Question about NAD C542 CD Player
How to repair a NAD C542 cd skipping - NAD C542 CD Player
5 Suggested Answers
  • 5 Answers
SOURCE: NAD C542 CD PLAYER
maybe it is just the belt for the tray motor.
Posted on Dec 01, 2009
robotek
  • 1512 Answers
SOURCE: Pressing the 'open' button on my NAD C542 CD
G'Day Michael,
Having fixed thousands of CD players in my career, and also being a NAD Authorised service guy from 1989 till recent times, I can comment with some authority to your situation, and correct some of the ill found assumptions given to you already.
This unit uses a KSS213c transport. Very common and used in many machines, also relatively reliable.
The drawer load motor is not shown above. Is will be mounted on the black plastic load assembly. The drive belt/motor for it will be under the tray runners.
If you do not hear the motor run, then it WILL NOT be a broken or failing belt. However, this is the most common problem with this style of transport. I would be checking anyway to see, the load motors do free run fairly quiet with no drive belt connected. Wind the tray assembly out by hand by kicking the gears over to open the draw to see the belt/motor
Because you cannot get it to work from the remote, AND you have "open" indicator on the front panel, it WILL NOT be a faulty front panel button(never seen one fail ever!)
I have never replaced a load motor to a Sony transport. Spindle motors can be a problem, but they never stop working altogether.
I would be checking the tray mechanics, a jam caused by something fouling the gears may cause a fail. Tap the front of the draw as you press eject to see if you can encourage it to work.
Sometimes, small nylon drive pinions can split, the excessive gap in the gears caused by the split causing a bind. Check also for blown pico fuses in the servo drive stage. This will cause no drive to the load motor.
If you cannot pin down the source of the problem, the player IS welll worth repair. These machines sound great and would have cost you a few bucks to begin with. If you need help locating an expert NAD authorised repair guy I can help.
Happy to discuss any of this further with you. As previously direct your comment to me by name. Cheers
regards
robotek
Posted on Aug 04, 2010
walesarumi
  • 6993 Answers
SOURCE: my Nad C542 stop read
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it cannot read data/files on CD's effectively. That's why it stops reading.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Good luck.
Once this us done, your player will play all DVD discs again.
Good luck.
Posted on Jan 14, 2011
SOURCE: Nad C542 Troubleshooting
found same problem with mine, solution .. place clean paper over the optic, then a magnet, leave for a few seconds, the build up of static causes a magnetic field in the optic preventing it tracking, have cured a few other brands with this as well .. shows manufactures are putting inferior parts in to their players, hope this helps !!
Posted on Apr 20, 2013
Nad cd541i doesn't always read cd's; it can tell me how many tracks/minutes there are but won't find the beginning of the cd; in this case, sometimes if I skip forward two or three tracks and...
It sounds like a physical problem in the laser seek mechanism. Possibly a sticky area on the guides. Heavy reading for all malfunctions related to optical disc...
http://www.repairfaq.org/sam/cdfaq.htm
May 19, 2011 | NAD C542 CD Player
I get a no disc message even though there is a disc in the machine.
Hello
there are two option of such fault
1. lens is dusty, clean the lens using moist cloth/cotton 2. lens got bad need replacement
third option is CD is faulty/scratch
hope it helps. do rate if so
Dec 12, 2010 | NAD C542 CD Player
Vfl display not working
no display could be a problem with the inverter circuit that drives the display
usually a transistor goes bad around the display area
check the board for dry solder joints as well
sme CD players have an option to switch off the display, check its not turned off
usually a button on the unit or the remote
darren
Nov 26, 2010 | NAD C542 CD Player
My NAD cd player CD slot goes in and then opens...it does not retain the CD inside to play...
Hello
This fault is due to loose tray loading belt or weak loading motor. You just change the loading belt with same type. Never use a belt more than tight. Use the same size. If belt changing does not help, replace the loading motor. OK.
Nov 21, 2010 | NAD C542 CD Player
How do I clean the lens? CD lends cleaner only provides temporary relief from fuzzy sound.
hi,
remove the cover, remove the spindle cover of cd player inside, thier you can see a little glas object
clean it with coton sticks and liquid that you use to clean the windows.
move over the lens gently once wet and once dry
now you lens is clean
thats all
greetings
cis
Feb 16, 2010 | NAD C542 CD Player
My NAD C 541 cd player will not play any discs. I open it put the disc in and it tries to scan and then rejects the disc and opens on its' own. There is the word 'over' in red below the track number...
It could be the belt for the tray mechanism. Tray closes then motor is pushed up to CD. If belt slips or physical mechanism is sticky CD will not spin and tray will reopen.
Nov 09, 2009 | NAD C542 CD Player
NAD CD player C 542
SORRY but you need to get this to your dealer,don,t think anything is stuck in there just a faulty drawer mecanisim.
hope this helps.
CABLE GUY.
Aug 04, 2008 | NAD C542 CD Player
NAD C542 CD PLAYER
Jun 27, 2008 | NAD C542 CD Player
Nad plays for a minute or so...
First thing to do is to check all your new caps and their polarities.
Capital98
Dec 19, 2007 | NAD C542 CD Player
Mar 20, 2007 | NAD C542 CD Player
NAD C542 CD Player Logo
225 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
