Question about Krups XP7230 Compact Super Automatic Espresso Machine
Krups xp7200 container error - Krups XP7230 Compact Super Automatic Espresso Machine
2 Suggested Answers
SOURCE: Krups Espresseria Automic XP7200 coffee machine
As this is an automatic espresso machine, I suspect that the cake container is where the "used" pucks of ground coffee drop into after your espresso is extracted. The container may not be fully seated in position. See if there is a door on the machine that the container may be hiding behind.
Good Luck.
-Steve
Posted on Sep 27, 2008
Krups error code 01
I don't have a service manual so I can't say exactly what it means but I had the same error.
I fixed it by clearing out the pressure chamber where the grounds are compressed and the hot water is run through. There was a blockage that made the displacement lever (the little arm that moves spent grounds to the trash container) stuck and not fully able to move out of the path of the plunger.
To do this I recommend using a compressed air can and a long slender object (pipe cleaner is ideal) to scrape out residue in the chamber and around the moving parts.
Aug 24, 2014 | Krups EA8250 Fully Automatic Espresso -...
Its about my Krups 8220. It gets stuck after it tells me to empty the two containers, immediately after cleaning the two containers and the coffee drawer it says machine in auto test and after it finishes...
Take it in to your Krups service agent, something is going to need replacing and they are by no means a simple machine to work on. You will fix nothing from the outside, it will need to be pulled apart.
Aug 19, 2013 | Krups Small Appliances Espresso Machine
Krups xp7200 how to do descaling
Manual has procedure....read that section.
Jan 24, 2013 | Keurig B50 Coffee Maker
My krups xp7200 is leaking water from the bottom. How can I open it to check the problem? thanks
You need to unscrew 4 screws in the front, three on the top (underneath the lid where you put the cleaning tablet), one inside the coffe container at the top, and pull gently, but firmly the little black nob inside the coffe container, that you use to adjust the coffee grinding, straight up. Then you can remove the coffee container on the top, and unscrew one screw underneath this container. Also, remove the two screws from the holes beneath the water container. NOW, you should be able to pull the front electronics off, and pull the main cover backwards, away from the front panel. You may have to bend it a little to get it completely off, but it is not a problem. Good luck! :)
Jun 15, 2010 | Microwave Ovens
Krups XP7200 series date problem
It seems that the dial knob and the electronic opto coupler don't work anu more. You can replace the digital panel by try to find a broken machine on ebay. Unless you are an electronics engineer like me (you can try to replace the optocoupler). See the post on leaking xp7240 for opening up the machine... it's tricky but easy.
Apr 14, 2010 | Krups XP7230 Compact Super Automatic...
How do I dismantle the grinder
I can remove the bean container by pulling off the grind selector knob and removing the only screw.
Then remove the scute for the cleaning tablets. Then remove the two screws that were covered by the scute. Remove the water tank. Under the tank remove the two screws.
Then the trick where everyone seems to look for: The facade of aluminum can be moved off. Set the machine on the floor and pull hard upwards at the facade. This comes off (pull hard!) and four screw are uncovered. Remove them and pull then back housing of the machine (remove first the containers/drawers). Now the inner parts are freely accessible. Take photos and remove the components from top till bottom to get to the bad parts that need replacement. Good luck!
Jul 21, 2009 | Krups XP7230 Compact Super Automatic...
Krups XP7200 wont grind beans (all lights flash)
See post on leaking xp7240. It is almost the same machine. This post explains how to fix it (valve is blocked but can be easily cleaned)
Mar 14, 2009 | Krups Small Appliances Espresso Machine
Good Luck.
-Steve
Sep 27, 2008 | Krups XP7230 Compact Super Automatic...
Cleaning and descaling Krups Orchestro 889
take a descaler solution never mind vinegar not strong enought 1part solution 1part water put that in our water container start the machine open valve let it drip for a few second untill you see the solution leave it like that for 10 minute after open the valve and do it again untill emty after you emty the solution clean water container very good fill it with water open the valve rinse very good because that solution is very corosif enjoy cheers
Jan 19, 2008 | Krups Orchestro 889 Espresso Machine
Krups XP7230 Compact Super Automatic Espresso Machine Logo
54 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
