Question about Rowenta Irons
Iron Leaking from the bottom? - Rowenta Irons
Rowenta Iron leaking out of bottom and leaks on clothes
I have one of these and have been battling the leak problem for years. I'm a stubborn mechanical engineer and I'm bound and determined to fix this, when in fact I should just buy another, different, iron.
The problem is then 'handle'. Built into the handle is the water tank. The water tank is made from two pieces which are then glued and screwed together. Think of taking a coke bottle, cutting it in half, and then gluing it back together. Now you see where the problem comes in... the glue they use isn't up to the task, or the heat... or the pressure... is causing the tank to leak somewhere / everywhere.
I have disassembled this several times, meticulously scraped out the old silicone, and tried several different types of silicone to re-seal. So far it always fails. It's good for a while, but maybe a couple months, before it starts leaking again.
Conclusion... BAD DESIGN. Very disappointing, because in every other respect I like this iron better than any I've ever owned.
Jul 14, 2010 | Rowenta Power Duo Iron
My iron leaks water from the bottom
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Dec 28, 2009 | Rowenta DZ5080 Iron with Auto Shut-off
Constant steam and water coming out of the bottom of the iron
Try using different water...
heatman101
Oct 23, 2009 | Euro-Pro G1490 Continuous Iron
Water leaks from bottom of iron
heatman101
Jun 18, 2009 | Sunbeam Steam Master 4055 Iron
I have a Tefal Pro express iron and I have water dripping out of the bottom of the generator. Can you help.
There is a seal or a connection leaking. Take the iron apart -- you'll probably see where it's been leaking.
May 04, 2009 | Tefal Irons
Iron leaks water
heatman101
Mar 11, 2009 | Rowenta DZ9080 Iron with Auto Shut-off
Water leaks out of iron
heatman101
Nov 23, 2008 | Black & Decker Steam Xpress AS250 Iron...
New iron, stopped heating and leaked water
heatman101
May 22, 2008 | Black & Decker D2030 Iron
Euro pro craft n sew 959 iron
heatman101
May 16, 2008 | Euro-Pro Craft N Sew 959 Iron
Irons Logo
41 people viewed this question
Top Rowenta Irons Experts
Joseph Hoffmann
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
