Question about Whirlpool GEW9868K Electric Dryer
What is wrong with my dryer?
Dryer has been working good. It has finished a load of clothes and I started a new load and the machine does not start, like no power. I checked the power box fuse and all seemed to be OK. Pushing all the buttons on the dryer made no difference,and was sure the door was closed.After it sits for awhile it will come right back up like nothing I wrong. I changed the thermal cutoff fuse and thermostat, but it dd not repair the problem. Any suggestions?
  • 27 Answers
Check the vent line (when it is working) for for good air flow...residual heat may be tripping the overheat safety.
Posted on May 17, 2014
2 Suggested Answers
catriver
  • 878 Answers
SOURCE: dryer will not start
slats, electric dryer, you want to check the thermal fuse first. Remove the lower panel on the dryer, push in on the two clips each side and it will pull off. Remove the vent screen on the inside. Remove the quarter inch screws holding the blower wheel cover on. To the right of the blower wheel on the housing you will see a white fuse top side. Two wires going to it. You can ohm it out or jump it temp. to see if the dryer starts. Also make sure the door switch is operating. Check the attachment. Catriver..post back
Posted on Mar 03, 2007
I have a Kenmore Elite HE5 Electric Dryer, Model 110.8708 The dryer will not rotate when I push the start button, the "sensing revising est. time" lights up amber in the Cycle Status display...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 24, 2011 | Dryers
Washing machine not washing clothes properly, clothes coming out cold. dryer also not heating up, repairman said to get new heating element for dryer but said nothing was wrong with washing part of machine...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jun 11, 2010 | Hotpoint Aquarius WD640 Front Load...
Water building up during the dry cycle and clothes getting wetter
1) Make sure wash cycle is 100% finished (sometimes dryer will start before - usu on synthetic cycle & allows water to continue flowing in)
2) Manually start the dry cycle after you ensure wash cycle is finished and push in the wash cycle button.
Hope that helps! If not, you may need a new control module (I did - hope you don't!)
Apr 19, 2010 | Haier XQG65-11SU Front Load Washer / Dryer
Our fridgidaire gallery dryer squeals very loud for about the first 5 minutes of being on then quietly finishes it's job. It does this with each new load.
You could have a belt that is slipping on the heavy load of clothes when you first start the dryer, if so you may need to replace your belt.
Your problem sounds like drum rollers is in need of lubrication.
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
Good Luck,
I hope this helps
Oct 16, 2009 | Frigidaire Dryers
Whirlpool Electric dryer won't start
Your problem sounds like it could be a broken belt, faulty motor, or maybe the belt has slipped off of the motor or idler arm pulley.
You can try this first:
Uplug the dryer, reach inside and try to turn the drum 1/4 to 1/2 turn, the plug the dryer back in, and push the start button. Sometimes motors will get dead zones in them and this will move it from that zone.
If you attempt the repair, and if you have a front loading machine, you would remove the front of the machine, this will expose the drum and belt, you can now check the belt to see if it is ok. If it is ok, then you can remove the drum and belt and this will expose the motor, idler arm with pulley and drum rollers.
While you have the drum out of there it is a good time to check the condition of the drum rollers to see if they have flat spots on them, if they do have flat spots on them, then need to be replaced. If not then I recommend that you lubricate them at the shaft with a good grade of Machine Oil such as 3 in One oil. This will save problems later.
Good luck,
I hope this helps you
Oct 04, 2009 | Whirlpool LER5636P Electric Dryer
Time work problem
If it is relatively new, then my advice to you, is to contact the service agents, and get it looked at under guarantee.
Please rate my solution.
Thanks.
Sep 17, 2009 | Bosch Logixx WFT 2806 Front Load...
Wash machine sometimes gets stuck on rinse cycle & dryer not dry
Sounds like the drain hose for the washer is too far down in the stand pipe at the wall causing a siphon effect, try raising drain hose a little. The dryer sounds like the vent line from back of dryer too wall is pinched causing an air flow obstruction. Hope this helps.
Mar 19, 2009 | Whirlpool Washing Machines
Moisture in dryer
is it cold outside clean your vent run dryer with out vent on gas dryer?
Feb 24, 2009 | Maytag LSE7806A Top Load Stacked...
Why wont my machine start drying?
I called Whirlpool on 08706008989. The machine can only dry half a load of washing at a time. At the end of the washing cycle, the Programme dial should be at either the sun or half sun symbol. Remove half the washing, set the drying time via the drying time dial and press the 1/2 Load Dryer button - Voila dry clothes!
Oct 28, 2007 | Whirlpool AWG320 Front Load Washer / Dryer
Dryer will not start
Mar 03, 2007 | Whirlpool GEW9868K Electric Dryer
Whirlpool GEW9868K Electric Dryer Logo
67 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
