Question about Superstar SS-3900EGHPA CB Radio
What is pin #and color code for royce 650 mobile microphone
Where do I get a HMN9030A WIRE DIAGRAM?
Contact Motorola Solutions Get Support for assistance.
Mark
Motorola Mobility Support
Mar 28, 2014 | Motorola HMN9030A Microphone
Color wiring code
what radio?1 shield 2 audio 3 TX 4 RX
Apr 05, 2013 | Cobra HG-M73 Standard 4-pin Microphone
Whateve I speak on mobile is not audiable by the
hi,
have you tried to call and speak to another cellphone?if you tried and same thing was happen ,your phones microphone is damage and needs to replace..its easy to replace if you have a T6 tools ,removed the back cover of your phone then the front cover..screwed the 6 screws then removed the LCD or glass display together with its frame then you will see the charging pin of your phone, (it is color gray)...the microphone is at the right side included in the charging pin (color brown and the terminal is gold)....much better if you replace including the charging pin to make it easy for you...
after doing that ,back all the screw and the cover ,turn on the phone and test it..
i hope it will help you ,thanks for trusting fixya..
Jul 01, 2010 | Nokia 1100
Where is the switch for the brake light in Rolls Royce Silver Spirit 1986
hello there
the switch should be located on the brake pedal arm there should be a pin and or a clip to hold it on the arm you should also have a plug on the switch...hope this helps thanks
May 30, 2010 | 2007 Rolls Royce Rolls Royce Silver Spirit
The XLR came apart
The ground (shield) is connected at pin 1. I think that it's the white color cable.
The "in phase signal - hot" is connected to pin 2. It's the red color cable.
The "out of phase signal - cold" is connected to pin 3. It's the yellow color cable.
Your microphone is a dynamic one so there is no need for power supply and no worry about wrong connections.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs".
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
May 09, 2010 | Audix D6 Professional Microphone
Hi i need to know the color code to assemble a new 3 prong stereo 1/4 inch jack for a shure sm 58 microphone. i need to know the order and color to reassemble the mic cable to a new 1/4 inch guitar type...
Unfortunately, different cables use different colors of wires. Thus, you'll have to see what colors are connect to both ends of the cables. Here is the wiring:
XLR -> 1/4 inch
Pin 1 -> Sleeve
Pin 2 -> Tip
Pin 3 -> Sleeve
Dec 24, 2009 | Audio Players & Recorders
Don't know the conections of blue or red
If we're talking about the microphone cable wiring on a low impedance mic remember this. Cheap mic cables with XLR's on both ends often have no standard color code to follow. True pin 1 is ALWAYS ground (shield wire) but the other two wires could be any color of the rainbow. Look for small numbers beside each pin of the XLR connector and make sure that pin two on one end of your cable, is also pin two on the other end as well....etc. Special note: The XLR connectors set screws have reversed threads and it's the same for the XLR male plug in the bottom of the microphone as well.....Glen
Dec 24, 2008 | Shure Beta 58A Professional Microphone
Mic problem
Hi and welcome to FixYa,
Offhand, the 4 pin mic connector and corresponding pin # would depend on the communications equipment the Astatic was initially wired for. However, the color coding of the wires in an Astatic would be:
  • white - mic audio;
  • shield/blue - gnd;
  • black - NC or speaker;
  • red - NO or PTT;
  • yellow - not normally used.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 09, 2008 | Astatic 636L Noise Canceling Microphone...
Superstar SS-3900EGHPA CB Radio Logo
53 people viewed this question
Top Superstar Radio Communications Experts
AnyMHz.com
AnyMHz.com
yobo007
yobo007
cwradio73
Are you a Superstar Radio Communication Expert? Answer questions, earn points and help others
