When printing, we had a color change away from magenta. replaced light magenta print head. printer started calibration but then gave error code "calibration error 2105". Whst do I do?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 145 Answers
First off make sure the printheads are ALL ok
after that replace the Lens Cover
Posted on May 10, 2014
Mix-it-up
  • 832 Answers
SOURCE: Not printing too well
Do use genuine brother ink for testing: If you're lucky the filter in front of the nozzles (which is part of the printhead) is not clogged. Do the power cleaning twice: power up. push menu then start mono then four times arrow up. machine will display maintenance. push arrow up several times til 7 is displayed then Enter then arrow up til 6 is displayed. Push Enter. push arrow up til 3 then Enter: P cleaning_all Push start/mono. After machine has finished maintenance will be displayed. push arrow up til 0 (zero) then enter then puh arrow up til 9. machine will print a test sheet. Repeat procedure above if no good result. After three times without success the printhead is clogged due to wrong ink. ...and do use dye-ink only for brother printers (pigmented ink will clog the filter!)
Posted on Sep 14, 2007
Inky
  • 691 Answers
SOURCE: Printer will not use the magenta color
You did not say what the results of the check pattern showed. Were all the lines present or were there some missing?
If lines are missing, follow the instruction in my previous posts for under head cleaning.
If check pattern is good then you may have a problem with a vacuum pipe. You can download a rescue kit for CX machines to help with this problem from tradebit
Posted on Nov 16, 2007
I had the same problem. It is most likely that your print head nozzles are clogged. Your choices are to attempt to manually clean them, or order a new print head from Canon.
Attempt the manual cleaning at your own risk, this doesn't always work. When it does not work, it means your print head is damaged.
To maually clean the print head. Printer cover up (so you can get to the cartridges and print head). Turn the Printer Off. Remove all the cartridges (I put each cartridge in a separate zip lock bag). Then flip up the lever and remove the print head.
Now heat (don't boil) distilled water (Iused a good sized cook pan and a plastic measuring cup to pour the water). Find a container you can soak the print head in (I used a deep alluminum baking pan). Pour the hot (not boiling) distilled water over the print head molding where the cartridges seat down (hold the printhead over your diposable alluminum pan). Then dunk the molded print head part into the pan numerous times. When the water gets dark change it (be carefuill not to stain the sink). Then slowly pour the hot distilled over the print head (opposite side from where the cartidges seat in). Eventually no ink will be in the water. Set the print head on a dry paper towel, and let it dry for 24 hours or longer. Reinstall the print head, then the catridges. If it worked, your true colors will return. It make take up to 15-20 photos to get all the ink catridges flowing-be patient. You can also just wait 24 hours after re-installing the cartridges, and hopefully it will take less photos to see the correct color match.
Never keep printing when a cartridge is low or out.
Print a few prints every week. Not printing for weeks causes the printheead and the ink flow to clog!
Good luck. I just recovered my S820 and my i900D using the above cleaning method. Like everything else, your mileage may vary! It cost me $1.29 for distilled water and about an hours worth of time!
Posted on Oct 20, 2008
SOURCE: HP D135 - replaced printhead - still doesn't print in that color
try this link : I followed the directions and fixed the problem. the instructions that came with the new printhead weren't really complete.
Here's essentially all I did for my fix - Opened the printer top, turned the printer off. Removed the "bad" printhead, cleaned the metal contacts on the printhead and printer with windex. Closed the printer. Turned it on. waited for it to reset. Opened the printer. Turned the printer off again. Installed the printhead. Closed the lid. Plugged the printer in again. When it was ready I accessed the HP toolbox and alligned the printheads and cleaned the printheads. It worked. Here's a link with photos.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpa02107&lc=en&cc=ca&dlc=&product=64986
Posted on May 01, 2009
pineworks
  • 4041 Answers
SOURCE: My HP C6180 is not printing its magenta color.
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Feb 21, 2010
Testimonial: "Thanks for you good advice. It all made sense to me and it should have worked. I found 9 others reporting the exact same problem. Craig patentQ.com"
I just installed new printer cart light magenta & magenta the self diagnostic shows them as loaded and 100 %. The print quality pattern does not print any color for either of them? No error codes?? I have...
printers will only print black and white unless you change the print settings to be color
before you go to print find the printer settings or options and make the default setting color
that way it will print exactly what is sent from the computer to the printer
Feb 07, 2016 | HP Photosmart C6200 C6280 Inkjet...
No magenta printing
Dirty mirrors will gives you dull color images..It seems color combination faulty..
chk original cartridges installed? or refilled cartridges?
Take supply status page..
chk colors..If color is dull(light) clean laser scanner assembly mirrors.
Do the color calibration..
chk drivers.,
Print from other file..
May 09, 2014 | HP COLOR LASERJET CP 3505 N PRINTER
Colors do not print right. We have tried to align, calibrate, and clean the heads, and the colors went from too much purple, to too much magenta
This would need a print head replacement kit there around $40 bucks from the mnaufacture. The issue here is the mix of the colors and this is caused by the print head.
Thanks I know this will help if you follow threw please do leave ratings and feedback
May 10, 2010 | HP Photosmart 3310 Printer
Colour problems when printing with dj 130
I had similar problems when I first installed the printer and after different tests we found out that the Magenta ink print head was faulty. Changed head to a new one and problem solved. You will need to recalibrate and do paper set up's again.
Aug 16, 2008 | Designjet Black Designjet 30/130 Series...
Magenta backgrounding
If the magenta is low the waste bin may be full and that may be causing the problem. If this is the case you need to change the toner. You can try calibrating the printer. You may have to do this 3 times in a row for it to make a difference.
Press Select-check mark button
Use arrows to go to Print Quality
Use arrows to go to Calibrate Color
Use arrows to go to Calibrate Now
Press Select to Confirm Calibrate Now
Jul 31, 2008 | HP Color LaserJet 2600n Printer
HP Business Inkjet 1000 error detecting new cartridge
Disconnect the communication cable (USB?).
Turn off the printer, wait one minute then turn it back on,
Then press the left button on the panel, the transparent one to the left of power button. It will print a status page. Check the dates and information under each color that is failing.
The ink cartridges MAY be outdated. Printing the test and information page without the computer connected fools the machine since it can't get your computer date.
If the cartridges are outdated, then change your computer year back to 2005 or so, reconnect the printer cable and send something to print, once the printer prints it out, reset your computer to today's year.
You will need to do this procedure whenever you turns off the printer. (Disconnect cable, change computer year, print, reset computer date).
Hope this works.
Wagner
Feb 20, 2008 | Canon Pixma iP6600D InkJet Photo Printer
HP COLOR LASERJET 3500
Hi!
If you could possibly manage to access the machine status menu and have it print to check the drum's life, fuser life, developer, etc.. pls refer. Kindly replace the toner cartridge accordingly use the menu settings when replacing any color if needed. Please print solid image or block in each color Cyan, Magenta, Yellow and Balck. Well see if what color causing the problem. Please let me know the print result it may be; washed out or too light, too bright or black, double image, or not clean. Don't hesistate to contact me again about the result.
Best regards,
Rosener Guyano
Jan 31, 2008 | HP Color LaserJet 3500 Printer
CLC 1180 with error E020 with sub 0124
Did you change the Magenta stater/ developer? A E020 code is saying that the toner desity is low. Try replasing the developer and run the ATDC for Megenta and see if that helps. You may have a problem with the developing ass'y it self. You may be able to take another colors dev. ass'y with the hopper open and see if the code goes away. The sub code 0124 means that it is the Magenta dev. ass'y
Jan 29, 2008 | Canon CLC 1150 Color Copier
Color calibration
You may first want to replace the magenta, but then do this.
  1. Press the Down Arrow and scroll to Troubleshooting.
  2. Press OK.
  3. Press the Down Arrow and scroll to Print Quality Problems.
  4. Press OK.
  5. Press the Down Arrow and scroll to Calibrate Colors.
  6. Press OK.
  7. Scroll to the Tutorial Page using the Down Arrow or Up Arrow key.
  8. Press OK to print this page.
Dec 07, 2007 | Xerox Phaser 6250DP Laser Printer
52 people viewed this question
jasbo
jasbo
