Question about Craftsman Garden
Glow plug location on a 1600 for tractor? - Craftsman Garden
  • Craftsman Master
  • 2,478 Answers
Most are in pre-cup with fuel nozzle.
Posted on May 11, 2014
Where the thermostat for the glow plugs on a 6130D John Deere tractor located
no thermostat for glow plugs
there is a relay that turns them on when the key is in the correct position
Dec 16, 2017 | John Deere Garden
Diesel hard starting after glow plug goes out
What in God's creation do you think the glow plug is for? The glow plug is there to start the initial detonation of fuel and once that happens it is not needed and the diesel diesels!(runs without help).
Sep 07, 2015 | John Deere Garden
Glow plug relay
81418784532&item=281418784532">G1900 Kubota, the glow plugs are energized when the keyswitch is moved halfway to the start position. Also the glow plug indicator light is illuminated when in this position. I hold the key in that position until the glow plug light goes out, and then crank the engine. On really cold days I repeat the glow plug cycle several times before cranking.
Jan 03, 2015 | Cars & Trucks
Why does the glow plugs on my tractor stay on
same vehicles he glow plug stay on for extra time up to 1 minute
Oct 21, 2014 | Cars & Trucks
LOCATION OF GLOW PLUG/1020 JOHN DEER TRACTOR?
Should be around injectors. A little plug with a wire on it.
Sep 01, 2014 | Garden
I have a 4500 John Deer tractor that typically won't start in cold temperatures (i.e. 39 or below) otherwise it starts promptly. I've pushed the key in to heat the glow plug a minute or more.
The 4500 John Deere tractor sounds like the glow plugs are not working. Checked voltage at the glow plugs to make sure that there is 12 DC volts.(Might have to remove main wire from the glow plugs to check!) If no voltage at glow plugs there maybe a bad fuse,relay or wire connection in the glow plug circuit. If there is 12 DC volts at the glow plugs, it is possible that the glow plugs need to be replaced.
Jan 01, 2013 | John Deere 420,1020,2010,2020,2510,2520...
I have a JD X595 Diesel. This is what happens, say if I start it, then shut it down it will not start again right away. The first time it starts the glow plug light comes on. Shut it down and try to start...
Before you do anything grab a test light, remove the wire from your glow plug, put one end of test light on positive on your battery and the other end on the glow plug, if the light comes on than your glow plug is ok, if not replace, otherwise you need to locate the relay/sensor that tells the glow plug when to go off/on which is more than likely the problem, you may be able to locate it by tracking the wire from the glow plug or your local John Deere service provider may be able to tell you exactly where it is over the phone.
Jun 09, 2011 | John Deere 26HP Hydrostatic 54" Riding...
Lost glow plug function
Had same thing happen on my New Holland 1630. Took the buss bar off the glow plugs and pulled them out and tested with test leads on the battery. They glowed. Put a volt/ohm meter on the buss bar and turned the key to glow position, no 12 volts present. Checked for blown fuse, nothing blown. Looked at relays. There was a glow plug lamp timer next to the start relay. Wiggled wires going to timer while asking for glow with key. Saw the glow lamp flicker. Took timer out and opened it up. Found a broken solder joint on circuit board resulting in a loose capacitor. Soldered the crack and put back on tractor. That was it! Glow plugs work now.
Dec 04, 2010 | One Step Ahead New Holland Tractor Set
Correct procedure for starting tractor?
Just till the plug / light glows then start, if you hold it too long the glow plugs wil burn out causing hard starting.
Apr 10, 2010 | Mitsubishi MT160, MT160D, MT180, MT180D,...
Garden Logo
21 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
