How to auto search without remote control aiwa tv at215?
5 Suggested Answers
SOURCE: Sylvania 6719DC + E Circuit 6 in 1 Remote Control
I bought this at a Dollar Store and it works great.
1) Turn TV on. Do not worry about what channel.
2) Press and release TV1 button on remote. Depending on what unit your trying to sync.
3) Press and hold SET and ON buttons together for about three seconds until light begins to flash.
4) Release buttons, light will continue to flash and search.
5) Be prepared to immediatly press SET button when Television Set turns off. Be patient this may take a few minutes.
I wasn't able to find information on this. Just got lucky. Hope this information helps. Good Luck!
Posted on Dec 06, 2008
laseramp
  • 313 Answers
SOURCE: how do i unlock my aiwa tv pin code without the
try # 0000
usually works
Posted on Sep 15, 2009
SOURCE: Aiwa TV remote codes
service code
Posted on Nov 24, 2009
SD Tech
  • 14553 Answers
SOURCE: Can u get to the menu on a memorex DVD /VCR /combo
No,most require the remote to navigate the menu and enter changes with.
Posted on May 23, 2012
Aiwa tv brand code?!
0091,0099. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Oct 11, 2015 | Aiwa Televison & Video
Hoe to auto search without remote control aiwa color television at215
Depending on the model sequences can be slightly different, firstly you must be able to access the "Menu" button on the TV, as well as the arrow and "Enter" buttons. These buttons are typically located on the left side panel of the TV.and may be the buttons for Prog + or - or Volume up or down . Generally speaking the same sequence of buttons you press to scan for channels are identical to those you press when using a remote. Play around with combinations and see what they do but dont dont hit the enter button until your happy that you know what it is doing, write down the sequences and button combinations so yo remember them for next time. Step 1: Press the "Menu" button, press the "Up" and "Down" arrow buttons to highlight "TV" menu and press the "Menu" button again to enter the TV menu.
Step 2: Press the "Up" and "Down" arrow buttons to select "Tuner Mode" and press the "Left" and "Right" arrow buttons to select the frequency band depending whats connected to your TV. (digital box or aerial)
Step 4:Press the "Up" and "Down" arrow buttons to select "Auto Search" and press the "Menu" button to scan for all channels that are available in your area.
May 10, 2014 | Televison & Video
I lost my original remote control for my AIWA combination TV/ VCR. VX-S135 ? I bought a universal remote control but there was no code listed for an AIWA TV. Just a VCR. I need to know the code to the TV...
what's the name/make and model of the remote?
Without me knowing the type of universal remote, there is no way I can get the right code for your TV.
I look forward to your reply.
Bye for now.
Jun 24, 2010 | Aiwa Televison & Video
I cant control my AIWA TV WITH A jumbo universal control.THE CONTROL NUMBER DOES NOT WORK that is given with the instructions
Have you tried the auto-code search?
Unfortunately, you can't teach this remote new codes, so if none of the AIWA codes from the manual work, and you run through this auto-program sequence and it doesn't work, there is no other solution for your TV.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
I hope that helps.
Nov 19, 2009 | Innovage Jumbo Remote Control
Rca remote is not workin on my aiwa tv
porfa necesito el codigo para un televisor aiwa me pueden ayudar xporfavor
May 06, 2009 | RCA RCU300WBL Remote Control
Remote is not working and when i use manual button on TVfor volume & channel change, it get changed to Video 1 and Video 2 and next channel. Every time it is happening like this only.
First, the remote:
If you have a cell phone with a camera, aim the remote at the cell phone, so you can see the front of the remote on the cell phone screen. Press a button on the remote, and see if you can see it blinking through the cell phone screen. If you can, you know the remote is working.
Now, the TV:
Have you programmed the channels in? Run the setup function on the TV to auto-search for channels. It should automatically program all the channels it's currently receiving.
Hope that helps. Please report back and perhaps I can help more.
Jan 04, 2009 | Aiwa F2000 20" TV
I need the code for a aiwa tv
I've got an AIWA F2000 TV . Code 528 worked for me
Aug 23, 2008 | RCA RCU300WBL Remote Control
Codes for aiwa
The code is " 009 ". or you can manually searching code by pressing button " set " together with " tv ". then red light appear. Press button volume continually until "volume level came out". then press button set again. Now your universal remote should be ok.
Aug 12, 2008 | Televison & Video
Setting the clock
Use an Aiwa Hifi Remote Control...Turn on the L300 (without any DVD on the player). Wait until in the TV appears "No Disc" Open the tray and put a DVD from other region (not zone 1), don't close the tray!!!. On the remote control of the Aiwa press the "Clock" button, in some remote control you must do a button combination like "Shift+9" (Is the combination to see the clock, do the combination fast), and in other model of Aiwa remote control doesn't appear the clock button, you must try with the "random" button. If you do it right, in the corner of TV where "No Disc" appears it will say "adjust complete".
Jun 15, 2008 | Sansui VRDVD4005 DVD Player/VCR
Aiwa tv/vcr/dvd combo mfg. 2003
what model uni remote do you have??
Aiwa i think is now sony. so try some sony codes.
also have you tried to auto search for your code?
Apr 09, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Electro Med Services...
