Question about Husqvarna Garden
GTH2654T WILL NOT DRIVE R BACK UP
WILL NOT DRIVE R BACK UP THE WELLS R ONLY TURN IN OPPISITE DIRRECTION
  • 32 Answers
Did you have the rear wheels off or one of the rear wheels off to do something?...sounds like one of the square keys that drive the wheels is missing. I did it myself once.pulled and wheel and forgot to put it back in. same response. check both rear wheels to make sure the key in still in both slots of the wheel. its a 2 or 3 inch piece of 1/4 x 1/4 inch square stock. if you lost it you can buy square stock 1/4 inch at a good hardware store.
Posted on May 17, 2014
My mower just stopped going when I was cutting grass. It will not move in forward gears or reverse. I lifted the mower off of the ground and spun one of the back wheels and the wheels move in the opposite...
That is normal if it has a rear dif/gearbox, they are ment to turn in opposite directions. Does your machine have a leaver to disengage the drive for recovery purposes.? This may have knocked the machine out of drive.
Jul 30, 2013 | Garden
My Prop On My Larson Boat With A Mercruiser Alpha 1 Drive & A 5.7 Liter Engine Won't Turn The Prop In Forward Or Reverse. When The Engine Is Off & It Is Shifted Into Forward The Prop Can B
run the engine and watch the drive shaft behind the engine , is it turning ? also as your mate selects forwad and reverse ! does it stop turning ? pos flywheel damper or output shaft damaged ! pos gearbox damaged !??
Jun 04, 2012 | Mercury Boating
Turn signal lights turn off when using prior to making turn
be sure to turn the signal lights on prior to turning the wheel in the dirrection you wish to turn... The turn signal deactivator in the steering column will sometimes deactivate the signals premeturely if the wheel is turned prior to signal engagement.
Sep 25, 2010 | 1997 Pontiac Sunfire
Can you reverse the door on the front load washer?
yes u can you will see some small plasitc pieces covering the holes on the oppisite side remove these plastic peices gently u willneed to use them on the oppisite side remove the door and the latch assembly u will see the same holes on the oppisite side make sure you install allthe plastic cover pieces back into the unit if not this is a great place for bugs to hide
Jul 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My refrigerator does not seal on the top corner oposite the door hinge. Is there anything to do?
yes either you door has slitely twisted thus twist it back gently in the oppisite dirrection or using a hair dryer heat up the seal and pull it out more till its in the correct position
Jun 25, 2010 | Samsung RB215LASH
Change Door
there should be two plastic covers or two screws on the oppisite side.simply unscrew the hinge from the side its on flip the door the oppiste way.remove the door mechanism that is on the frame and put the mechanism onthe oppisite side and rescrew the hinge on the oppisite side
Apr 28, 2010 | Whirlpool GEW9250 Electric Dryer
Needle not picking up bobbin thread. Seems threaded properly. lsd-1 (classic) Problem occurred after needle hit something perhaps the the cap spring which had some marks on it but no real damage. ...
change the needle, if bent it may skip, use top thread while holding to pull thru, turn bobin around to turn in oposite dirrection, bobins usually turn in 1 correct dirrection
Sep 28, 2009 | Sailrite Sewing Machines
Garden Logo
73 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
