Question about Dell Latitude D610 Notebook
Computer froze I receive error code 1000-0146, just like other poster. The computer turns on but freezes at startup. Do I need a new HD.
    Scholar:
  • 109 Answers
You will need a new hard drive. Its a DST fail "Drive Self Test". If you have the original Windows CD you could boot to the recovery console and backup what you need before swapping out hard drives.
Posted on Jun 23, 2009
Error Code 0F00:136C
1.check ur harddisk for error (if HD okay)
then
2. clean your ram for dioxide connection (copper lower part connect to slot) or try another ram (good condition or new)
if none of the above solve your prob then it time to replace new MAINBOARD/ MOTHERBOARD system..
hope this solve..
Oct 27, 2013 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Dropped laptop, Error codes 2000-0142 and 2000-0123
Remove the HDD and test. Replace if necessary.
Nov 29, 2012 | Computers & Internet
Hi, I need help, my pc freezes and I cant move the mouse or do anything else, I have to restart it. Please Help me.
Start/Run... Run msconfig. On General tab, select Diagnostic Startup. Reboot. Use the computer in this state for as long as the freeze usually appears.
If no freeze, return to msconfig General tab. Selective startup, uncheck Startup.
Repeat reboot and trial usage. If no freeze, check normal startup. On startup tab uncheck everything that looks non-essential. Reboot and retest. When the computer seems "fixed" recheck one startup item at a time. Repeat your timed test until the issue reappears. When it does, the latest startup item you enabled is the cause.
Oct 16, 2012 | ASUS P5VD2-X Motherboard
My e9180t froze during first startup during the performance check
Restart it. It will be fine. If not . do a restore.
That what I do . I have a HP a730n.
Ken
Sep 25, 2009 | HP Pavilion Elite e9180t PC - 3.00 GHz;...
My son's r4 keeps freezing in middle of game. How do I sort this please? Does it need reformating? Whay exactly does reformating mean anyway?
I had this same problem with 3 ds lites it would freeze on startup some times after freezing with the r4 what i found is the card is not making a good connection with the pins in the slot 1, you can get a new slot 1 for a few bucks but it requires soldering. until i received my new one i took a 1.0mm screw driver flat head and pushed the card all the way down and lodged it with the screw driver. Has not froze after that.
Sep 14, 2009 | Nintendo DS Console
IMac freezes on startup. Can't use safemode.
Safe mode just requires holding shift down during start up and if it starts up at all this should be possible. Once in safe mode, you should be able to use Disk Utility to Verify disk and Fix Permissions. To Repair disk or with/without safe mode you need to startup with your install disk and on the first screen or after selecting language, use options to select Disk Utility. You really should tell us the MacOS version--10.3.9 10.4.11 10.5.8 or 10.6 are current and tell us your install disk version, too. With safe mode you can use terminal to run fsck to fix the disk, read the man page. Alternatives include starting up in Target Disk Mode (command+t at startup) and using your computer as an external disk for another Mac by Firewire or possibly USB, fixing it using the others software. These methods in descending ease.
A now permanently dark screen would indicate a bigger problem and a trip to an Apple store for an evaluation. Tell us your iMac model--could affect whether you can easily savage your disk data in this case. -Ken
Sep 11, 2009 | Apple iMac G5 Desktop
Froze. very slow. very hot
Sounds to me like the cpu fan,has died and the cpu is overheating causing the freeze, the slow running, and the excessive heat. the cpu is probably fried.
Jul 12, 2009 | HP Pavilion dv6000z Notebook
Viewsat ultra 2000
viewsat ultra need new bin and a fix for this box freezing and won't unfreez until i turn it off from the back. can someone help me please
Mar 03, 2008 | ViewSonic VA720 17" LCD Flat Panel Monitor
User environment error message and HDD fail of Test #2-07
i would suggest that you restore your pc back to a previous date and see if the 30 second freeze ups go away. This has happened on a few of pc's i have had, but the reason i put it down to was a corrupt windows update or one of window malicious viral scans. Go to start>programmes>accesories>system tools and select system restore. When opened up choose a date previous to when this started happening or choose a date before the last updates or system check, only dark lettered dates can be restored the greyed out dates cannot.
Jul 11, 2007 | HP Compaq Presario M2010US Notebook
Dell Latitude D610 Notebook Logo
510 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
