Question about Shark Euro Pro Atomic Ant Ep044 Canister Vacuum Cleaner Bags Filters
Euro Pro EP044 Atomic Ant--it died and I need to know how to remove the cover to get to the fuse.
I need to take the cover off. I removed the 3 screws that I found but nothing came loose. It looks like the plastic case snaps together. I think the fuse blew just like it did with my EP022 (TINY WONDER). If I can remove the first section of the cover, the rest might come apart so I can see the fuse.
2 Suggested Answers
fred_license
  • 350 Answers
SOURCE: How do I remove roller brush from Shark cordless handheld vacuum?
You have to remove All the screws, and you are correct they are almost impossible, after that most of the part's also snap together, so you almost have to break it to take apart, a vacuum repair shop knows all the tricks to opening these up....
Posted on Feb 20, 2015
Hi, My Shark Pocket Mop steamer isn't getting steam to the head, and when I removed the head I found that there is calcium build up on the opening of the body. What is the best waytto remove it? gnc
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the
Shark Manuals that you need.
heatman101
Jan 17, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark euro-pro x upright vacuum that shuts down every 15 minutes
These are prone to overheating. The manufacturer put a foam 'filter' wrap around the electric motor. This filter wrap insulates the motor, trapping heat inside, which causes overheating. The motor is very similar in form and function to the one in the Hoover Windtunnel, but the Windtunnel has no filter wrap. It doesn't overheat, and functions fine without it. There is a filter on the intake anyway. It's a redundant filter, and I have removed mine. It works fine now.
If you take the filter out yourself, you will need a special screwdriver for one of the motor cover screws. I guess they don't want the consumers opening it up.
I suggest taking it to a vacuum repair shop and explaining to them the problem, and asking them to remove the filter wrap from the motor.
Jan 11, 2010 | Euro-Pro UV209 Upright Vacuum
Steam Vaccum won't switch on
it sounds like your thermal fuse went out and u have to open it up ant test the fuse with a multimeter...I had the same problem and had to replace the thermal fuse...I ordered a fuse(sf188e) from ebay...cut the old one out and soldered in the new one...hope this helps.
Dec 30, 2008 | Euro-Pro Shark Steam Mop - Gray/ Purple...
The cord cover on my euro-pro ep601 is broken at entry point
There is a clip under the handle on the front of the unit above the dust cup if it is vertical that you may need to release. There also is a hidden screw under the thermostat label.
Dec 18, 2008 | Euro-Pro EP601 Bagless Upright Cyclonic...
Shark Euro Pro upright vacuum V1310RS
Most vacuums you either remove the bottom plate, or the top cover comes off. If no screws on the top cover, then turn vac. over and remove the screws on the bottom. Then you should be able to get to the brush roll and belt.
Feb 15, 2008 | Vacuums
Shark Euro Pro Atomic Ant Ep044 Canister Vacuum Cleaner Bags Filters Logo
Top Shark Vacuums Experts
Thomas Perkins
Thomas Perkins
Ruth summersides
Are you a Shark Vacuum Expert? Answer questions, earn points and help others
