Question about Dell Latitude D410 Notebook
Rm bios related issues will not boot
Goes past Dell screen and then stops on black screen with letters RMR in the corner
Cuke
SOURCE: Dell D600 LCD issue
What I've found on two laptops I've worked on in the past two years is that in a case like this, there is a little pin near the power button (or on the strip up near the display) that tells the laptop when the monitor is closed.  If that pin gets stuck, the computer will think it's shut all of the time.  The sensor is only active in normal mode of windows with the drivers installed (if it's in safe mode or VGA mode  the sensor does not work until you raise the resolution.  the sensor doesn't work at all if you boot from a knoppix cd.)
You may be able to just flick the pin and get it unstuck, but in some cases you have to remove it all togther.
To remove it, turn the lapotp off. lean the monitor back as far as it can go (don't force it). You then need to carefuly pry up the strip that the power button is on (ussually there is a space you can pry open on the left or right side of the strip depending on the model laptop; be very careful not to break anything).  You can then pop it out with a small knife or tweesers and clip the strip back down.
If you don't feel comfortable doing this, then find someone who is.
I hope this helps someone.
Posted on May 14, 2008
Geekman
  • 32281 Answers
SOURCE: Dell Latitude D800 Boot Problem
Did the diagnostics pass the RAM and the hard drive.
You should check the BIOS settings to see if the hard disk is detected, if possible reset the BIOS back to the default settings and see if the computer boots up.
If not :-
Then it appears that the operating system is either corrupted or system files were deleted or infected with viruses.
Your only option is to do a operating system repair or a complete new install of Windows.
I recommend you do a new install.
Posted on Nov 23, 2008
pagebor
  • 2785 Answers
SOURCE: Inspiron B130 won't boot
plz try to boot through safe mode, if you can then log in normally.
if you cant boot from safe mode then you have to reload or repair your os.
Posted on Dec 23, 2008
SOURCE: Dell latitude d600 screen goes black during boot
ok after you have booted in safe mode do a restore to a date just before the last day it worked properly and try that restore is found here
start/programs/accessories/system tools/system restore
hope this helps
Posted on Mar 16, 2009
  • 144 Answers
SOURCE: Dell Vostro 1500 will not boot
NEEDS TO BE REINSTALLED SEE IF YOU CAN HIT F12 AND SEE IF YOU CAN GET THE BOOT MENU
Posted on Jun 06, 2009
Problems to obtain a complete system boot at first try.
See if you can boot to safe mode. Run check disk on the hard drive. Make sure the BIOS battery is ok.
Oct 29, 2017 | Dell Computers & Internet
Turns on but black screen
Restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode.
If you able to start in the safe mode then Scan your computer for viruses. Some viruses can cause a black Screen , especially ones that infect the master boot record (MBR) or boot sector.
Update drivers for your hardware. black Screens are hardware or driver related so updated drivers could fix the cause of the STOP error.
Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including black screen.
If it didn't helps you then simply get the system utility program like PC Fresher that will fix windows errors that cause of black screen screen
Oct 04, 2013 | MSI Wind U100-030US Laptop
Black screen
Sep 16, 2013 | Dell Latitude E5500 Laptop
It wont boot, goes to black screen with whit blinking dash
Yes, this sounds like the traditional black screen issue, but it's different! This machine is a Dell Dimension 3000 with XP. System won't boot. After Blue Dell BIOS splash screen with F2 & F12 options, it just goes black. There will ultimately be a white cursor in the upper left hand corner. I can edit BIOS with F2, I can get in to the boot menu with F12, but I can't do anything after that. I can even get in to the Safe Mode menu (F8), but it never boots.
Aug 14, 2011 | Gateway LT2001u Netbook
Hi my dimension 3100, just after the boot the screen stay on the progression bar and no more! I just can read Dell DV051 Series Bios Revision A03 and in the lower corner the logo Intel Inside pentium...
are you saying you are stuck on the screen that says dell on it as soon as it turns on, and that f2 to enter bios does not work? if so, the issue can be related to a bad hard drive or bad motherboard. i have come across this issue alot, normally on desktops, and those are the 2 fixes that are usually the problem.
Jul 08, 2011 | Dell Latitude D600 Notebook
Hi - the screen on my dell d410 goes dark 20 seconds after powering on, regardless of whether I boot normally to Win (XP) or hit F2 to reach the BIOS. Note the screen display is just about visible if...
As per the problem description the Laptop Display is Fade out even in BIOS window. If that's the case then the unit must be serviced as the issue is Hard ware related. The Computer uses minimum Softwares in BIOS Mode, Hence most of the Diagnostics related to Displays and Input adn Output devices are done in BIOS. I suggest you get the unit serviced. For details of the Nearest Dell Authorized service Center please visit the following Link:
http://www.dell.com/content/topics/reftopic.aspx/dfo/topics/en/services/services_warranty?c=us&cs=22&l=en&s=dfh&~ck=mn
Dec 06, 2010 | Dell Latitude D410 Notebook
When my dell e510 boots and gets past the first bios screen and shows it booting up the system components it is completely unreadable all letters are in the wrong place or distorted and the entire screen...
Sounds like it could be a graphics card problem problem is it's integrated so part of your motherboard unless you have installed a graphics card.If you have a graphics card in it take it out plug your monitor into the other graphics port and enable on board graphics in your BIOS/ integrated peripherals by pressing F12 key,..if it now works you know your graphics card is broke.If you havn't a graphics cardin it your motherboard needs replacing.
Aug 04, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Can turn computer off and on and I will see the windows screen then the screen goes blue with a blinking cursor. I also have a dell.
It is related to bios enabled computrace models. It has happened twice to my dell 1525 I bought it 12/08. The software used to image your recovery partition is incompatible with the two tiny hidden partitions computrace uses. Computrace gets corrupted and shuts you down like you stole the laptop through no fault of your own. All of you data is still there so don't worry. smile.gif
According to dell, you have to remove the hard drive, download your correct bios from their site using another computer of course, and while the hardrive is still removed, flash the new bios and then reinstall the hardrive and it should work fine with all your data intact.
I found this tech update at dell's website this problem goes back to 2005 but the most recent update was dec. 2008 and includes many laptops including the 1500 series.
Computrace freaked out and completely disabled your system. You can send it back or follow the instructions in the update if you are out of warranty.
I am a graphic designer so I needed to finish a project, so I did this to get it running again, backed up my data, and sent my laptop back for a replacement.
I have included part of the update and the Dell web link for you below.
Certain Dell™ Portable Systems Display a Black Screen with a Flashing Cursor when Booting from the Hard Drive
This issue only occurs on Dell portable systems that shipped after Oct. 31, 2005, and have the following configuration:
  • The CompuTrace BIOS feature is supported and has been set to Activate.
  • A system account has been created, and the laptop is registered with Absolute Software.
  • The Altiris Backup and Restore application for local client has been installed.
Affected systems manifest the following symptoms:
  • When the system is powered on, it does not complete the boot process, and the only indication that a problem has occurred is a black screen with a flashing cursor in the upper left corner of the display.
  • The system cannot boot from any media as long as the hard drive is attached. The only way to boot to other media is to remove the hard drive from the system.
Altiris Backup and Recovery software uses an atypical mechanism to hide a partition within the system volume. This mechanism involves hiding valid data relating to the Altiris Backup and Recovery software in marked blocks that the operating system is designed to ignore. The installation process for Altiris also leaves table entries that store directory information for NTFS. These entries are formatted differently than those normally observed on an NTFS-formatted partition. These changes were not anticipated, and we are not aware of any other product that uses the file system in such a manner.
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&dl=false&l=en&s=gen&docid=2A28448CB118EBAFE040A68F5B2854D5&doclang=en&cs=
I hope this helps.
Feb 18, 2009 | Dell Inspiron 1501 Notebook
Black screen
Some USB devices seem to cause this problem. I've had it myself. USB devices when hooked up cause the computer to freeze as it hard for USB drivers to be loaded outside of windows. Try updating you windows thru windows update though even updated I still run into the problem sometimes. If updating dosen't work you need to keep the drive unhooked while booting then hook up in windows.
Dec 11, 2007 | Dell Dimension 8400 PC Desktop
Will not go past startup screen
I think u need to updrage ur bios and RE-INSTALL UR WINDOWS
Oct 26, 2007 | Dell Inspiron B130 Notebook
Dell Latitude D410 Notebook Logo
22 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
