one that is weak signal. 1 check for antena or cable or satellite input is ok or wire might be defective due to old. 2 input socket is loose some where. 3 loose contact near tuner or some print break. 4 at last & final its tuner might be defective. hope this will help.
Oct 03, 2007 | Panasonic CT-36D32 36" TV
Grilling Logo
Top Traeger Industries Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Traeger Industries Grilling Expert? Answer questions, earn points and help others
