Technical specifications EMC 2.0
DC input, volts AND amps. Thanks
Shuttle83
  • 1139 Answers
SOURCE: No Power
Hello jasper100, Have you opened the unit to take a look inside? Since you dont have a blown fuse we cans assue the a short has not occured. Now I would chect to see if the voltage regulator in the amp has voltage coming from it. It may not in that case you may have to remover the old regulator and put in a new one just to get to the point of properly troubleshooting this amp. I would suggest that you get a schematic for this unit and use a multimeter to look at the voltages in the power supply section and see which sections have no rail voltage (12v supply voltage). I would also advise checking the remote to for regulator failure.
Posted on Sep 10, 2007
  • 508 Answers
SOURCE: I have a umax 2500 scanner . I need specifications
google it
Posted on Jun 25, 2009
SOURCE: there are 2 sets of wires on the rca rt2760 home
one is for the speaker connection the other is a control wire for the sub that should have a white plug on it to plug in the back of receiver
Posted on Dec 13, 2010
barterjoe
  • 344 Answers
SOURCE: with 13.3 volts dc input only putting out 94 volts
AT 10.64 AMPS THIS WOULD EQUAL 1000 WATTS BECAUSE VOLTS TIMES AMPS IS EQUAL TO WATTS.
There may be a regulator that boosts the voltage when the inverter is in use. you might check in line voltage while in use and see what you get. Operating amperage should be around 10amps.
good luck and feel free to reply and vote. Joe
Posted on Feb 16, 2011
SOURCE: Can I use a 12 volt DC power supply with the Meade
Yes you can just make sure that the power cord has the CORRECT pin polarity- you can order the 12 volt cigarette lighter style cord from Meade.
http://www.meade.com/support/index.html
Posted on Jun 27, 2011
I lost my old original power adaptor so I need more specific info for the bms10m.
It is a class 2 transformer. The Conair part number is TEAD-57-121600U Input: 120 volts AC 60 Hz 29 Wats Output: 12 volts DC 1.6. You can try getting an alternative as long as it has the specifications as shown above. I wish you luck.
Feb 20, 2018 | Power Computers & Internet
How can I tell how old my iPad is?
5 February 2013
iPad (4th generation) - Wikipedia
https://en.wikipedia.org/wiki/IPad_(4th_generation)On January 29, 2013, Apple announced and scheduled the launch of the 128 GB variant of 4th generation iPad. It was released on February 5, 2013. Following the announcement of the iPad Air on October 22, 2013, sales of the fourth-generation iPad were discontinued.‎History · ‎Features · ‎Hardware · ‎Reception
A1459 - Lookup Mac Specs By Serial Number, Order, Model & EMC ...
https://everymac.com/ultimate-mac-lookup/?search_keywords=A1459
Intro. October 23, 2012*, Disc. October 16, 2014**. Order, MD516LL/A*, Model, A1459 (EMC 2605*). Family, iPad 4th Gen (Wi-Fi + Cellular), ID, iPad3,5.
iPad (4th generation) - Technical Specifications - Apple Support
https://support.apple.com/kb/SP662?viewlocale=en_US Oct 14, 2016 - Model A1459*. GSM/EDGE (850, 900, 1800, 1900 MHz); UMTS/HSPA+/DC-HSDPA (850, 900, 1900, 2100 MHz); LTE (Bands 4 and 17).
Identify your iPad model - Apple Support
https://support.apple.com/en-us/HT201471 Sep 21, 2017 - A1459 on the iPad (4th generation) Wi-Fi + Cellular A1460 on the iPad (4th generation) Wi-Fi + Cellular (MM); White or black front bezel ...
Launch Date here
ipad a1459 launch date Google Search
Oct 04, 2017 | Miscellaneous
What specifications do i use to get a replacement charger for a Peak Charging Adapter . . . . . . . . 120 volt AC (700mA, 12 volt DC Output
Just as your information says ask for a 12 volt 700 ma charger..but seeing that yours is a 450 amp jumper..any 12 volt that fits your ac input will do the job...one more thing if you do not have a charger..just connect it to your battery and run the engine for 20 min or so it will recharge the car battery and you jumper..also you can get a lighter wire with two lighter plugs and charge it through you lighter..good luck
Oct 22, 2014 | 450 Amp Jump-Starter with USB and 12 Volt...
I have the Western Digital My Book Essential Edition 250GB External Hard Drive. I have moved and lost the power cord. I purchased the DYNEX 500ma Universal AC Adapter as a replacement. When I plug the...
I don't have a photo of the AC adapter, but if you look on it the Voltage and Amperage specifications are;
Input: 100-240VAC / 50~60Hz
Output: 12VDC / 2A
This means the Input power can be from 100 volts to 240 Volts AC, and at 50 to 60 Hertz
The Output power is 12 Volts DC at no more than 2 Amp's. (Amperes)
Asian Power Devices Inc. has a model DA-24B12 that fits these specs.
Also a Wattac AC adapter model number - BAO362Zl-8-A01 will work.
Otherwise just use a 12 Volt, 2 Amp power pack, with a positive on center contact, and a 2mm pin hole
Sep 15, 2011 | Western Digital 250GB MyBook External USB...
Hi I want to purchase a AC DC 12watt Power Adapter for my old ARTEC 1236P Scanner. Can someone tell me if I can use my spare Input 230V ~ 50Hz 9W (Output - 12 to 9v) adapter? If not what should be the...
This will mean the input on the first device is 120 V and input on the 2nd device is 230 V. Right? If so Yes you can use this if it belongs to the same scanner however you will have to plug the power into a 230 V Circuit. You cannot adjust, manipulate, change the Volts/Watts/Amps under any conditions. If the 203 V (Out put) plug is the same as the 120 V plug and there is a place to plug it in to the scanner then go for it. Volts/Amps/Wwatts/AC/DC are very specific to a specific device.
Jul 24, 2011 | Artronix Technology Artec 1236 P Flatbed...
Were can i purchase protron ac/dc power supply for protron pltv-32 pltv32 lcd tv
Check this link below:
http://www.lcdpayless.com/productpage.php?productId=5441
Specification of Protron pltv-32 lcd ac adapter:
Output Voltage: 24V and 12V Volts DC
Amperage: 6 A and 3 A Amps
May 15, 2011 | Protron Ac / Dc Power Supply For Protron...
Describe your Western Digital 250GB MyBook External USB 2.0 250 GB Hard Drive Problem Do you have a picture of the voltage and amperage adapter for the Western Digital 250GB MyBook External HD ?
Output: 12VDC / 2A
Nov 23, 2010 | Western Digital 250GB MyBook External USB...
Can i run my xplode amp from my pc
Thanks for using Fixya.
Yes you can... but, this will cause you a lot of hassle. You'd need to get yourself an AC/DC converter because your amp needs 12 volts. Do not use your computer's power supply unit for the 12volt input as your amp eats up alot of power so you might overload your computer's power supply unit (PSU). After getting the AC/DC converter for your amp. You need to rewire your audio input going to the amp so that it uses a 3.5mm jack so you can easily plug it in to your computer's audio output. I hope this helps.
Thanks and have a nice day.
- HotRatchet
Nov 08, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Lost power cord
Specifications:
  • Manufacturer: HP
  • Input: 100-240V, 50/60Hz
  • Output: 32V, 16V
  • You can get more information here:
    http://www.unitedsale.com/product_info.php?products_id=18583
    Please vote me if you like my post.
    May 25, 2009 | HP Photosmart 2610 All-In-One InkJet...
    Two car batteries @ 24-volt, would like to go to 15-volts
    Hello j37p,
    You will need a thing called a "DC to DC Converter". Here's a link to one place that makes them: http://www.powerstream.com/
    One model they have is the PST-D24/12-800. It will accept 20-28V input and has an adjustable output from 12.5-15.5V.
    I'm hoping that you are not planning on trying to charge 3 batteries with your vehicle alternator. You would not want 2 12V batteries in series anywhere near the vehicle electrical system. They would definitely burn stuff up. You'll also want to be thinking about how to keep the dc converter and your amp(s) cool. Believe me, they will be getting hot and require some serious airflow.
    Hope this helps.
    Apr 14, 2009 | Car Audio & Video
    103 people viewed this question
     Grubhead
    Grubhead
