Question about Kenmore Elite HE5t Washer
HOW DO I REMOVEW THE CCU ON A KENMORE H5T - Kenmore Elite HE5t Washer
  • 122 Answers
The top panel has 3 screw on the back, either 1/4 or T20 torx. Remove screws and the slide panel back. The CCU is located in the front Rh side of unit. It should be grey or white in color.
Posted on May 15, 2014
Kenmore elite he3t front load washer has no power. Replaced ccu, worked for a few minutes then stopped. Unable to power up
I would guess you have a short in the machine somewhere and likely have fried the new CCU also. If you want to and have the ability, you can track down the short and fix that. Then you will probably have to purchase another CCU before it will run. Wish I had better news. Good luck.
Jun 22, 2016 | Kenmore Washing Machines
Washer won't unlock flashes f14.....Kenmore Elite HE4t
F14 for Kenmore (Whirlpool) machines means EEPROM Error.
The Central Control Unit (CCU) receives it's data from an EEPROM on board the CCU, if there is an error reading this data, it will cause this error.
A power glitch may cause this error. Try unplugging the Unit for two minutes to see if that fixes the error. Check CCU. So its likely you'll need a new CCU board.
Check your owners manual, some models have up to a 5 year parts warranty on that CCU.
Jul 21, 2011 | Kenmore HE4t 3.8 Cu. Ft. King Size...
Dryer stops flashes f22 code, kenmore elite oasis
Take the top panel off, should be 3 screws on the back of the top panel. Then look at your CCU, and remove the wire connections from it and inspect the wiring in the connectors to make sure non of the pins are broken or burned. Then reset all the connectors back to the CCU and see if that fixes it, if not then your CCU would need to be replaced.
The CCU on your model is #6 here: http://c.searspartsdirect.com/lis_pn...7082-00003 Yes, unless you see mounting screws that hold it in place.
Here's the CCU for your model, in case you need to order it: http://www.repairclinic.com/referral.asp?R=1265&N=1454783
Hope helps.
May 15, 2011 | Kenmore Elite Oasis 6808 Electric Dryer
I have a kenmore elite he3 front loader washer. it gives me a f11 code when i attempt to wash a load.
F/11 is serial communication error code. It means the communication between the central control unit (CCU) and the motor control unit (MCU) is not good. Possible causes include worn or failed drive system components, faulty CCU or MCU, broken wiring harness, faulty drive motor, or faulty wiring harness connections in the CCU, the motor, or the MCU.
Jun 09, 2010 | Kenmore Elite 45986 Front Load Washer
Fl4 problem, kenmore elite won't spin or drain anymore.
EEPROM Error
The Central Condrol Unit (CCU) receives it's data from an EEPROMonboard the CCU.
If there is an error reading this data, it will cuse this error.
Check CCU
So its likely you'll need a new CCU board. Check your owners manual, some models have up to a 5 yr. parts warranty on that CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 16, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite he14. What is the f14 error?
EEPROM Error
Check CCU
Feb 18, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore he2 plus washing
CCU/Touchpad/LED assembly error(f21)
This error occurs if the touchpad/DED assembly is not able to transmit/receive data to/from the central control unit (CCU)
1. Check the touchpad/LED assembly by selecting different cycles and changing the modifiers and options available to confirm the touchpad/LED is responding 2. Unplug washer or disconnect power for five minutes. this will reset the CCU, and may reactivate the commmunication if the damage isnt sever. 3. Check Wire Harness connectors to the touchpad/LED assembly and Central Control Unit (CCU)
Replace failed component.
Sep 18, 2009 | Washing Machines
Kenmore F-01 error
The F01 fault code is indicating an EEPROM error or a PUMP DRIVER error. A communication error between the Central Control Unit (CCU) and the EEPROM on board the CCU occurred.
Possible causes of an EEPROM error:
A power glitch may have caused this error. Unplug the power cord for 3 minutes then reconnect power.
Possible causes of PUMP DRIVER error:
The pump driver fails to activate. Replace the the CCU board.
Most likely the CCU board will need to be replaced.
Good Luck!!
Thanks
Apr 22, 2009 | Kenmore HE2 Plus Front Load Washer
How to replace ccu on a kenmore he2 plus?
f01 code??? remove 3 screws on rear of top panel ccu is on right side toward frontrelaes tb will allow ccu to slide badck remove wire connectors by pulling small tb away from plug andpulling connector straight upnew ccu should wire up just like old one but try to chane one connector at a time to avoid confusion
May 21, 2008 | Kenmore Washing Machines
Kenmore Elite HE5t Washer Logo
64 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
