Question about Garden
Craftsman mulcher mower
Our Craftsman 6.0 hp 22" cut lawn mower runs to fast and vibrates really bad..How do I fix this
SOURCE: Spark Plug setting for craftsman 21'' mulcher push mower
Found a Manual from sears, thank you
Posted on Mar 20, 2009
  • 376 Answers
SOURCE: Craftsman 42 inch riding lawn mower is not cutting evenly
The first thing to check is your blades. If one is bent, it will never cut even. It happens a lot hitting roots, antbeds, etc. Mulching blades will bend easier than a straight blade. It's best to take them off and lay one on top of the other to see if they're bent.
Posted on May 25, 2009
SOURCE: my craftsman rotory lawn mower 6.5 hp self
You have water in in the carborator, I'll bet. I had this same problem. Here's what I did.
I emptied the gas tank, put in a new spark plug, changed the oil and then unscrewed thd big nut on the bottom of the float container (attached to the carborator near the rubber gas injector button) and emptied and cleand the float container. Then i put it all back together, pulled the cord and the same thing happened, but this time i could keep it going by having my daughter constantly pushing the rubber gas injector button. After it had run for a minute with this constant pushing of the button, all the water was gone from everytwhere and it worked.
Posted on Aug 13, 2009
bargainbin2
  • 123 Answers
SOURCE: 13.5 hp Craftsman lawn mower 5-speed
Here is a picture to help you place it on right. There are two deck designs pick yours.
Posted on Aug 29, 2009
vincob
  • 718 Answers
SOURCE: my craftsman self propelled lawn mower no longer
if it is a belt driven drive check the belt for tension or break. or check the cable that engages the drive wheels.
Posted on Sep 04, 2009
My craftsman riding mower vibrates so bad when I engage the mower. How do I stop vibration?
Things you need to check, loose blades, blades out off balance, bad belt or loose belt, bearings in the blade mandrels worn.
Jun 29, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My Craftsman mulcher 21" 6.0 lawn mower starts but won't stay running
clean the carb left over old fuel plugs the jets inside
Jun 08, 2012 | Craftsman Garden
Craftsman 6.5,22 inch cut. model# 917.379470
does not sound good the off balance of a loose blade could have caused the rod to break inside the engine the age of mower and how much use it has had could be a factor only way to really know it to look inside the crankcase.
Jun 06, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
I HAVE A CRAFTMAN LAWN MOWER 6 HP SELF PROP RUN FOR 2 OR 3 MINUTES ONLY I CHANGE THE OIL GASOLINE AND S/PLUG CAN YOU HELP ME TO FIX IT?
It sounds like you have a bad Ignition Coil (Module). This is how they act when they start going bad. When they get warm, they quit. Some will last up to 20 minutes before they shut down. You can sometimes find a used one pretty cheap at a small engine shop.
Jim
Aug 07, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
I recently got a green Craftsman with yellow writing "Craftsman" and ("22" Mulcher") I didn't know where to look for the model number. I found a family "YBSXS.1901VC" then "274466" it also said not legal...
You need to take the mower into a SEARS authorized store and have them show you the code meanings. Craftsman has changed a lot of their codes so for the first time this is the only way.
Sep 11, 2010 | Craftsman Garden
Started to vibrate and stopped working when I passed over roots.
you had the mower up on it's front oil leaked in the head take the plug out and pull it a few times to clear the oil out and clean the plug it should take of the problem
Jun 26, 2010 | Craftsman 22" Rear Bag Rear Propelled High...
Is my Craftsman Mulcher lawnmower a 4 stroke or 2 stroke engine??
It should be a 4 stroke, the only thing I can find on it is the mulcher blades, set up called a side discharge mower. It has a 5.5 HP ,22 inch, briggs and stratton engine. Hope this helps.
May 05, 2010 | Craftsman Garden
Intek 6.5 HP in a Craftsman 21'' mulcher/bagger --loss of power--
No - 6.5HP is enough to cut 3" at a fast walking pace. I would suspect a blown head gasket.
Sep 26, 2009 | Garden
Replacement part for Craftsman 650 Briggs & Stratton 22" multi cut mower Model #917.376741
You first need to locate the model number on the mower, not the Briggs engine. Then go to searspartsdirect.com and enter your model number on the right side of the web page. This will take you to a list of parts for your mower. Your model number should be located on the deck of the mower (you didn't say if it was a rider or a push). Rider model numbers are located on the rear of the body behind, on or under the seat. Push model numbers are found on the back of the deck between where the handles attach to the frame.
May 25, 2009 | Craftsman Garden
Garden Logo
75 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
