Question about managemylife.com
Kenmore 19702 not working
Stopped working, unplugged for 5 mins, plugged back up for 5 mins then turned on ,still not getting cold, i don't hear the compressor just a click every few mins, whats wrong?
  • 3 Answers
Check the drain hole inside
Posted on May 11, 2014
Kenmore refrigerator (bottom freezer)
U MAY HAVE BLOWN THE COMPRESSOR RELAY DUE TO THE TRIP? U CAN REMOVE IT FROM THE COMPRESSOR AND SHAKE IT IF U DONT HAVE A METER TO TEST IT, IF IT RATTLES THEN ITS BAD? IF THERE IS A CLICKING WHEN COMPRESSOR IS TRYING TO RUN ITS BAD, OTHER WISE I WOULD SUSPECT A BAD COLD CONTROL THERMOSTAT ESPECIALLY IF UR TURNING IT FROM UNDERNEATH AND NOT JUST THE KNOB? DID U USE A SCREWDRIVER TO GET INTO THE TINY SLOT UNDER THE TIMER AND TURN IT SLOWLY TILL U HEAR A CLICK? TURN AGIN AND THE NEXT CLICK SHOULD TURN IT BACK ON U SHOULD HEAR THE COMPRESSOR AND THE FAN WORJKING
Mar 14, 2015 | Kenmore Refrigerators
I have refrigerator kenmore bottom freeze (water, ice disspenser) screen letter say if err, could you pl help me?
Error "ER IF" stands for ice fan error. most likely ice has build up in the fan that sends cold air to make ice. Try unplugging the unit for about 5 mins and plugging it back in to see if error is cleared. if error returns you will likely need to defrost the freezer to get ice out of fan.
Oct 02, 2012 | Kenmore Refrigerators
I have a kenmore chest freezer model 19502/19702. I had it unpluged for 5 months. When I plugede it back in the power light flickers. Tryed other outlet. Other then that it seems to be working
We purchased this same Kenmore chest freezer model 19502/19702 in 2010. In less than 2 years the compressor quit. If you do a search on this model you will see dozens of complaints. Don't waste your time or money on this freezer.
Apr 16, 2012 | Kenmore Freezers
Fridge wont get cold
unplug for 15 min let sit the plug back in u should here it turn on feel the sides of the freezer if getting cold but fridge not the fan for fridge bad also there should be a copper or steel looking wire inside in back for therm
for the temp move it around it mite work if not condecer low or bad
Dec 17, 2011 | Kenmore Refrigerators
Kenmore coldspot has been turn off for a year, plugged back in and it will not get cold. You can hear the motor running but will not get cold.
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Aug 24, 2011 | Kenmore Side by Side Refrigerator
... Hearing an "electrical-like noise" coming from
Hello
Could be the compressor trying to start.It may be cutting out on high heat then reseting itsself.
Try unpluging unit for 10 15 min.If the refrig will still not start have a service tech come out.
Jun 16, 2010 | Kenmore 64802 Top Freezer Refrigerator
Front door won't open on 2003 Kenmore Washer and no release
When I had the same issue I tried the following things. It has been so long I do not recall the exact order I did them in or what finally worked but it did open.
Unplugged it for 5 mins.
Turned off everything else in house.
Plugged it back in.
Pushed Drain/spin - start (I could hear it try to click locked)
Then I pushed to stop it (then I hear the door lock click)
I tried all the different wash options and finally one of them allowed me to cancel the wash and the door unlocked. I know I unplugged it at least twice because of the computer needing to be reset. When a tech was working on it a couple of years ago I had him explain a few things and I don't recall the exact # of min's you are supposed to wait so I use 5 min's.
The water was still in my washer and I had to open the bottom and drain it by opening the cleanout to the pump. Large mess on the floor. Make sure you unplug the machine first. It will get on the wiring.
I also learned recently that your house electrical needs to be correct. These machines are extremely picky about their power.
Sep 17, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Coldspot Side by Side Model 51559101
Unplug the Ref for 15-20 min., plug it back in and listen for the compressor to start. You will need to be behind the Ref so you can tell if the compressor or the fan is running. It will help to take the cover off so you can see the compressor.
Compressor not running but you hear a clicking noise. The relay needs to be replaced.
Compressor runs but not cooling. Low on coolant
Feb 06, 2009 | Kenmore 53642 / 53644 Side by Side...
Frigidaire refrigerator making beeping sound
Unplug your refrigerator from the ac outlet, and 0open theref door for approx. 5 minutes. Then plug it again, after you hear the beeping close the door. wallah it's fixed.
Dec 21, 2008 | Frigidaire FRS3R5EMB Side by Side...
managemylife.com Logo
Top managemylife.com Computers & Internet Experts
thinksewfast
Steve
Paul Bade
Are you a managemylife.com Computer and Internet Expert? Answer questions, earn points and help others
