Question about Maclaren Twin Techno Umbrella Stroller
How to fix wheels? - Maclaren Twin Techno Umbrella Stroller
  • Maclaren Master
  • 1,629 Answers
Hi Helena
We'd recommend you contact Maclaren direct
Posted on Jun 22, 2014
Steering wheel is not straight, and I have an appointment for getting a wheel alignment, and my question is that will the wheel alignment also fix my steering wheel to be back straight and normal ?
A wheel alignment will help if that is the only thing causing the car to go right. If you have hit something , like a curb it could have bent or broken something in the front end. The wheel should return to straight if the alignment is all that is needed.
Oct 21, 2017 | Cars & Trucks
My wheel fell off where cani get it fixed
Those wheels have a fixed axil that goes bad. A new wheel will fix that.
Sep 05, 2014 | Vacuums
Hi i have an inglesina triple pushchair- one infront of the other and the wheels keep breaking- i have fixed the ones infront now but the first set of wheels keep coming off- is there anywhere to buy...
Regards, Tony
May 10, 2011 | Toys
I took front wheel off bike to fix puncture. i
Loosen up the hub nuts. Center the wheel between brake pads. Put something like a screw driver in the space between wheel and frame to keep the wheel centered and not moving as you tighten the nuts.
Oct 02, 2009 | Cycling
Steering wheel is a little off set, how do I fix it.
Open your control panel. Click on "Printers and other hardware". Click on "Game Controllers". Then click on the wheel controller. From there, you should be able to assign the buttons and fix the offset.
Oct 02, 2009 | Logitech DRIVING FORCE FEEDBACK STEERING...
Uneven steering wheel
Off center steering wheel is very common, a good front end man will drive the car/truck and verify that the wheel is centered, it is not a mechanical problem just an adjustment issue, go to an outside shop or another dealer and tell them u just want the wheel straight, remember the road has a slight angle to drain water off, it's called road crown, tell them you want the wheel centered and to take road crown into account when they do it, make sure the front end man double checks the center by means of a good road test on varied road surface, tell them where it is that the off center is most noticeable, all this is from personnel experience, I am a fanatic about the wheel being centered. If u have more questions fell free to ask, sorry for your justified frustration on this issue.
Jan 06, 2009 | 2005 GMC Envoy Xl
Bicycle Rear Wheel Problem
Tighten the two pinion gear bolts that are holding the rear wheel, if the wheel is wobbling, then that is the problem.
If this does not fix the problem, you will probably better buy a new wheel, or replace the whole pinion gear and axis assembly, better to replace the wheel.
Oct 29, 2008 | Victory VegasLow 26 Men's Dual-Suspension...
Broken casters (wheels)
This is definitely something that you can do yourself. Remove the back of the dishwasher and the front kickplate. This will give you access to the wheels. The wheels are held in place with a U shaped clip. Remove the clip and the wheel will come out. replace with the new wheel.
This happened with my Danby DDW1805 and I fixed it myself. I used two step stools at the side of the dishwasher to raise it off of the floor.
Aug 28, 2006 | Danby DDW1805W Designer Series...
Maclaren Twin Techno Umbrella Stroller Logo
60 people viewed this question
Top Maclaren Baby Gear Experts
Jennifer Rock
Jennifer Rock
xxxxxx xxx
Jim Goldsmith
Jim Goldsmith
Are you a Maclaren Baby Gear Expert? Answer questions, earn points and help others
